Welcome to the North American Subaru Impreza Owners Club Tuesday April 2, 2024
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 03-01-2010, 10:40 PM   #1
hkssubbie02
Member#: 146863
2004 STI
jbp 98 fozzy
Default need coilover setup
looking to go coilovers on my 04 sti. the stock struts have about had it
looking to spend around a g. mostly street use but i would like to start doing some autocross. any suggestions. any places to get some good deals.
hkssubbie02 is offline   Reply With Quote
Old 03-02-2010, 12:03 AM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Go to the Suspension Technical Forum. Awesome advice in there... too bad no one ever reads it.
EDIT: Copied from my post below after the thread went off-topic.
OP, here are some options you have at your disposal and the approximate pricing:
OPTIONS:
1) BC Coilovers - Dampening/Rebound, spring rate (?) and height adjustable - ~$1000
2) Pair a dampener with a spring setup - Dampening/Rebound and height adjustable
2.1) Struts/Dampener - For this you have a few options, but the only two that really stand out are Tokico D-spec Struts or Koni Yellow Inserts. Both have adjustable Dampening/Rebound and both have superior valving to many cheaper coilover setups. The Koni's are the better option of the two with valving comparable to coilovers in excess of $18xx.xx. The D-specs run $540 and the Koni's run $620-700
2.2) Springs - For this you really have two options as well: Springs or a Ground Control Sleeve setup. With the springs you have a TON of options to choose both rates and height. You can get progressive or linear. Personally, I really prefer the RCE Yellows if you go this route. The Ground Control setup is even more versatile as it gives you a huge variety of spring rates and lengths and the system allows for height adjustment as well. The advantage to the GC setup is that springs are cheap and easily changed to suit your needs. This is an insanely popular autocross setup. Springs run $200-350 (buy em used for maximum saving) and the GC setup runs ~$400
Those are your options. I've personally worked on a variety of setups, but have extensively used Tokico D-specs with RCE springs. They are a great bang for your buck. I've gotten many compliments on how they perform as well as their refined comfortable nature. No bumps or rattles at all.
My new setup I'm building will utilize Koni Yellow Inserts in STi housings with a Ground Control Sleeve system. I just need to select my rates now.
Good luck and send me a PM if you have any more questions.
Old 03-02-2010, 12:18 AM   #3
Evil Imports
Member#: 14732
I can get you BC or megans, i personally like the BCs a little better
Evil Imports is offline   Reply With Quote
Old 03-02-2010, 03:42 PM   #4
KevnKel
Member#: 165886
2008 Impreza WRX
Blue Mica
Megans FTW
KevnKel is offline   Reply With Quote
Old 03-02-2010, 05:26 PM   #5
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
BC>>>>>Megan, i just got the bc ram models, they are very sweet. the br series will be sweet for street use and fully adjustable as well. pm evil he will take care of you, he is a good guy
SubeSTIle is offline   Reply With Quote
Old 03-02-2010, 06:24 PM   #6
FATgc8
Member#: 98838
2005 STi
CGM
BC makes Megan coilovers... If I were you I would save up a little more and try to find a slightly used set of rce tarmac zeros. They are the best coilover set up for DD IMO.
FATgc8 is offline   Reply With Quote
Old 03-02-2010, 06:40 PM   #7
Iron Giant
Member#: 174780
2005 Impreza WRX STi
WR Blue
Good advice ^
Why do you need coilovers anyway? Height adjustment is overrated for most applications, the exceptions being if you want to push the limits of slamming your car, you need to adjust for different seasons (shouldn't be an issue in most of the southwest) or if you need the adjustability for the track (corner balancing comes to mind).
Tarmac 0s, and KW V1s are the cheapest I would personally go. I've had good experiences with H&R on a lot of other cars and they make an 04 setup which I also might give a shot (it should be a little cheaper than the other two and it still uses bilstein dampers).
If you can spend more money, I can't recommend Tarmac 2s or ohlins DFVs enough (I have the latter)...but they're stepping into the $2-3K arena.
Iron Giant is offline   Reply With Quote
Old 03-02-2010, 07:27 PM   #8
kpluiten
Member#: 120273
06 WRBWRXWGN
Originally Posted by Iron Giant View Post
Good advice ^
Also good advice. ^
Old 03-02-2010, 07:28 PM   #9
kpluiten
Member#: 120273
06 WRBWRXWGN
For you (OP) you can run the Tokico D-spec struts and RCE yellows and it will handle VERY VERY well. That's an excellent setup for sure. The D-specs are adjustable to meet your needs and they handle higher spring rates very well.
Old 03-02-2010, 08:07 PM   #10
Evil Imports
Member#: 14732
yes, BC makes megan, but they are not the same
Old 03-02-2010, 08:07 PM   #11
Evil Imports
Member#: 14732
GAY double post
Old 03-03-2010, 10:52 AM   #12
FATgc8
Member#: 98838
2005 STi
CGM
I never said they were the same. All I'm saying is if hes willing to spend a little more he could get a way better coilover setup for his car. I think if people were to drive a set of fully dialed in bc coilovers compared to a set of higher end coilovers like the rce's they would clearly see what the better coilover is. Unfortunately, most enthusiasts now days only care about how slammed there car is and too often don't bother to think about the functionally of them.
Old 03-03-2010, 11:06 AM   #13
Evil Imports
Member#: 14732
Maybe someone should tell Phil from element tuning that his BC coilovers suck
Old 03-03-2010, 12:15 PM   #14
FATgc8
Member#: 98838
2005 STi
CGM
Hmm last time i heard he was running the JIC Custom valved FLT-RS. Regardless, if he happened to change his setup, AND IS RUNNING THE BC stuff im almost positive there not some off the shelf coilovers that a regular customer would buy for there dd sti.
Old 03-03-2010, 12:30 PM   #15
kpluiten
Member#: 120273
06 WRBWRXWGN
It's also a bit of a fallacy to assume that because a driver chooses a part, that it's the best part available or that it's even good. I'm not necessarily knocking BC, but I am saying that you always point to Phil as proof of BC's worth. Some drivers are just plain fast. They can make up for improper suspension setup because they are skilled. I envy these people. These people are very talented, but it does not mean they cannot benefit from a different setup.
Also, is he using the $900 BC's or one of their more expensive sets?
Again, I'm not looking to start fights here, just a discussion.
Old 03-03-2010, 12:38 PM   #16
Evil Imports
Member#: 14732
http://forums.nasioc.com/forums/show...6&postcount=73
Quote from the link, that someone from BC said, also in that thread Phil also posts
"The coilovers that Element Tuning and Topspeed use are the SAME EXACT coilovers that customers can buy and have bought. I know. I provided them personally.
Call them up. Ask them yourself.
They asked for slightly different spring rates, that's it. Valving is OTS. We provide that same service to our customers, as we always have since the beginning."
Old 03-03-2010, 12:46 PM   #17
Evil Imports
Member#: 14732
do you really think someone with a time attack car would rather use a improper suspension and "make up for it" then use something they believe would make them pull better times???
Old 03-03-2010, 12:52 PM   #18
kpluiten
Member#: 120273
06 WRBWRXWGN
I'm not saying he's using the wrong setup at all. It might be perfect for him. But yeah, I guess I am saying people make mistakes all the time. And it's entirely possible that because someone is very talented, it might not affect them to the extent it would a less talented driver.
Because "Phil from Element Tuning uses them" is not justification on whether or not they are a good coilover for the OP.
Phil is also using them on a time attack car right? That's a far cry from what is needed on a street car.
Just saying.
Old 03-03-2010, 01:01 PM   #19
Evil Imports
Member#: 14732
I am making the point, because people come in and say BCs suck (in other words) and i am saying if they do suck, i don't think one of the fastest guys in a subaru would be using them.
My wagon doesn't ride harsh at all, very smooth and is a DD with BCs on it, so is i put RCE zeros on it, my car will ride smoother and handle better as a DD for only $900-1000 more???? thats pretty much what everyone is saying so i just want to make sure i am getting it right
Old 03-03-2010, 02:00 PM   #20
FATgc8
Member#: 98838
2005 STi
CGM
Never said that they sucked, all i said that there are a lot better coilovers out there if your wanted to spend a little more money. Im sure that if money wasn't an issue Phil from element would be using a different set of coilovers like ohlin,motion, etc.
Old 03-03-2010, 02:42 PM   #21
bObby
Member#: 66959
04 STi and E46
M3
Money for Phil probably isnt an issue by the looks of how well put together his car looks. He could've bought Ohlins instead of those CF doors he's got.
bObby is offline   Reply With Quote
Old 03-03-2010, 02:45 PM   #22
kpluiten
Member#: 120273
06 WRBWRXWGN
My main contention with the BC's (and most coilovers in that range) is the lack of bump travel and droop. Both of these are qualities I value a lot in a strut/sprint or coilover setup. This is why I'm taking a different approach. Not everyone agrees though and that's cool.
Old 03-03-2010, 02:47 PM   #23
Evil Imports
Member#: 14732
Old 03-03-2010, 02:54 PM   #24
Evil Imports
Member#: 14732
My main contention with the BC's is the lack of bump travel and droop. Both of these are qualities I value a lot in a strut/sprint or coilover setup. This is why I'm taking a different approach. Not everyone agrees though and that's cool.
i just read that whole thread, LoL even my little one have NEVER had a problem with lack of bump travel and droop, and this is since she was born,
I think that a nice sturt/spring combo is nice for the street, but i don't think my BCs are bad for the steet, My car isn't riding coilovers so i can "slam" it like alot of people, I don't feel anything is wrong with my coilovers, as they aren't Harsh on the steet like most people who has never had them will say. and to even say the road out here aren't good for these coilovers are crazy, living in NJ with pothole and some VERY bad roads, i still didn't think they were harsh like people make them out to be.
Old 03-03-2010, 03:02 PM   #25
FATgc8
Member#: 98838
2005 STi
CGM
Sounds like your happy with YOUR coilover setup and I think that's all that matters. We could go back and forth all day on what setup is the best for dd in the end I personally think that if you could spend the extra cash on some rce zeros they would suit the dd needs a lot better. Not to mention the peace of mind that all rce's coilovers have a lifetime rebuild warranty.
Stance coilover setup ? need help ASAP! racer555 Brakes, Steering & Suspension 0 12-20-2008 01:22 PM
05 STI need Budget Coilover setup, any suggestion? Liam Brakes, Steering & Suspension 7 08-29-2007 12:26 PM
i Need Help For Coilover Setup wanna ride in a sti Newbies & FAQs 5 02-05-2002 07:48 PM
Anyone have the TAS/Bilstein coilover setup (or know about it)? rB5 Brakes, Steering & Suspension 2 07-10-2001 01:37 AM
Anybody know anything about the Tein RA Coilover setup? SilverSuby Brakes, Steering & Suspension 2 05-24-2001 07:18 AM
