05-31-2001, 09:31 AM | #1 |
Member#: 3846
Vehicle:2001 2.5 RS Silverthorne |
towing with an rs coupe
Is it possible to tow a light trailer with a motorcycle on it with my rs coupe? I want to haul the bike to PA from CA. The trailer is 4x8 and weighs less than the motorcycle.
05-31-2001, 09:38 AM | #2 |
Member#: 1994
Vehicle:2018 STI WRB |
the RS can tow ~1000lbs I think. It should be ok.
05-31-2001, 09:49 AM | #3 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
05-31-2001, 01:51 PM | #4 |
Member#: 5769
Vehicle:'09 WRX Prem 5-dr Dark Gray |
Absolutely, check your manual. '01 and earlier Imprezas can't tow as much as other Subarus. Also, be aware that Subaru has restrictions on trailers without brakes. My guess is, if your trailer doesn't have brakes, you're restricted to 750 lbs. or less. The manual will tell you for sure.
Bob |
05-31-2001, 03:38 PM | #5 |
Member#: 1217
Vehicle:2005 9-2X Artic Silver |
I towed a dirtbike with the RS, 2dr 5-speed, no problem. I use my WRX now to haul a dirtbike.
Later |
06-01-2001, 12:19 AM | #6 |
Member#: 3409
NWIC
Vehicle:98 My FMIC Is bigger than yours. |
Waiting to hear from McDade about the whole phantom entry stating not to push start your Subaru, I read the entire owner's manual (excluding the climate control/radio sections) last night.
RS can two up to 700 lbs without trailer brakes. Add brakes and the max loaded trailer weight goes up to 1500lbs with no more than 25 square feet of frontal area. A simple open-air bike trailer with a single bike would be fine. hint: Owner's manual understates things to avoid potential lawsuits by people exceding the limits. ('70 Boss 302 had a 6k something rev limiter to keep the accessories from blowing up, not the motor itself.) |
06-01-2001, 06:50 AM | #7 |
Member#: 3846
thanks everyone for all your help. I read the manual and suspected that it was on the low side. The bike weighs just a little over 4000 lbs. and the trailer is around 325 so everything should be just fine! thanks again
06-01-2001, 06:54 AM | #8 |
Member#: 2817
Vehicle:2001 Impreza 2.5RS BRP |
Wow! Your bike weighs 4000lb!?!?!?
06-01-2001, 07:26 AM | #9 |
Member#: 419
Vehicle:2002 WRX |
I tow a Honda XR600 dirt bike on a steal 4x8 trailer with my Outback Sedan and I don't have any problems. I got a bolt on Hitch from Drawtite and had a local installer wire the lights. I would think your RS could pull it just as good as my car because we have the same HP and torque. You might feel it back their a little more because of the lighter weight of your car.
Good Luck! Mike |
06-01-2001, 08:09 AM | #10 |
Member#: 632
Vehicle:'12 Cayman R '17 Macan GTS |
Is the towing capacity not 2000lbs? I swear I read that before. I tow my sled around all winter up north, through the mountains, etc. with not one realted problem yet. As a matter of fact the RS easily out-towed a Suburban (with 3 sleds vs. my one) up the mountains on two different occasions. The sled is about 475lbs, plus the 4x8 steel trailer. YMMV (as for me, I have 8k miles plus with the sled on back)
Christian |
06-01-2001, 09:45 AM | #11 |
Member#: 3846
oops that is supposed to read 400. oh well!
06-01-2001, 10:52 AM | #12 | |
Member#: 935
Vehicle:Will Woollard Fan Club |
06-01-2001, 11:16 AM | #13 |
Member#: 3409
NWIC
2001 Impreza&Outback Sport owner's manual. Page 7-50, 1/2 way down under the big caution box.
"Total trailer weight (trailer weight plus it's cargo weight) must never exceed 1,500 lbs (681 kg)." Why don't you guys believe me when I say I read the entire manual? Also.. max tongue weight is 150 lbs. They recommend a 60/40 front/rear weight distribution on the trailer. Total vehicle weight including trailer, cargo, driver, passengers, and optional equipment should never exceed the GVWR (Gross vehicle weight rating). |
06-01-2001, 04:19 PM | #14 |
Member#: 741
Vehicle:2010 Outback Dirt Green |
I moved from NJ to California with about 1000lbs of trailer and junk attached. Being honest and objective, my '00RS had no problem pulling the trailer up hills or from a standing stop. Even going around tight turns, the RS didn't seem to mind having 1000lbs of baggage dragging behind it. And for comparison, my last car (96 Z24) felt slower with 5 people in it, than the RS towing that trailer! (Z24 went a best of 14.9 1/4)
The best part of the trip was visiting the grand canyon. |
06-01-2001, 09:18 PM | #15 |
Member#: 2609
Vehicle:98 BK-GT White '97 SVX Ebony Pearl |
Greg, WOW! NJ to SLO-town! Congratulations and welcome to San Luis Obispo from a "native"!
<FONT face="Comic Sans MS">Glenn O</FONT f> |
Towing with an '06 Wagon. | colin edge | Brakes, Steering & Suspension | 2 | 07-12-2007 12:22 AM |
Towing with an STI | booch70 | General Community | 85 | 04-02-2007 10:18 AM |
need an rs coupe wing for my 2000 rs | sekretskwirl | Private 'For Sale' Classifieds | 1 | 04-14-2006 05:28 AM |
anyone have pictures of a legacy with an RS coupe wing? | Fitz | Interior & Exterior Modification | 8 | 03-07-2001 10:28 AM |
Towing with an OBS... | Foxbat | General Forum Archive | 3 | 01-20-2001 12:49 AM |
