Tire & Wheel Forum sponsored by The Tire Rack |
11-24-2008, 01:56 AM | #1 |
Member#: 194170
BAIC
Vehicle:2005 Evolution VIII Tarmac Black |
Tire size on stock '06 17"s
I need some new rubber and want to go wider than the 215/45/17 that are on it right now. The tires I want are 235/40/17 BFG KDWS. Had em before on a previous car and liked them. I Plan on getting some springs in the very near future as well. Will I have any issues with the tires being wider? Taller? I think they will be fine but just want other opinions.
11-24-2008, 02:23 AM | #2 |
Vehicle:OK buy Nates beans westcoastroasting.com |
too wide...225/45 is about it on a 17x7
get some 17x8's if you want wider tires kdws arent the greatest and they get LOUD more research |
11-24-2008, 01:56 PM | #3 |
Member#: 194170
BAIC
I've heard so much of that they get loud. I had 2 sets of 17's on my prelude and never noticed.
11-24-2008, 02:06 PM | #4 |
Member#: 103068
SCIC
Vehicle:11 STI sedan SWP |
If you really want to, you can mount 235/40R17 on your stock 17x7. BUT you might run into a problem with the tire rubbing the strut under high loads.
Skip Barber racing mounts 235/40R17 BFG R1 on the stock 17x7 wheels on their MX-5 racing school. 225/45R17 will fit fine on the 17x7 06 wheels. Many people mount the RE070 on their stock 06 wheels. |
11-24-2008, 06:36 PM | #5 |
Member#: 141672
Do you really need all season tires where you live? Get some tires that have great steering response as in having stiff sidewalls. Dunlops direzza sport Z1 star spec tires are awesome for that as they have steel cord reinforced two ply sidewalls.
11-24-2008, 08:28 PM | #6 |
Member#: 62150
Vehicle:2007 WRX wagon UGM |
KDW's are all season??+1 for goodyear f1gsd3...like glue
11-24-2008, 10:01 PM | #7 |
Member#: 55252
SCIC
Vehicle:* pullup bar * |
11-25-2008, 11:00 PM | #8 |
Member#: 194170
BAIC
I've got a good deal on the KDW's. I snowboard a lot so I would like something that performs well in the wet too. I'm going to go with 235's. Its not going to rub and If 255s fit on stock '07 sti rims then I should be good. If not then well...
11-25-2008, 11:44 PM | #9 | |
and the faulty logic of this is epic and kdw's are WAY down on the list of 'good' tires for your useage and saving $$$ on tires that may wreck ya isnt saving any $$$ and then, well.... |
11-26-2008, 02:11 AM | #10 |
Member#: 55252
SCIC
i don't understand.. other than going snowboarding, does it constantly snow where you are?? from what i've read on and off here, you'd want smaller tires in that type of weather and basically just snow tires, not all seasons.. all seasons are mediocre tires with mediocre performance, they don't do well in anything.. kdws are mediocre tires that do just ok in dry and wet, that's it
11-27-2008, 05:30 PM | #11 | |
Member#: 103068
SCIC
But, most 235/40R17 will fit on the stock 06 wheels without issues. If you will drive in the snow often, wide is NOT your friend. |
04-06-2009, 10:40 PM | #12 |
Member#: 106910
NESIC
Vehicle:2016 GTI C6 ZO6 track toy |
did you end up having any rubbing issues? i'm thinking of running something similar.
05-19-2009, 12:17 PM | #13 |
Member#: 177401
Tri-State
Vehicle:2015 STi White |
225/45/17 requires 7.0" of rim width
235/45/17 requires 7.5" of rim width 225/40/17 requires 7.5" of rim width 235/40/17 requires 8.0" of rim width It is well well out of spec to put 235/40/17 tires on 17x7" rims. Stick to 225/45/17 if you want width on those rims. |
05-19-2009, 02:51 PM | #14 |
Member#: 177401
Tri-State
Track conditions and road conditions are totally different. Putting a low profile tire like 235/40/17 on a narrow rim, you will not be getting the sidewall absorption the tire is designed for. On a race track, who cares. When you hit a relatively small pothole and dent your rim, you'll know it's because you put on a tire that's totally out of spec.
40 sidewall should not be more than a 20% stretch. 245 on 7.0" is 37.8% stretch. NOT EVEN CLOSE TO SPEC! |
05-19-2009, 06:20 PM | #15 | |
Member#: 103068
SCIC
A 245/45R17 is not stretched on a 7" wheel, it is the opposite. A stretch would be installing a 215/45R17 on a 9" wheel. |
05-20-2009, 01:23 AM | #16 | |
Member#: 177401
Tri-State
245/45/17 is 45 sidwall. It can handle up to a 30% stretch in spec. 245 on a 7.0" rim is 37.8% stretch, as we said before. It's a lot CLOSER to spec on an 45 sidewall but STILL out of spec. Sorry if you don't like the word "stretch" being used to imply a wider tire than rim but it's fairly obvious what I mean and I cannot think of a more appropriate term. |
05-20-2009, 04:13 PM | #17 | |
Member#: 103068
SCIC
I talked with someone at Toyo yesterday (because I can walk there from my office, or Nitto for that matter), and the practical effects of an ill-fitted tire (without getting into how to calculate everything since it is different for all cars since the vehicle weight and load is a variable) are: Contact patch distortion Sidewall rollover Heat build up However, in order to quantify all these things, we are going to get into lots of engineering work and measurements that most people will not understand or have the tools to take. |
05-26-2009, 06:15 AM | #18 |
Member#: 194170
BAIC
I don't want ppl to think that running a 235/40/17 is fine on a 17x7 if you are trying to do any sort of track duty. I bought it because A:I wanted to build up the rest of my car and B: needed some tires for the mean time. The KDW's are great tires, regarding their treadwear. For those that have posted, I'm not an idiot, and knew they would fit, as well as knew there would be a compromise for the width. I still love the rubber. It is the same reason I got Cobb springs. I wanted a great look while I saved the money to get my car to turn on a dime. The tires have been great, a little loud like I knew, but great wet handling. Cobb springs suck, but we knew that. Got the drop I wanted. If ppl want to throw 235's on a 7" rim they will work fine, depending on offset. Stock=straight. The KDW's have the XL load on the 235/40 sidewall which helps on the stretch.
Similar Threads | ||||
Quick Question about Tire Size On Stock Rim | aren040 | Tire & Wheel | 9 | 05-04-2006 10:33 PM |
Widest tire size on stock 16" Bugeyes ?? | choloman05 | Tire & Wheel | 4 | 03-22-2006 03:05 PM |
Tire size on stock rims? | deim | Tire & Wheel | 1 | 08-16-2004 04:38 PM |
widest tire size on stock wheels? | Imprezz25rs | Tire & Wheel | 1 | 02-13-2004 08:20 PM |
Tire sizes on stock rims? | adeck | Brakes, Steering & Suspension | 0 | 09-18-2001 07:50 AM |
