07-19-2003, 01:38 PM | #1 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
What Cars Came With A Rear LSD?
Since the FAQ was getting huge with my single question posts, I figured I would do a different format and create a new thread. I'm poking around in the FSM's, and while they give a LOT of information, there are a few holes as to which models actually had the LSD. Please feel free to correct me if I have made an error.
Unless specified, the LSD uses male axles and is a viscous coupling unit. Impreza: 2000-2001 2.5RS 5MT, 4.111 2000-2001 2.5RS 4EAT, 4.444 2002+ WRX 5MT, 3.545, 2002+ WRX 4EAT, 4.111 2004 WRX STi 6MT, 3.900, mechanical SVX: 1992-1997 AWD 4EAT, 3.545 final drive, has axle stubs Legacy: 1991-1992 Turbo 5MT (Sedan only?), 3.900 final drive, has axle stubs 2000 GT, GT-LTD, Outback-CW, Outback-LTD, Outback-SDN (excluding Outback, Brighton, and L) 2001+ 2.5L (Excluding Brighton and L) 5MT, 4.111 2001+ 2.5L (Excluding Brighton and L) 4EAT, 4.444 2002+ 3.0L (H6) Outback and Outback-SDN 5MT, 4.111 2003+ Baja, see Legacy specifications Forester 2000-2002 Forester S 5MT, 4.111 2000-2002 Forester S 4EAT, 4.444 2003+ with Disc Brakes 5MT, 4.111 2003+ with Disc Brakes 4EAT, 4.444 2004 XT Turbo 5MT and 4EAT, 4.444 -Jon
06-03-2004, 10:05 PM | #2 |
Member#: 38120
South East
Vehicle:1991 Rio Red Legacy Turbo |
My '91 Legacy Turbo 4EAT has a 3.900 LSD.
I don't believe it was just 5MTs that had 'em. |
06-03-2004, 10:38 PM | #3 |
Member#: 2279
South East
Vehicle:2000 Slingshot Pastelito Racing |
That is correct, the 4EAT 91 Leg T's came with the rear LSD as well.
06-04-2004, 07:44 AM | #4 |
Member#: 13793
Vehicle:2007 specB, 03 Ram '92 SVX-5 speed |
Modification required.
No stubs on the SVX rear VLSD diffs.
Todd |
06-04-2004, 11:10 AM | #5 | |
Member#: 177
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
the svx and STI rear diffs are r180s
the xt6 also used a r160 with a 3.70 ratio |
06-05-2004, 09:10 PM | #6 |
Member#: 22345
Vehicle:2003 RSX black |
will the r180 from the svx/STI bolt into the gc8? (disregarding the gear ratios)
06-05-2004, 10:18 PM | #7 |
Member#: 177
i dunno
diffs don't bolt directly to the sub frame so if you had the right bracketry ... yeah i guess? |
06-06-2004, 11:11 AM | #8 |
Member#: 50488
Vehicle:1999 GC8 ej20g! Black |
91' Legacy RS used 4.111 rear LSD (Jap Spec)
06-06-2004, 11:12 AM | #9 |
Member#: 50488
And you can also add 92-94 Liberty/Legacy RS and RS-RA to the list
... Also...didnt the 1999 Impreza have rear LSD as well? I thought it was the first year, because my car certainly does, and I never switched out the rear end. Unless the owner before me did. |
06-06-2004, 01:11 PM | #10 |
Member#: 59118
Vehicle:2016 WRX Pure Red |
02 RS 2.5 have it?
06-06-2004, 02:48 PM | #11 | |
Member#: 3313
The 99 Impreza 2.5RS's had it, I thought. I was pretty sure just the 98's didn't, for that body style. Neil |
06-06-2004, 06:12 PM | #12 |
Member#: 22345
whats the deal with the stub axels/no stub axels thing? are they not compatable?
06-06-2004, 11:51 PM | #13 | |
n00b Moderator
Moderator Member#: 811
Vehicle:2000 RS-Ej20G It tastes like burning |
06-07-2004, 02:34 PM | #14 |
Homicidal Maniac
Vehicle:2008 STI |
Lemme see if I remember.
Many of the late model axles have a male end that inserts into the rear differential. Some of the older models required axle stubs because the axles themselves did not have a male end. The axles were a flange type kind of similar to the front axles (but not really). For this to work, the rear differential requires a 3-4" long axle stub to which the axle will mount to. -Jon |
06-08-2004, 01:28 AM | #15 |
Member#: 22345
anyone know if the wrx lsd is compatible with the older impreza L rear ends (as far as mounting goes, not the actual gear ratios)
06-08-2004, 08:06 AM | #16 | |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
You'll have to either source newer axles or take the stubs from your current diff and insert them into the LSD first. Also, you'll have to do some minor clearance grinding inside the older housing to fit the (slightly larger) LSD in place. There is some good info in the drivetrain forum by Joel Gat regarding the swappage and fitment issues of LSD's, both OEM and aftermarket. It's my understanding that with the older diffs, you can remove the stubs and then use newer type axles. (without taking the ring gear into consideration) Jay Storm |
06-08-2004, 09:51 PM | #17 |
Member#: 22345
so i can source a wrx lsd rear end (complete), then i can make it work with that and just inserting my old impreza L stub axels into it, then using my existing axels.
i'd like to keep my existing axels if possible. thanks for the info |
06-09-2004, 02:18 AM | #18 |
Member#: 25808
SCIC
Vehicle:2003 Impreza RS STI---->Prodrive |
So what is it on my 2003 Impreza 2.5 Sedan?
Is it just an AWD or something like central differential XXX Do it function totally different with the LSD?? WOud u mind explaining it to me?? Thanks! |
06-09-2004, 09:53 AM | #19 |
Member#: 2279
South East
2001 was the last model the RS (2.5) came with a rear LSD. It's open, in other words, it doesn't compensate for power differences between the rear wheels, same goes for the front one.
06-09-2004, 11:12 PM | #20 |
Member#: 56676
Vehicle:1996 Impreza "Brighton" Hunter Green |
How can you tell if you have an LSD differential with out opening it up? I have one that is supposed to be from an 02 WRX. I'd like to know that I didn't get cheated.
06-12-2004, 12:44 AM | #21 |
Member#: 22345
something i ran upon:
http://kmhafer.datsun510.com/Subaru.htm Clutch-Pack LSD: 1985-1986 (production up to 3/86) XT 4WD is listed with a 3.70 LSD option (Subaru part # 7220 11000). 1986-1987 (production from 4/86-10/86) GL 4WD is listed with a 3.70 LSD option (Subaru part # 7220 11001). 1986-1991+ (production from 11/86) Loyale/GL 4WD is listed with a 3.70 LSD option (Subaru part # 7220 11002). 1988-1991 GL and XT-6 4WDs with single range transmissions are listed with a 3.90 LSD option (Subaru part # 22011 GA022). |
06-12-2004, 12:45 AM | #22 | |
Member#: 22345
06-12-2004, 12:58 AM | #23 |
Member#: 8069
South East
Vehicle:2016 Fiesta ST Kona Blue |
yep.. agree w/ sick1.8t... the 86 GL10 Turbo my friend has the the above mentioned LSD (almost positive it was standard on the GL10T).
07-04-2004, 02:43 AM | #24 |
Member#: 22345
a sube tech at a dealership said that the svx rear end wont directly bolt into the rear of an impreza. i'm not sure if he also ment the axels are the wrong length or if its just the housing wont fit into the existing bracketry. anyone have any info on this? i was under the impression that all newer rear ends would bolt into the impreza, set aside the whole stub axle thing.
and is the svx rear really a R180? |
07-04-2004, 10:24 AM | #25 |
Member#: 177
i believe so ..
Similar Threads | ||||
'02 WRX 6 spd STI Conversion with r180 rear LSD & DSS (Drive Shaft Shop) Rear CVs | nissaneng | Transmission (AT/MT) & Driveline | 16 | 03-17-2010 01:39 AM |
Car came with intake, what AP options do I have? | ST3 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 04-02-2006 12:25 AM |
4.11 Tranny with Matching Rear LSD Diff | JoeT | Private 'For Sale' Classifieds | 17 | 02-10-2005 04:31 PM |
Are the painted side skirts the same size as the plastic ones that my car came with? | RyanRock | Interior & Exterior Modification | 5 | 05-13-2004 06:33 PM |
I wish my car came with a hand gun accessory | Stroke | Off-Topic | 9 | 09-05-2003 12:55 PM |
