Tire & Wheel Forum sponsored by The Tire Rack |
06-15-2015, 05:09 PM | #1826 |
Member#: 402344
Vehicle:2009 WRX Stage 2 Satin White Pearl |
I want help! First post in here so bare with me. My stock rims are beat up and I'm in need of new tires soon so I was thinking of getting a tire / rim package at the same time to make it easier. I don't have any suspension mods done and I don't plan on doing any either. I plan on going Stage 2 with my 2009 wrx but after that nothing further. Interested in a combination of show/functionality.
I love the Enkei Kojin's. What would be the ideal tire size for no modification and a decent ride. 225/40/18? The one part that confuses me is the offset. Thanks in advance. My budget is about $1500 for tires/rims. I'm thinking of getting 18s when I pull the trigger unless anyone has any reason why I should stick with 17s.
06-15-2015, 05:55 PM | #1827 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
You have a lot of research to do.
06-15-2015, 06:27 PM | #1828 |
Member#: 402344
Alright, thanks.
06-15-2015, 07:08 PM | #1829 |
Member#: 363640
NESIC
Vehicle:2010 WRX SWP |
That's the great thing about this post, you can go back and check out everyone's specs and pictures to see what you like. Are you looking for something more performance oriented (wider wheel with more tire) or something more showy (larger wheel with less tire)? I have had a couple of set ups, my first was an 18x8 +48 wheel with a 225/40/18 tire. It looked good but seemed to ride very hard on that tire. My current set up is a 17x9 +42 with a 245/40/17 tire. I don't think I will ever change from this size set up. |
06-15-2015, 11:10 PM | #1830 |
Member#: 402344
I'm more about performance than having big rims that are all show. I'd stay with stock but they're dinged up from previous owner and my tires are going so I wanted to do a package deal of rims and tires at the same time. The offset is the part that confuses me the most so I'll do some more research on the web and look through this thread more. I'm thinking of going with 17" instead of 18" because as many have said it looks funny with the brakes being super small behind the rims.
06-16-2015, 12:50 AM | #1831 |
Member#: 146287
BAIC
Performance?
Kojin? 225? More tire means more grip (performance). The widest 17" tire is 255. Anything wider will have to be 18". 18" tends to weigh more (poor performance) and cost more. Widest tire seen on a narrow body is 265. I think a 275 might work. But AFAIK, it hasn't been done. Anything wider will require widebody or flares. Also be weary of tire performance. A proper 225 tire can out-perform a crappy 275 tire. You want to minimize weight. Wheels and tires are both unsprung and rotating weight. The more weight you can save, the better. However, as wheels get lighter, the price starts to go up. The peak of that curve is generally the Enkei RPF1. You won't find a lighter wheel for less. Less offset will require more camber to fit. More offset, less camber. You need camber to be able to corner. 0* will corner just as poorly as -5*. Factory specs are generally -.5* to -1*. I was able to get stock suspension to -1.4*. Proper research should have lead you to this post. (Or some version of it.) http://forums.nasioc.com/forums/show...postcount=1749 |
06-17-2015, 01:21 PM | #1832 |
Member#: 360184
Vehicle:2008 WRX Obsidian Black |
I'm looking for fitment like this. |
06-17-2015, 05:37 PM | #1833 |
Member#: 292225
Vehicle:08 WRX (16g) OBP |
06-19-2015, 10:29 AM | #1834 |
Member#: 207614
South East
Vehicle:2008 WRX Hatch VF52d SSM |
^thats "chosen one"s car. 18x9.75 +20 XXR 527's with 225/40/18 tires. Generally not a fan of the stancy look but his car looks legit.
06-30-2015, 09:39 AM | #1835 |
Member#: 380465
Vehicle:2010 WRX Limited WR Blue |
Jelly
I'm really close to getting the Enkei Raijin 18x8.5 and I'd like to wrap them in 255/35s but I would prefer to not mess with rolling and camber. I may just punk out and get 245s. |
07-02-2015, 10:49 PM | #1836 |
Member#: 408498
E. Canada
Vehicle:2009 WRX WRB |
I posted before, but that was with stock suspension. It kinda looks the same, but a slight change...
-GTWorx Bilstein dampers w/ RCE Black springs -18x8 +48 Sparco Assetto Gara rims -235-40-18 Bridgestone Potenza RE760 tires Once again thanks to everyone else who posted their dimensions and pictures up. This thread was priceless in terms of finding what I should go with! |
07-11-2015, 08:32 AM | #1837 |
Member#: 425262
Vehicle:2017 WRX WRB |
I know that I'm mostly alone (and lowered they look great), but I totally dig having some ride height. Maybe it's the potholed NJ roads...
07-14-2015, 04:05 PM | #1838 |
Member#: 236693
Vehicle:2010 WRX Sedan Spark Silver Metallic |
Been lurking here forever, finally pulled the trigger recently. Thanks to everyone who has posted over the years.
225/45R-17 Bridgestone Potenza RE970AS Pole Position XL, 17x7 Enkei Performance EV5 HBML, BC Racing Coilovers |
07-15-2015, 09:02 AM | #1839 |
Member#: 324464
E. Canada
Vehicle:2010 WRX Hatch OBP |
Anyone know if a 18x9.5 +25 will fit? I know it will require a roll and possibly pull with some camber work as well.
07-15-2015, 09:32 AM | #1840 |
Member#: 219100
Vehicle:2014 STI hatchback Satin White Pearl |
07-15-2015, 12:21 PM | #1841 |
Member#: 324464
E. Canada
The 08-10 WRX (non STi) 17"/18" wheels thread
07-17-2015, 09:16 PM | #1842 |
Member#: 277465
TXIC
Vehicle:11 STi 04 FXT |
"Are your fenders rolled and pulled?.... Yes sir, about 3in out"
and "225-40-18" adjust camber as needed to fit. |
07-19-2015, 10:01 PM | #1843 |
Member#: 324464
E. Canada
07-19-2015, 11:03 PM | #1844 |
Member#: 146287
BAIC
Am I taking ****ing crazy pills?!
07-20-2015, 07:23 PM | #1845 |
Member#: 344329
Vehicle:2008 Wrx, 6mt |
17" O.Z. |
07-21-2015, 12:41 AM | #1846 |
Member#: 357709
Vehicle:2010 wrx red |
17x9 rota Titans. 245/40r17 continental dw summers |
07-21-2015, 05:03 PM | #1847 |
Member#: 355826
Vehicle:09 WRX hatch DGM |
07-21-2015, 05:53 PM | #1848 |
Member#: 207614
South East
Any more pics of that Titan setup? That's exactly the wheel and tire I was thinking about.
07-22-2015, 12:38 AM | #1849 |
Member#: 357709
No work necessary. +42 offset. Rolled one rear fender. Stock suspension.
07-22-2015, 07:41 AM | #1850 |
Member#: 363640
NESIC
Your car looks great! I also run a 17x9 + 42 wheel with a 245/40 tire and I have no fender mods and do not rub. I'm also a bit lower with RCE black springs. Love this wheel/tire size combo on our narrow bodies.
