03-21-2001, 03:48 PM | #1 |
Member#: 2578
How do you reset your ECU
I am told when i install my new muffler to reset my ECU, whats that do and how do i do it? LIttle embarrasing, this topic floats around here enough, but i need to know.
Thanks Alec
03-21-2001, 04:03 PM | #2 |
Member#: 3371
Vehicle:2004 Forester XT Java Black |
Disconnect the negative battery cable for about 45 minutes to an hour.Reconnect and start the car,allow it to idle for about 30 minutes and do not touch the gas pedal.Turn the car off after 30 minutes restart and take er for a spin.I've read and experienced for myself that gas mileage will dip quite noticeably.Many have claimed check engine problems but I haven't.Almost forgot,resetting the ecu allows the computer to relearn the amount of air being sucked in to the engine and compensating with the appropriate amount of fuel or something like that.Does that help any???
[This message has been edited by randolph-rs (edited March 21, 2001).] |
03-21-2001, 05:36 PM | #3 |
Member#: 3231
RMIC
Vehicle:88 626 Turbo white |
yep he covered it the car will drive or i should say pull nicely afterwards
03-21-2001, 06:03 PM | #4 |
Member#: 2578
yeah, thanks alot, If i have any trouble i'll post a topic for some help.
Thanks Alec |
03-21-2001, 07:03 PM | #5 |
Member#: 4119
NESIC
hmm i only had it run till it was at perfect idle, but i accidently turned on my parking lights, after that i started it up again and redlined it a couple times, but hmm its rainy now so i don't want to go overboard, can't see those dayam potholes
03-22-2001, 05:36 AM | #6 |
Member#: 1259
Vehicle:1999 Impreza RS Rally Blue Pearl |
I've changed intakes and other things numerous times and have had to reset the ECU every time. I usually disconnect for the length of the job and then let it idle for about 10-15 mins, and have never had a single problem. Remeber, dont put your foot on the gas at all when you start her back up.
Justin |
03-24-2001, 12:41 AM | #7 |
Member#: 1874
Vehicle:2007 WRB Sports XT |
One other thing...
If you have the keyless entry, or factory alarm, keep the remote handy cause it will go off when you hook the battery back up. (kind of obvious if you have an alarm, but I just have the keyless entry and couldn't figure out why my lights were flashing - till I reset it with the remote) |
03-24-2001, 03:14 PM | #8 |
Member#: 2024
NESIC
Vehicle:2005 Legacy 2.5i Atlantic Blue Pearl |
One thing I figured out the last time I reset my ecu is that if you put the key in the ignition and turn it to "on" and THEN connect the battery, the alarm doesn't go off!
03-25-2001, 08:35 PM | #9 |
Member#: 4119
NESIC
hmm i disconnected my battery for a reset, then an hour later, i connected it back and my alarm didn't even go off
03-26-2001, 03:30 PM | #10 |
Member#: 251
Vehicle:1998 Impreza 2.5 RS Black |
Has anyone tried the way that Brett describes on his MRT website? Go here and take a look:
http://www.mrtrally.com.au/performance/howresetecu.htm I looked for the connectors last summer and couldn't find what he was describing, but I did drive my car right after starting the engine. Did some redline runs, pulled over to shut off the engine and restart, and it felt faster (but that was by the un-scientific butt-dyno method). I'd be interested to see if the US models have those connectors to do this method. If someone successfully does it this way, please take pics and post them! -Chris [This message has been edited by cakagan (edited March 26, 2001).] |
03-27-2001, 04:41 PM | #11 |
Member#: 2030
I tried putting the key on the ON position before connecting the battery. Does not work for me.
How do you reset the ECU? | Homemade WRX | Engine Management & Tuning | 2 | 04-24-2003 12:52 PM |
How do you Reset the ECU | BlueByYou | Newbies & FAQs | 16 | 03-28-2003 02:01 PM |
How do you reset the ECU to get rid of a CEL? | Jasno999 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 05-19-2002 01:54 PM |
How do you reset the ECU | khai yang | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 12-22-2001 10:21 PM |
How often do you reset your ECU? | Gambit | Normally Aspirated Powertrain | 17 | 10-26-2000 02:57 PM |
