01-16-2013, 09:55 AM | #26 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
USB, mini USB, and micro USB all use identical communications protocols, just different physical connectors. You just have to pay attention to host (port A) or device (port B). With regular USB it's very obvious, host (A) connectors are the big rectangular ones you have on your computer, device (B) connectors are the big square ones that you often see on printers and external hard drives. With mini and micro it's much less obvious, the connector and jack are just shaped slightly different. There are even on-the-go ports which can act as either host or device depending on what you plug into it (the phone's port is almost certainly one of these, it can act as a device when you plug it into a computer, or as a host when you plug a controller into it). You don't want to get the wrong adapter and accidentally plug two host ports into each other, for example, or they'll both be trying to power each other.
01-16-2013, 11:55 AM | #27 | |
Member#: 321715
Vehicle:03 Big 16G WRX PSM |
01-16-2013, 05:03 PM | #28 | ||
Member#: 165749
01-17-2013, 01:10 AM | #29 | |
Member#: 140444
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
I haven't heard that direct from Microsoft, but check this out... http://www.displaylink.com/support/ticket.php?id=335 I'm not sure where to find an authoritative source, but it looks like X86-based tablets like the Surface Pro might be the only viable option. |
01-17-2013, 07:30 AM | #30 | |
Member#: 70395
http://www.speedport.us/speedportapp.html |
Similar Threads | ||||
Tactrix/romraider On Mac | 07white450r | Open Source Reflashes | 3 | 09-01-2010 07:21 PM |
RomRaider Works Romraider ecu logger doesnt | tumtum411 | Open Source Reflashes | 2 | 06-03-2010 10:56 AM |
Tablet Ignites Debate on Messiah and Resurrection | poison | Off-Topic | 8 | 07-05-2008 11:12 PM |
Enginuity on a Tablet PC? | NJ2.5RS | Commercial ECU Reflashes | 3 | 11-25-2007 12:39 PM |
NJ: Compaq Tablet Pc now on ebay | burrito007 | Private 'For Sale' Classifieds | 1 | 05-02-2005 02:09 AM |
