Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Vancouver Impreza Club
Old 06-09-2007, 01:12 AM   #1
ShawnRS
Member#: 18797
MY06 WRX Wagon
Question pinch weld adapter for jacking
Hi all
Has anyone seen pinch weld adapter (like in the OEM jack) for a floor jack in a store up here? I have asked at lordco but the guy told me to buy floor jacks etc.
All I want to do is make rotating my tires easier, safely, without putting the car on stands.
The wore out my OEM jack on the last car I had.
Shawnrs
ShawnRS is offline   Reply With Quote
Old 06-09-2007, 02:49 AM   #2
Picard
Member#: 100204
2006 STI (retired)
I have a floor jack, but I don't use the pinch welds at all. I use two other spots in the front to lift the car. I know you're not supposed to leave the car on the floor jack when you rotate tires, but I do it (I've got a 3-ton jack). If I use the front jack plate, then I could put jack stands in the other spots.
I haven't really looked for spots in the rear. If you read this thread, someone mentions getting something at Sears:
http://www.iwsti.com/forums/showthre...highlight=jack
Picard is offline   Reply With Quote
Old 06-09-2007, 03:39 PM   #3
jonney_boy
Member#: 28747
06 WRX
I've made my own out of wood for home use.. BUT.. i've heard that you can just cut a slit in a hockey puck and it would work well...
Otherwise... look online... they are fairly common.
jonney_boy is offline   Reply With Quote
Old 06-09-2007, 04:17 PM   #4
alan ling
Member#: 5233
The hockey puck idea is great. Never thought of that!
alan ling is offline   Reply With Quote
Old 06-09-2007, 07:31 PM   #5
Phot3k
Member#: 85001
2005 Impreza 2.5RS
Crystal Gray Metallic
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
I've been contemplating either getting this adapter or making my own out of wood since it's $20.00 not including shipping for the one listed above. Still strange that Lordco doesn't carry it but it's not the first time someone's asked them.
Phot3k is offline   Reply With Quote
Old 06-09-2007, 10:36 PM   #6
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD) / 87 GL
why don't you just get a floorjack and jack it up on the rear diff and front xmember plate??? then use jack stands on the pinch welds...?
if you REALLY want to jack up on the pinch welds (which i really don't see a point in doing if you're just swapping tires) then get a hockey puck and go nuts with a saw on it until it fits nicely... or just jack it up without anything on the pinch welds...
Zefy is offline   Reply With Quote
Old 06-11-2007, 12:10 AM   #7
ShawnRS
Member#: 18797
MY06 WRX Wagon
To me, lifting at the OEM Emgerency jack lift points is safer than balancing half of the car on the diff or that other front spot (behind the oil pan), when it comes to rotating my tires.
Anyway thanks for the ideas and I'll have a look at sears.
Shawnrs
Old 06-11-2007, 02:31 AM   #8
Picard
Member#: 100204
2006 STI (retired)
The spot in the front that I use the floor jack is part of the frame just inside of the pinch welds on either side of the vehicle. There's a bolt that I use as a marker.
Old 06-11-2007, 03:40 AM   #9
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
Shawnrs
it is perfectly safe to do... i wouldn't go under the car like that, but it's safe... when i change the tires i'll typically throw one of the extra wheels and tires under the side of the car after i lift it up... if the car falls, it's gonna fall on a wheel and not on the ground... that is a good option if you can't be bothered with jack stands like me...
jacking up on the diff or front xmember is more stable than it looks! plus you can change 2 tires at a time saving time and effort...
Old 06-11-2007, 05:51 AM   #10
Bar-F1
Member#: 15686
04 EK->E30->STi
I use hockey pucks. I didn't cut a slot into it though, but the weld is still holding up nicely. My jacks are too thick to reach the front subframe, so I get two small jacks and lift the whole side up. I don't have to run around the car this way too.
Bar-F1 is offline   Reply With Quote
Someone want to make pinch weld jack adapters? chimchimm5 Service & Maintenance 13 01-31-2010 01:04 PM
Safe to jack up car anywhere along pinch weld? shemoves Service & Maintenance 2 06-08-2009 09:46 AM
Pinch weld jack adaptor with side skirts? veener79 Service & Maintenance 6 03-22-2009 09:12 PM
Bent OEM pinch weld jack point. seattleswimboy Service & Maintenance 10 11-11-2006 10:40 AM
transmission jack adapter for regular hydraulic jack? annointed Transmission (AT/MT) & Driveline 5 08-26-2003 01:42 AM
