06-21-2015, 04:17 PM | #176 |
Member#: 142405
Vehicle:#716 Group5 S10 |
I have to ask - what's the point of using a subaru if you aren't going to use the engine or drivetrain?
06-22-2015, 09:23 PM | #177 |
Member#: 267815
South East
Vehicle:Be in awe dont hate .) |
Well ill take a stab at it.............................
..... I cant speak for all Suby owners but for my 04 STi...which ive owned for over a decade...i absolutely love everything about the car from the squishyness of dash to the superb styling and superior brakes. Cons..........engine............stock engine and built engines are all the same. incoherent garbage by design .( yes yes it displeases me as well but ...is as follows Boxers knock with decent ign timing unless using ethanol which is garbage and i cant even get it here anyways so...........boxers suck without decent ign timing. They will blow up with decent ign timing. Period. Now you can have a $5000 outfront V4 block... thats pretty good. Built like a freakin NASA rocketship. Pure precision. But itll break too...they always do. Despite the 100 people who say otherwise.A LS engine swap is cheap, lighter, will outlast me and you and makes 450 HP on piss gas regardless of knock and keeps on tickin.....compared to a built 2.5 making 450 that is beautiful!!!!Pure glory from the heavens........ But good for 10 passes. Besides if it does break.( LS engine)...parts are cheaper and you have tons of options on parts. Hell I even saved a few hundred pounds ditchin the EJ25 for a 5.7 V8. Not bad id say. My question is...... Why would you want yours to be just like everyone elses?????????? Be the black sheep my friend.........be the black sheep. Lol |
06-30-2015, 12:36 AM | #178 |
Member#: 133949
Vehicle:2004 sti black |
when you turn down the Nissan hub and press it into the bearing what are you guys using for rotors and calipers? or just re use sti rotors ? is the hub the same distance so the sti rotor and caliper still play nice?
07-04-2015, 03:37 PM | #179 | |
Member#: 424018
Vehicle:2003 Silbaru SrX soon to be skull camo |
I've done alot of research and reality is I have more seat time in a simulator than the real thing so I want a modest,reliable 300 - 350hp that I can slam off the limiter that's originally rwd drive intended and parts are dime a dozen and much cheaper than similar subi components. Reality is I love this chassis and I even Kumakubo (the owner of ebisu circuit and team orange) said he loved drifting this chassis, he said it was one of the most effortless cars to drift he had ever driven, I'd imagine largely in part to the rigity of the subaru's chassis I couldn't believe the amount of factory bracing and thickness of sheet metal subaru uses in these and what could be better for a purpose intended rigid chassis rwd drift car? In my opinion the Silbaru SrX http://www.rs25.com/forums/f145/t219...ml#post3314434 I quit my day job and opened a shop "Frankensteins Laboratory" FB page coming soon for weekly updates |
07-04-2015, 03:40 PM | #180 |
Member#: 424018
I'll have to see what's going to be easiest between having a gd hub ,s14 bolt pattern and extra caliper
07-04-2015, 11:26 PM | #181 |
Member#: 267815
South East
Just measure where the depth is on the suby spindle and do the same distance when u mill the 1 mm off the shaft. Stock rotors work just fine. That's the point of using the same lug pattern which the 240s have.
07-05-2015, 12:26 AM | #182 | |
Member#: 424018
Or a 240sx r200? |
07-08-2015, 09:06 PM | #183 |
Member#: 267815
South East
Yep. 350Z diff (R200) 240 spindles turned down and stock rotors work great.
07-08-2015, 10:37 PM | #184 |
Member#: 186766
SWIC
Vehicle:04 WRX Driftaru White & Blue |
350z is larger than 240sx r200. The 93-96 q45 r200 is the same size as a 240sx r200 and has the same output flanges as 350z diff so 350z axles will work. And yeah in terms of axles, the 350z axles have same spline count as s13/s14 so they work in the s14 hubs
07-09-2015, 08:17 AM | #185 |
Member#: 142405
Stock 240 rotors? On STI knuckles or WRX knuckles?
07-09-2015, 12:50 PM | #186 |
Member#: 424018
Here's the difference, you need the stis |
09-14-2016, 01:46 PM | #187 |
Member#: 432831
Vehicle:2004 Impreza Outback White |
what can be done to compensate for the front tires with out thee cv shafts and the wheel bearings
09-14-2016, 01:49 PM | #188 |
Member#: 142405
09-14-2016, 04:44 PM | #189 |
Member#: 432831
I mean by removing the front cv shafts the front tires would bend inwards or just not have the same support. what can be done to fix that
09-14-2016, 06:00 PM | #190 |
Member#: 142405
That's not at all how it works. Maybe this isn't the project for you...
09-15-2016, 09:06 AM | #191 |
Member#: 432831
woah don't put me down like that haha I thought I read that without the CV joints the front end acts up. if I'm wrong that's all the better.
Now covering the wheel bearings how can that be done. I plan on using a Toyota transmission and rear by getting a custom bell housing fabricated to match the ej25 but as its been said the weight ratio would be an issue getting more grip to the back wheels any thoughts on that, or would throwing counter weights in the back work |
09-15-2016, 09:15 AM | #192 |
Member#: 142405
If you go back in the thread, I did a whole post with pictures on how to do the stubs in order to keep your wheel bearings together.
Yeah, even my rally wagon was too light in the rear. It was fun, but I broke axles like it was my job, and it had a stockish NA motor. |
06-30-2017, 01:23 AM | #193 |
Member#: 460200
So how many of the RWD owners here actually daily these cars?
I keep seeing people talking about rear diffs holding up from drifting and rallying, but nobody has outright said "I daily my whip and..." |
06-30-2017, 08:05 AM | #194 |
Member#: 142405
Why would you do this just for a DD? There are so many other nicer, better, faster, more reliable ways to have a RWD DD.
I fully regret wasting the time and money on doing it. The cars aren't set up to be RWD, and they really don't handle well at all. If you really want a RWD Subaru, just find a salvaged BRZ. |
06-30-2017, 08:13 AM | #195 |
Member#: 460200
BR-Z didn't come in a wagon and it's hella uselsss as a daily.
06-30-2017, 08:15 AM | #196 |
Member#: 142405
I daily drive a Corvette, so in my opinion, a BRZ is hella useful as a daily. To each their own.
06-30-2017, 09:21 AM | #197 |
Member#: 460200
Used to DD a CTS-V, now THAT was a practical car.
07-03-2017, 08:58 PM | #198 |
Member#: 449564
So has Anyone done a RWD conversion and kept the 5x100 bolt pattern and used a r200 diff?
07-03-2017, 11:44 PM | #199 |
Member#: 198108
Vehicle:MY98 WRX Blue |
07-04-2017, 12:48 PM | #200 |
Member#: 449564
Taking the RWD vs. AWD discussion to one place (with poll) | Eyeflyistheeye | General Community | 178 | 05-01-2008 12:51 AM |
Would a RWD conversion fix the gearbox issues? | jcl | Transmission (AT/MT) & Driveline | 7 | 03-02-2008 02:48 PM |
LS1 and RWD conversion on a Honda Prelude.... | SilverBoosted | Off-Topic | 31 | 07-31-2006 05:58 PM |
What are the main differences in these 2 technologies for a 2wd / rwd conversion? | dawoniyi | Transmission (AT/MT) & Driveline | 1 | 04-21-2006 11:40 AM |
front diff/ rear diff/ and RWD conversion | supermoose | Subaru Conversions | 5 | 09-08-2003 05:16 PM |
