Tire & Wheel Forum sponsored by The Tire Rack |
04-23-2016, 03:33 AM | #4851 |
Member#: 437435
04-23-2016, 08:39 AM | #4852 |
Member#: 421611
Vehicle:2016 JRtuned Econobox |
^ Sex.
04-23-2016, 11:30 PM | #4853 |
Member#: 432607
Vehicle:2016 WRX WRB |
04-24-2016, 02:22 PM | #4854 |
Member#: 397628
Vehicle:2018 STi Crystal White Pearl |
Ordered a set of wheels in 18X9.5 +38 for my 16 STi. I was not planning on this size but, I got a decent deal.
Installing RCE Yellows the same time that the wheels are mounted. I have not pulled the trigger on tires just yet. Looking for an opinion. The car will not be tracked, just daily driven and spirited drives now and then. Looking for best overall comfort and do not want to roll the fenders on the yellows. What would be the best option? Looking at: 255/35, 255/40, 265/35 if it will fit. I appreciate the help! |
04-24-2016, 08:56 PM | #4855 |
Member#: 439846
Vehicle:2015 WRX Crystal Black Silica |
04-25-2016, 02:33 PM | #4856 |
Member#: 383483
Vehicle:2015 WRX Limited CVT DGM |
04-25-2016, 03:19 PM | #4857 |
Member#: 420460
04-25-2016, 09:34 PM | #4858 |
Member#: 427519
04-26-2016, 08:30 AM | #4859 |
Member#: 436869
Vehicle:2016 WRX ISM |
Putting on 18x9.5 +38 wheels soon with stock suspension, possibly lowering in the future. I know I could go 265/35 safely but am comtemplating 275/35. Anyone done that? What's required and could I get away with it without rolling on stock suspension? I've looked and can't find much on 275s
04-27-2016, 04:07 PM | #4860 |
Member#: 396667
Vehicle:2015 WRX Crystal White Silica |
04-27-2016, 05:54 PM | #4861 |
Member#: 403893
SCIC
Vehicle:2015 STi Limited WR Blue |
Pretty sure you need a custom tune to run Cobb Flex Fuel. They're working on OTS maps, last I checked.
04-27-2016, 05:58 PM | #4862 | |
Member#: 329962
BAIC
Vehicle:2016 WRX 6MT Shadowmere |
One guy on this post with a dark blue wrx said: "18x9.5 +40, 275/35, no fender mod", but provided only one picture Another with a red: "18x9.5 RPF1" Emailed MachV and they said their 18x9.5 +42 MIGHT work, but can't confirm. Would love if someone would give a detail configuration on running 275/35/18. |
04-27-2016, 06:34 PM | #4863 |
Member#: 436459
South East
Vehicle:2016 WRX MT ISM |
Wheels: 18x8.5 +33
Tires: 245/40/18 [IMG][/IMG] Last edited by nTaWRX; 05-08-2016 at 06:37 PM. |
04-27-2016, 07:49 PM | #4864 |
Member#: 385166
E. Canada
Vehicle:2015 WRX Sport-Tech World Rally Blue Pearl |
I'm looking for the Avid AV-20 and many peoples have those, but I can't decide between 18x9.5 +38 and 18x8.5 +33 can someone explain me the advantage/disadvantage of one over the other? I have a Stock 2015 WRX
Thanks! |
04-27-2016, 08:59 PM | #4865 | |
Member#: 404378
Vehicle:2016 WRX STI DGM |
04-27-2016, 11:09 PM | #4866 |
Member#: 427519
04-27-2016, 11:51 PM | #4867 |
Member#: 29393
Vehicle:2015 WRX wrbp |
04-28-2016, 12:52 PM | #4868 | |
Member#: 398410
Vehicle:2018 subaru wrx DGM |
i just got back from tire rack earlier this morning and i went from 18x9.5 +38 255/35 to 17x9.5 +38 275/40 its super flush no poke. it has to be the right wheel and tire combo though as all tires in the same spec are not created equal. in my case there were no affordable 265/40 17 so i pretty much didn't have any choice but to run 275. tire rack even said its within spec so we test fit and it was a go. rpf1s and a narrow sumitomo no work no roll no pull no hassle on mess and definitely no rub. 18s are too heavy probably could have gone 18x10 +38 on a 265 i doubt a 275 on a 10 in wheel would fit. i would say my setup is the limit and even at that caution has to be taken as to tire choice. no conti dws or pss for me won't fit in 275 but others will... pics later if i get around to it. |
04-28-2016, 12:56 PM | #4869 | |
Member#: 398410
ps. you can scratch the finish of with the light stroke of a finger nail and they weigh 24+ lbs (i weighed them) 50 lbs per corner with tires will really bogg the car down quite a bit. my advice to everyone is to get 17s even sti guys 17x10 with 265 or 275 edit: might i add they are made in chinois if that means anything to you. anybody in the midwest want a set of avid av20 with some brand new 255 35 hit me in a pm 18x9.5 +38 blue ill sell them for a reasonable price. Last edited by powder8; 04-28-2016 at 02:10 PM. |
04-28-2016, 03:31 PM | #4870 | |
Member#: 422693
Vehicle:2016 WRX Premium Lapis Blue Pearl |
04-28-2016, 04:30 PM | #4871 | |
Member#: 398410
my tires weigh 28lbs but my wheels only weigh 17 so it works out... thats 8 lbs per corner from 18x9.5 av 20s with 255s. you will feel that. on my vehicle even with a 275 the car is not nearly as restricted as when i had the avids on earlier today. all in all you get one season either a fall winter or a spring summer out of these wheels. but hey they are so cheap you can replace them one at a time as needed right...ive been running chinese knockoff wheels for years avid.1 av20s were the first and only budget wheels i had a problem with. Last edited by powder8; 04-28-2016 at 07:52 PM. |
04-28-2016, 05:36 PM | #4872 | ||
Member#: 97135
"you will feel that" if you came from a significantly lighter wheel like a TS-1 or RPF1. Realize that race teams run 18x9.5-18x10 Rotas that weigh 21-22lbs. Also understand that noone really gives a **** about your opinion. You made your comment, no need to make post after post regurgitating it. |
04-28-2016, 06:01 PM | #4873 | |
Member#: 398410
understand its a forum and someone might need that exact information bc i didn't find it anywhere else. but hey like i said they are **** wheels no one will argue that point. btw I'm a huge proponent of less expensive wheels; just not those. xxrs are run on formula drift cars if you call that racing. they have a few very reliable options 527 being chief among those. i run them for winters w/e dude do what you want on your car. back on topic |
04-28-2016, 08:04 PM | #4874 | |||
Member#: 97135
wrong. 23lbs.
For a daily will it even matter? Nope. Quote:
The point is - people can buy whatever the hell they want to buy. |
04-28-2016, 08:45 PM | #4875 | |
Member#: 329962
BAIC
Would love pictures from back, front and top down. I'm also considering 275/40/17 over 275/35/18 for more meat. |
