10-10-2005, 09:26 PM | #1 |
Member#: 81123
Vehicle:2002 2.5 WRX BY RIP 02' 2.5WRX PSM |
Checklist before a tune...
At one point in time, someone on here had a nifty maintenance checklist to do BEFORE you went to your tune.
I am tuning myself, but am almost out of answers and I am wondering if it isn't mechanical. I have utec and many mods and just when i get AFR's good and no knock - I'll get knock 2 days later in a completely diff. MLP and RPM than I had before. And sometimes it'll be 20-30 knocks!! Then I'll reduce timing or something and the knock is gone - until 2 or 3 days later. So, hence the checklist , I'd like to comb thru any possibilities of problem one by one. I have already: changed plugs, replaced front o2 sensor, leak test done professionally, compression test (fine) , oil change, cleaned MAF, cleaned filter, cleaned IACV thingy (replaced gasket too). Took it to Godspeed and had a decent tune (i think). Problems : rough idle, stalls out, bucking and hesitate past 6k at any TPS. Knocking. Thanks for any suggestions
10-11-2005, 10:11 AM | #2 |
Member#: 81123
Any ideas? I dropped the car off today to get a complete comb-thru. They're gonna check all hoses and pipes for leaks. They also mentioned my alternator could need attention, hence the stalling.
10-11-2005, 10:38 AM | #3 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
10-11-2005, 11:26 AM | #4 |
Member#: 43081
TXIC
What about fuel filter?
10-11-2005, 11:19 PM | #5 | |
Member#: 81123
That was it! Thanks. And the fuel filter's not a bad idea either. |
$500 only to prep before a tune at HarmanMotive | Drew888 | Engine Management & Tuning | 6 | 03-21-2006 02:11 AM |
TBE Gains before/after Tuning | Scott Farmer | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 12 | 12-06-2005 02:54 PM |
CEL day before UTEC tune. | finger123 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 08-25-2004 09:06 AM |
Can I drive before getting tuned? Advice please | skiblur | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 04-27-2004 12:44 PM |
what preperations before road tune? | cwingo | Engine Management & Tuning | 1 | 03-21-2004 05:31 PM |
