03-18-2014, 07:31 PM | #4076 |
Member#: 307892
Vehicle:2012 Imp DGM |
My JDM reverse light plasmas came in on Monday. I'm waiting for my turn signals to arrive before installing, but plan on seeing if they will fit in at least the rear side marker slots that I have amazon $2.99 specials in now.
03-18-2014, 07:50 PM | #4077 | |
Member#: 348055
Vehicle:2013 Impreza 5MT ISM |
Wish I had some sort of local connection for this sort of thing. |
03-19-2014, 02:42 AM | #4078 |
Member#: 372528
SWIC
Vehicle:2013 Impreza Sport White |
One of this links should work... They are all the same picture...
http://s100.photobucket.com/user/els...G1920.jpg.html http://i100.photobucket.com/albums/m...o/IMAG1920.jpg <a href="http://s100.photobucket.com/user/elsecomojado/media/IMAG1920.jpg.html" target="_blank"><img src="http://i100.photobucket.com/albums/m38/elsecomojado/IMAG1920.jpg" border="0" alt=" photo IMAG1920.jpg"/></a> What do you guys think, this is home made, right in my garage, is my new prototype of muffler delete. |
03-19-2014, 03:08 AM | #4079 |
Member#: 385031
I am not very sure about it and help you to find out later there.Thank you
03-19-2014, 08:02 AM | #4080 | |
Member#: 380534
Vehicle:2014 XV Crosstrek orange |
03-19-2014, 12:05 PM | #4081 | |
Member#: 373442
Vehicle:2013 Impreza GJ |
How difficult was the application? |
03-19-2014, 07:15 PM | #4082 |
Member#: 345444
Vehicle:2013 Impreza 5-door White |
have you guys changed out reverse lights into something that actually looks bright BUT also outputs?
i have LEDs in mine and they look great, like a super bright square when i back up, however, it doesn't actually help me see. i don't really care, but if there was an option to put something in that looked good and worked, i would buy it. i saw the LED bulbs that have the leds on the sides, as well as a projector on the end ... wondering if any of you guys tried those. also, is the plasma bulb from jdmtoy the brightest you guys have seen that fits? (i don't like anything above 6k, but at 5-6k is fine) http://store.ijdmtoy.com/mobile/Prod...ode=T15_SKU326 lastly, i put yellow overlays on my fogs, and then i put a regular white LED bulb in, hoping that it would look yellow when on. well, instead, it gives it a light yellow with a green tint look. did any of you achieve yellow fogs using just a bulb? i wasn't able to find a yellow bulb. i only found amber LED bulbs for the fogs. Last edited by tspunk; 03-19-2014 at 07:24 PM. |
03-19-2014, 08:00 PM | #4083 | |
Member#: 329271
South East
Vehicle:2012 Impreza Limited Ice Silver Metallic |
03-19-2014, 08:13 PM | #4084 | |
Member#: 345444
and since you're on, would you happen to know if i can put an LED 9005 bulb into my DRLs? I don't ever use the high beam, but I don't know what that would do... what if I put a 9005 LED bulb in, and then flicked my high beam? |
03-19-2014, 10:32 PM | #4085 |
Member#: 345877
Vehicle:2013 Impreza Sport Ice Silver |
Since they're 9005 LED high beams, I would have to assume they would come on just like halogen 9005's.
I have LED's in my fogs. They come on just like halogen fogs. They're just not very bright. They sure do look better than the stock bulbs though. I plan on doing the H11 fog conversion come spring. |
03-20-2014, 11:28 AM | #4086 | |
Member#: 337144
International
Vehicle:2012 Impreza Hatch Ice Silver |
ehh not sure on this, looks ok, tips are way too small, heres mine if you havent seen this around |
03-20-2014, 02:52 PM | #4087 |
Member#: 372528
SWIC
Wow, your car looks awesome. I guess the size of the tips depends from person to person. My car is not highly modified like yours so, I think it would just look funny. Did you cut the plastic all the way through the bottom? Do you have a close up from the bottom? if I may ask.
03-20-2014, 02:58 PM | #4088 |
Member#: 345877
I basically have what Dijm8 has, but on only the right side. I don't have duals. I had them try a few different size tips, and the smaller ones just looked weird.
03-20-2014, 06:31 PM | #4089 |
Member#: 307892
Anyone know a good spot to tap into for lighting under the dash or under the hood? I have some led strips from my quadcopter that will work great and ideally want to tie into the dome light's circuit
03-20-2014, 07:40 PM | #4090 | |
Member#: 337144
International
03-20-2014, 09:01 PM | #4091 |
Member#: 348055
Disgusting... By disgusting I mean... Awesome.
03-20-2014, 09:19 PM | #4092 |
Member#: 380534
I imagine you run that much negitive camber because of the ride height...or visa versa. You must get about 2K miles out of a set fo rear tires, and I know the handling of the car constantly detereorites the whole time. There is low and slow...and low and fast. I personally prefer the latter.
Love the exhaust, just not a fan of the stance. |
03-21-2014, 01:04 AM | #4093 |
Member#: 317244
Vehicle:12 Impreza White |
03-21-2014, 11:56 AM | #4094 |
Member#: 337144
International
03-21-2014, 02:03 PM | #4095 |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
03-21-2014, 02:15 PM | #4096 |
Member#: 372100
Vehicle:2013 Premium 5dr CVT DGM |
03-21-2014, 06:30 PM | #4097 |
Member#: 345877
I know when the Nitto Neo-Gen came out it was touted as being "optimized" for lowered vehicles. Not sure how. But that'll probably be next.
03-21-2014, 08:38 PM | #4098 |
Member#: 380534
that rear tire probably has less than 500 miles on it, and it's already showimg different wear patterns inside to outside. Soon, you'll start to get excessive "tramlining", the car will follow every crack and expansion joint in the road. Handling will rapidly deteriorite, but you'll still look cool...right up until the tire EXPLODES.
I can only imagine what the steering axle looks like. It's a cool look, but not safe, or sustainable. If your just too low...can't get the right parts to get the alignment specs anywhere near acceptable, well then you have to decide. If you are simply chasing the "look", then your good. If your chasing the max on road handling performance the impreza can have, then you need to re-evaluate your ride height. I've seen many go down this path...albiet with a different platform. Vanity is a cruel bitch, and you alone suffer the consequences. A high quality handling car returns benefits every time you get behind the wheel...but not every one who witnesses those drives, appreciates what you have done. A simple and slight bump up in ride height...might bring the car back to a more driver friendly status...I don't know. From other experiences I can honestly tell you, a well balanced, properly aligned, performance tire eqpt car...can reap rewards for the driver every mile. That my friend is infinately more important to me, than what any stranger thinks of my ride. just saying................ |
03-22-2014, 01:34 PM | #4099 | |
Member#: 372528
SWIC
03-22-2014, 03:08 PM | #4100 | |
Member#: 334099
Vehicle:2012 Sport Premium Dark Gray Metallic |
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? | somebody else | Southern California Impreza Club Forum -- SCIC | 3 | 12-23-2015 04:34 AM |
factory SS or aftermarket for 2012??? | Myth21 | Transmission (AT/MT) & Driveline | 8 | 01-07-2012 11:18 AM |
Has anyone test drive a 2012 Impreza yet? | pRiMe DiReCtIvE | General Community | 25 | 11-28-2011 10:03 PM |
Hybrid Impreza in the works for 2012? | rsholland | News & Rumors | 43 | 03-12-2010 10:58 PM |
