Tire & Wheel Forum sponsored by The Tire Rack |
05-20-2009, 04:13 PM | #26 | |
Member#: 103068
SCIC
Vehicle:11 STI sedan SWP |
I talked with someone at Toyo yesterday (because I can walk there from my office, or Nitto for that matter), and the practical effects of an ill-fitted tire (without getting into how to calculate everything since it is different for all cars since the vehicle weight and load is a variable) are: Contact patch distortion Sidewall rollover Heat build up However, in order to quantify all these things, we are going to get into lots of engineering work and measurements that most people will not understand or have the tools to take.
05-26-2009, 06:15 AM | #27 |
Member#: 194170
BAIC
Vehicle:2005 Evolution VIII Tarmac Black |
I don't want ppl to think that running a 235/40/17 is fine on a 17x7 if you are trying to do any sort of track duty. I bought it because A:I wanted to build up the rest of my car and B: needed some tires for the mean time. The KDW's are great tires, regarding their treadwear. For those that have posted, I'm not an idiot, and knew they would fit, as well as knew there would be a compromise for the width. I still love the rubber. It is the same reason I got Cobb springs. I wanted a great look while I saved the money to get my car to turn on a dime. The tires have been great, a little loud like I knew, but great wet handling. Cobb springs suck, but we knew that. Got the drop I wanted. If ppl want to throw 235's on a 7" rim they will work fine, depending on offset. Stock=straight. The KDW's have the XL load on the 235/40 sidewall which helps on the stretch.
Quick Question about Tire Size On Stock Rim | aren040 | Tire & Wheel | 9 | 05-04-2006 10:33 PM |
Widest tire size on stock 16" Bugeyes ?? | choloman05 | Tire & Wheel | 4 | 03-22-2006 03:05 PM |
Tire size on stock rims? | deim | Tire & Wheel | 1 | 08-16-2004 04:38 PM |
widest tire size on stock wheels? | Imprezz25rs | Tire & Wheel | 1 | 02-13-2004 08:20 PM |
Tire sizes on stock rims? | adeck | Brakes, Steering & Suspension | 0 | 09-18-2001 07:50 AM |
