Brakes & Suspension Forum sponsored by The Tire Rack |
09-13-2002, 03:11 AM | #1 |
Member#: 7142
Sedan rear strut top torque specs (for rear strut bar install)
Ok I did my searching and I came up with 14.5 ft/lbs. Just verifying if this is correct...
Also, is there a specific torque spec on the actual two bolts that connect the towers to the actual bar? Or is it just, "nice and tight?" (the bolt in this pic http://www.oakos.com/wrx/installs/RSTB/IMG_3495.jpg , even though it is a whiteline bar). (This is for a Cusco rear strut bar install) Thanks. Bryan |
09-13-2002, 05:22 AM | #2 |
Member#: 18226
Vehicle:2001 M3 Laguna Seca Blue |
yes its 14.5
im not sure about the strut tower bar though |
09-13-2002, 08:32 AM | #3 | |
Member#: 7089
NWIC
Vehicle:2016 STi |
Re: Sedan rear strut top torque specs (for rear strut bar install)
09-13-2002, 10:41 AM | #4 |
Member#: 7142
Thanks guys.
Bryan |
09-13-2002, 10:45 AM | #5 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
BTW, you're supposed to replace those nuts every time you undo them if I'm not mistaken, and I've read at least once where not replacing them has caused problems. I wish I had the link handy, but I don't.
And no, I didn't replace mine when I swapped my struts out, but... just so you know. |
09-13-2002, 10:52 AM | #6 |
Member#: 7306
Hey Bryan,
Did you just get a strut bar or did you get other mods on the suspension? Just curious on whether you bought the RA's. Tyler |
09-13-2002, 12:25 PM | #7 | |
Member#: 7142
I decided to get a stage 0 first, then throw on the coilovers. I still have it sitting around my house, just haven't had time to go up to Scooby Specialties and have them install it (along with my EGT probe). I kind of also want rims at the same time, but I haven't had the urge to dump 4K on the stuff just yet Been out at all lately? |
09-13-2002, 12:27 PM | #8 | |
Member#: 7142
Yes I read that somewhere.... anyone have the part # handy or should I be fine? I know at least 2 or 3 people that didn't replace them and they haven't had any problems. |
09-13-2002, 02:57 PM | #9 |
Member#: 7306
I am going to need a ride after the stage 0 install.
I have been meaning to stop by Marina Blvd, but after the MTV thing on San Diego, I haven't been wanting to go. I've been curious if you have done anything to your car. I am still the same, but have big plans on my mind. Hope to see you soon. Tyler |
Similar Threads | ||||
Torque spec for Ver5 strut bottom insert bolt | Rallly2000 | Brakes, Steering & Suspension | 10 | 03-15-2010 12:59 AM |
What is Torque Spec for rear diff mounting bolts? | shemoves | Transmission (AT/MT) & Driveline | 2 | 11-07-2007 08:40 PM |
torque spec for rear differential bushing bolt | alltractionWRX | Brakes, Steering & Suspension | 1 | 03-08-2003 09:43 AM |
Torque specs for rear swaybar mounts? | Dave99 | Brakes, Steering & Suspension | 2 | 08-03-2002 05:37 PM |
urgent: need torque specs for rear sway bar.... | FormerSubTech | Brakes, Steering & Suspension | 1 | 01-26-2002 12:30 AM |
