01-28-2008, 03:41 PM | #1 |
Member#: 47145
MWSOC
Vehicle:2012 Gas Saver |
DataLogLab RoadDyno Enginuity Definition.
For those using DataLogLab for road dynoing here is my latest definitions using Enginuity's latest Logger Definitions.
Its now setup to display 'Manifold Relative Pressure (Direct)* (psi relative sea level)', 'Engine Load (Direct)* (g/rev)', 'Knock Correction Advance (degrees)', & 'LC-1 (AFR)' although the LC-1 Enginuity datalog column name may have changed since the last revision to the enginuity logger definitions. Just change the ColumnTitle=, the file should be put in: C:\Program Files\DataLogLab\Universal Data Log Formats\Enginuity_WRX_DataLogDefinition.txt On DLL: Under Customize>Options>File Locations & Power Graph> Path & File Name of Univ. Data Log Defintion File. Find the file, Click Load. If you don't like the 'Knock Correction Advance (degrees)' simply change the ColumTitle= to FLKC or FBKC as it is displayed in the datalog. You may have to change the conversion factor as well to get it in the viewable area of the graph. Code:
[DataLogDefinition] Name=Enginuity WRX FileExtension=csv DelimiterAsciiCharacter=44 [Column] Name=Time Description=Time ColumnTitle=Time DataItemID=63 Type=1 ColumnDecimalPlaces=3 Offset=0 ConversionFactor=0.001 DisplayDecimalPlaces=3 DisplayColour=630000 DisplayLineWidth=3 DisplayLineStyle=1 [Column] Name=Boost*100 Description=Boost ColumnTitle=Manifold Relative Pressure (Direct)* (psi relative sea level) DataItemID=37 Type=1 ColumnDecimalPlaces=2 Offset=0 ConversionFactor=10.0 DisplayDecimalPlaces=2 DisplayColour=630000 DisplayLineWidth=3 DisplayLineStyle=1 [Column] Name=Load*1000 Description=Load ColumnTitle=Engine Load (Direct)* (g/rev) DataItemID=76 Type=1 ColumnDecimalPlaces=3 Offset=0 ConversionFactor=1000.00 DisplayDecimalPlaces=2 DisplayColour=630000 DisplayLineWidth=3 DisplayLineStyle=1 [Column] Name=Knock Correction*100 Description=Knock Correction ColumnTitle=Knock Correction Advance (degrees) DataItemID=62 Type=1 ColumnDecimalPlaces=1 Offset=0 ConversionFactor=100.00 DisplayDecimalPlaces=2 DisplayColour=630000 DisplayLineWidth=3 DisplayLineStyle=1 [Column] Name=AFR*10 Description=AFR ColumnTitle=LC-1 (AFR) DataItemID=36 Type=1 ColumnDecimalPlaces=2 Offset=0 ConversionFactor=10.00 DisplayDecimalPlaces=2 DisplayColour=630000 DisplayLineWidth=3 DisplayLineStyle=1 [Column] Name=Engine Speed/10 Description=Engine Speed/10 ColumnTitle=Engine Speed (rpm) DataItemID=3 Type=1 ColumnDecimalPlaces=0 Offset=0 ConversionFactor=1 DisplayDecimalPlaces=0 DisplayFactor=0 DisplayColour=4227072 DisplayLineWidth=3 DisplayLineStyle=1 |
01-28-2008, 05:23 PM | #2 |
Member#: 103320
Vehicle:1998 swapped Forester L |
thank you for posting this. back when I was looking for it, I had to register on a puerto rican forum just to get the DL link.
01-28-2008, 05:33 PM | #3 |
Member#: 47145
MWSOC
no problem, I've had several requests here recently for the definition file. Figured I'd just post it up.
05-10-2008, 10:19 AM | #4 |
Member#: 164128
MWSOC
Vehicle:2004 STi WRB |
None of the values from my log seem to be showing up? Any suggestions?
05-10-2008, 03:16 PM | #5 |
Member#: 47145
MWSOC
05-10-2008, 06:59 PM | #6 |
Member#: 164128
MWSOC
Yes, not absolute in the logger. I did another log yesterday and used that and it now seems to work. I've noticed that when Enginuity logs sometimes it doesn't fully log what is going on every time. Thanks for your help!
05-10-2008, 05:17 PM | #7 |
Member#: 171344
Vehicle:2006 STi Wagon Black HTA Green |
Have any opinions on the accuracy of DataLogLab vs Mick's spreadsheet dyno? |
05-16-2008, 04:41 AM | #8 |
Member#: 91093
TXIC
Vehicle:2002 Wrx |
I tried to use several logs old and new but when i hit draw its just a flat line, and i did select values on the left to include but it doesnt look like anything. I looked and its not set for absolute time.
12-19-2008, 08:21 PM | #9 |
Member#: 197637
SCIC
Vehicle:2006 Evo IX Silver |
You must make the txt definition file compatible with your log. The column title in the txt file must be the same as the column title in your log.
04-03-2009, 01:46 AM | #10 |
Member#: 204111
RMIC
Vehicle:2005 WRX |
I know I'm a noob and I'm sorry but all I can get to display looks like this:
http://i4.photobucket.com/albums/y10...e/Picture1.png What am I doing wrong? |
05-16-2008, 09:22 AM | #11 |
Member#: 47145
MWSOC
^post up a bit of the log in [code] brackets.
12-17-2008, 05:25 PM | #12 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
is this program worth the money if we're already good with airboys sheet?
12-17-2008, 06:05 PM | #13 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
I tried some logs back to back in both the spreadsheet and dataloglab and got the same numbers. Dataloglab is nice for comparing different runs and stuff though.
You should be able to download a 30 day eval. |
04-06-2009, 06:33 PM | #14 |
Member#: 189660
MAIC
Vehicle:'02 WRX Element Tuning Race Team |
Ok, I couldn't get this to work at all. I successfully loaded what you put in the first post, but I can't get the program to recognize the car. It's an '05 STI. Is there something special you have to do (like in RomRaider when you have to select COM4)?
04-06-2009, 08:59 PM | #15 |
Member#: 47145
MWSOC
you need to open the romraider generate .csv file.
04-06-2009, 09:28 PM | #16 |
Member#: 189660
MAIC
ahhhh that would make sense now.
i'll try it tomorrow. |
Similar Threads | ||||
GT3076 airboy roaddyno 24psi...E85 | TDagen | Proven Power Bragging | 31 | 04-08-2018 10:52 AM |
DatalogLab worth the cost? | jblaine | Engine Management & Tuning | 0 | 09-22-2005 06:46 PM |
DataLogLab adds 3.6 to my boost | NavyBlueSubaru | Engine Management & Tuning | 7 | 04-09-2005 10:48 PM |
Dataloglab Compatability with Tuna WB02 | NavyBlueSubaru | Engine Management & Tuning | 2 | 05-17-2004 05:08 PM |
300+WHP measured by dataloglab | NavyBlueSubaru | Proven Power Bragging | 48 | 09-02-2003 02:06 PM |
