07-23-2004, 08:52 AM | #1 |
Member#: 34476
BAIC
Vehicle:88 civic subyless for now |
odd boost noises
Ok, I have a SOHC 2.5RS motor with a wrx turbo kit on it. I am running 5 psi and when I engauge boost, right around 3 or 4 psi I start to hear a crinkle type noise. I think it may be boost escaping into the atmosphere but not sure. I hope its not serious and I just wanted to see if anyone knew what it might be. Any suggestions would be appreciated.
07-23-2004, 09:51 AM | #2 |
Member#: 2279
South East
Vehicle:2000 Slingshot Pastelito Racing |
Crinkle? Like beebees in a coffee can?
07-23-2004, 10:00 AM | #3 |
Member#: 146
RMIC
Vehicle:'16 WRX Limited White |
yes, if it's beebees in a coffee can, or a loud crackeling sound..... GET OFF THE GAS!!!!!! that would be pre-detonation, and it will destroy your motor.
07-23-2004, 03:49 PM | #4 |
Member#: 34476
BAIC
I am running pig rich though and I have wrx injectors. But yes it does sound like beebee's in a coffee can now that I think about it. I have the motor running on my 1.8 ecu and harness in MY95 L so I wasn't able to hook up the knock sensor so I can't tell if it is knocking on my safcII. Pre-detonation though huh. Wow I had no idea, thanks ALOT for the input Aphex, I really appreciate it.
07-23-2004, 07:56 PM | #5 |
Member#: 34476
BAIC
Out of curiousity, what is pre detonation exactly?
07-23-2004, 07:58 PM | #6 |
Member#: 2279
South East
Engine Knock... http://zhome.com/ZCMnL/PICS/detonation/detonation.html
Either your timing is screwed up, or your fuel is insufficient, either way, if you continue on it you will blow up the engine. Then it'll look like this -> http://forums.nasioc.com/forums/showthread.php?t=528857 |
Similar Threads | ||||
Yet another Odd wheel noise | cvalle-sd | Service & Maintenance | 0 | 05-25-2005 06:04 AM |
Odd engine noise... | ScubaruImpreza05 | Normally Aspirated Powertrain | 0 | 01-22-2005 09:28 AM |
05 WRX with ODD tranny noise - need info about driveline | Craig02WRX | Transmission (AT/MT) & Driveline | 2 | 10-16-2004 02:37 AM |
More odd suspension noises | Bionic | Brakes, Steering & Suspension | 4 | 03-18-2003 11:05 PM |
odd brake noises | Suladed | Brakes, Steering & Suspension | 2 | 05-18-2001 06:43 AM |
