Old 05-04-2005, 09:31 AM   #1
attitude
Member#: 52043
04 sti
Default fuel pump not priming/ecu not on?
i was driving my car last night and it shut off. when i try to start it, the fuel pump wont prime, the utec doesn't have the lights on it either. my avc-r is tapped to the ecu wires, and it is getting power. i have a bad feeling that the utec or ecu are fried. anyone else have similar problems?
mods:
utec
tuner pro
all fuel mods
t-67
tgv delete
front mount
big maf
etc.
attitude is offline   Reply With Quote
Old 05-04-2005, 09:44 AM   #2
2phless
Member#: 69343
1998 TransAm cnvrtbl
First. Get power for the AVCr somewhere else. There are enough sources of 12v in the car that you don't need to be sharing one with the most important component in the car.
If you are lucky, one of the connections for the AVCr broke the circuit to the ECU. If not, try taking the UTEC out of the loop. It probably won't start with your mods, but you can listen for the fuel pump. Really lucky and it just wants a hard battery reset.
2phless is offline   Reply With Quote
Old 05-04-2005, 09:46 AM   #3
gusto
Member#: 58323
checked all your fuses???
gusto is offline   Reply With Quote
Old 05-04-2005, 09:58 AM   #4
attitude
Member#: 52043
04 sti
going to check all fuses soon, i have to work until 5. and i unplugged the batt. and hit the brakes. no luck
Old 05-04-2005, 07:28 PM   #5
attitude
Member#: 52043
04 sti
fuse sbf #5 under the hood keeps blowing. only when plug 187 on the ecu is plugged in. far right plug. think the fuel pump is grounding out in the tank?
Old 05-04-2005, 08:21 PM   #6
03MBP
Member#: 32460
2005 Forester XT
Check the main relay, mine went on me a few weeks ago. Its the brown one under the glove compartment/kick panel.
03MBP is offline   Reply With Quote
Old 05-05-2005, 12:15 AM   #7
wrxtuner02
Member#: 22700
TRD FJ Crusier SE
76 MG Midget Special
we actually found it to be the aforementioned fuse and it only blows when the 187 plug is in the ecu, there are quite a few grounds on that plug, one being teh rear O2. i guess well start tracing grounds tomorrow.
wrxtuner02 is offline   Reply With Quote
Old 05-06-2005, 04:58 PM   #8
wrxtuner02
Member#: 22700
TRD FJ Crusier SE
well we think we found teh culprit. The pony express MIL eliminator was somehow grounding out and plowing the SBF fuse #5. simple solution, pull teh rear o2 and plug the hole. how imperative is teh rear o2 to the ecu? We have a UTEC and TUNA in teh car.
Old 05-06-2005, 05:01 PM   #9
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Rear O2 is only there for emissions.
dwx is offline   Reply With Quote
Old 05-06-2005, 06:21 PM   #10
attitude
Member#: 52043
04 sti
hole will be plugged tomorrow
Old 06-24-2005, 12:58 AM   #11
nate.the.great
Member#: 72031
2017 SS 1LE
I'm having the same problem, but I don't really understand your post. I have a PDE downpipe which has never given me a CEL. I also have a a/f ratio plugged into the rear O2 sensor (I just needed something to fill the other spot in my other a-pillar hole.) When my ECU gets hot from "spirited driving" my fuse blows.
Basically, the instructor was driving my car, my fuse blew, and my car died. We towed it and then I pulled the fuse and swapped in a new one (car was off), and that fuse blew right away. Then, I took my ECU cover off, let everything cool down, and put in a new fuse. It worked and I drove home. Any ideas on my culprit?
nate.the.great is offline   Reply With Quote
Old 06-24-2005, 07:59 AM   #12
attitude
Member#: 52043
04 sti
no. this still hasn't fixed it. we still have no idea why this fuse is blowing.
Old 06-24-2005, 10:11 AM   #13
nate.the.great
Member#: 72031
2017 SS 1LE
when does yoru fuse blow? is it under hard driving? i wonder if ecu heat has anything to do with it?
Old 06-24-2005, 10:52 AM   #14
attitude
Member#: 52043
04 sti
i drove mine for about two miles, hit a bump, and blew the fuse.
i have since waited a day, then put a new fuse in it, and it blows right away.
it is 90+ degrees here, and its hot in the car.
i wonder if i removed the utec from the ecu, put it in the garage for a day, to allow for complete cooling, and tried it then...
but that wouldn't explain why they blow when i hit a bump, or stall it. mine seems like something is rubbing.
Old 06-24-2005, 11:03 AM   #15
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
wild suggestion:
check the gromits where the wires enter and leave the engine bay
Old 06-24-2005, 12:00 PM   #16
attitude
Member#: 52043
04 sti
will do, although i have looked at them already. but not intensively
Old 06-24-2005, 12:16 PM   #17
nate.the.great
Member#: 72031
2017 SS 1LE
try this...
1. make sure your ecu is cool - (i have some wires wired into my ecu and i moved those apart to make sure they weren't touching each other)
2. unhook your battery
3. drain your power by hitting the brake
4. install the new fuse
5. plug in the battery
that worked for me. however, mine blew when my ecu was very hot AND we were in a turn. i wonder if the turn had anything to do with it. how weird... I wonder if that fuse blows when the ecu sees something weird (heat, etc...)
Also see this post. http://forums.nasioc.com/forums/showthread.php?t=521166 Maybe under extreme loads aka cornering or hitting bumps that wire underneat the rear seat gets pinched?
Fuel pump continously priming on swap speedymaker Subaru Conversions 1 03-22-2010 08:20 PM
fuel pump wont prime legacy1907 Subaru Conversions 3 12-21-2007 11:22 AM
Fuel Pump wont prime!! 02ej257 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-08-2006 03:45 PM
FS: Walbro Fuel pump (NEW), CObb ecu, TXS axleback WRX Jim Private 'For Sale' Classifieds 7 10-18-2003 06:32 PM
PE fuel pump dies - POS - need info on supra pump alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 02-20-2002 08:25 AM
