08-07-2009, 06:24 PM | #1 |
Member#: 188424
Vehicle:2012 LS6 FD RX7, Evo |
Weird hissing noise coming from left side of the engine on WOT
so i noticed this sssssssssssssssss noise coming out of the engine while im driving. like air is leaking or something. it is RPM dependent. when i am WOT on highway, it pulses sometimes. like the gasket is going up and down hitting the metal.
so i went under the car, checked all the gaskets. i see no leak on the headers, trackpipe, or the exhaust. no residue. nothing. all the lines are connected. what could this air leaking like sound be? any comments, suggestions would be appreciated thanks
08-08-2009, 01:28 PM | #2 |
Member#: 188424
bumpy
08-08-2009, 02:28 PM | #3 |
Member#: 202804
Vehicle:2002 PSM Sedan The 2.0L that could |
i would say check for normal boost psi, but you have a 2.5 rs. Can you hear the hissing @ idle or it's just at WOT?
08-08-2009, 04:20 PM | #4 |
Member#: 53558
NWIC
Vehicle:2005 Baja Turbo White/Silver/Black 3tone |
lol First response that came to mind was 'it's the turbo?', then I realized it was an RS as well.
Is your intake properly together? If there are any tears or it has come apart, that could make that sound you are describing. Your engine would also be louder. |
08-08-2009, 09:21 PM | #5 | |
Member#: 188424
i hear the noise at all RPM's especially at WOT. it defenitely sounds like air leaking and sometimes it pulses like the flange is vibrating.. im really not sure what else to check right now.... |
08-08-2009, 09:22 PM | #6 |
Member#: 188424
and also, its comign from left side of the engine (from sitting in the car), which is opposite side from where the intake is...
08-08-2009, 09:35 PM | #7 |
Member#: 53558
NWIC
Get some carb cleaner. With the car warmed up and idling, start spraying it on your intake manifold where it bolts to the heads. If it dies, you've got a leaking gasket. Easy way to check for intake leaks.
08-10-2009, 12:24 PM | #8 |
Member#: 188424
Weird Moaning noise coming from my front right axle area...? | Flyin_Hayn | Transmission (AT/MT) & Driveline | 2 | 06-05-2010 02:50 PM |
Weird noise coming from driver side while cornering?? | waitandbleed92 | Brakes, Steering & Suspension | 1 | 02-01-2006 06:19 PM |
clacking noise coming from driver side of engine | nhluhr | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 10-25-2004 04:22 PM |
weird buzzing noise coming from driver side mirror | x12oyx316x | Service & Maintenance | 1 | 02-19-2004 09:16 PM |
damn, weird whine noise coming from the front of my engine | jmott | Texas Impreza Club Forum -- TXIC | 1 | 08-03-2002 11:27 AM |
