10-20-2014, 11:37 PM | #9251 |
Member#: 336869
I am thinking of buying Blouch 1.5XTR Twinscroll 10cm^2 and running 26psi mid range on 93 for my stockblock v8 ej207. Do you guys think this is too much for the heads? Also when should I expect to see full boost and how much hp roughly? (stock heads and cams etc). mods are exhaust, CAI, 3 port, fuel pump, sparks etc
10-21-2014, 01:24 AM | #9252 | |
Member#: 270569
International
Vehicle:'15 Foz XT & GT86 |
10-21-2014, 08:58 AM | #9253 |
Member#: 182415
Vehicle:1999 RS Aspen White |
10-21-2014, 03:51 PM | #9254 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
Im running flat 4 rails on my V8. They bolt up but its a super tight fit and the connecter does hit the rail. Install can be PITA but they work great!!
10-21-2014, 09:55 PM | #9255 |
Member#: 309465
E. Canada
Vehicle:1999 GC + ver 9 swap Feather White |
10-21-2014, 10:16 PM | #9256 |
Member#: 79643
NESIC
Vehicle:2021 STI TE Terminal black pearl |
10-22-2014, 03:56 AM | #9257 | |
Member#: 266527
Just the usual, Equal length headers Ewg Fmic Id1000 3'' Turbo back exhaust KS tech 73mm intake AP 3'' inlet Stock v7 block Stock cams Speed density I might throw in a pair of kelford cams and arp head studs in there next month and switch to E85 so we push this thing out to 450-480whp. |
10-22-2014, 02:52 PM | #9258 | |
Member#: 306719
Vehicle:2003 Sti Wagon @jn_garage |
Any oil analysis ? |
10-22-2014, 03:33 PM | #9259 | |
Member#: 336869
10-22-2014, 05:03 PM | #9260 |
Member#: 266527
10-22-2014, 05:05 PM | #9261 |
Member#: 266527
10-23-2014, 03:45 AM | #9262 |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 EJ207 S204 Wagon |
Just had my (S204) EJ207 tuned yesterday at Yimisport.
330whp 320wtq on 91 pump 401whp 383wtq on e85 Peak torque was around 4.3K with HP's around 6.3K for both fuels. Tomei 7760 Tomei ELH Cobb catted TBE Spearco TMIC APS 70mm intake Hybrid MBC/EBCS 1100 FIC injectors Unbelievably smooth running motor. I now have next to zero NVH, even with the Cusco engine and motor mounts, Beatrush pitch stop, and all upgraded bushings. I had noticeable NVH before the motor swap. |
10-23-2014, 07:56 AM | #9263 | |
Member#: 306719
10-23-2014, 10:58 AM | #9264 | |
Member#: 309465
E. Canada
Man... I guess it's a bit of a rhetorical question, but what's up w/ my engine then? Or maybe I'm the dumb one and it's normal.
I overlaid your dyno chart on mine and you're spooling only a couple hundred RPM later. I'm running the stock VF-37/engine w/ a perrin inlet, high flow DP and grimmspeed EBCS tuned for 93 octane. :\ I don't suppose anyone has a dyno chart of a stock v9 w/o any tuning, etc? Quote:
10-23-2014, 01:02 PM | #9265 |
Member#: 82745
SCIC
10-23-2014, 03:45 PM | #9266 | |
Member#: 336869
23 psi at ~3600 in 3rd 23 psi at ~3350 in 4th |
10-23-2014, 08:25 PM | #9267 | |
Member#: 309465
E. Canada
Engine does feel a bit sluggish in lower revs sometimes. Is there a faq or a how to on how I'd check up or diagnose if my AVCS is working? I'd have thought that my tuner would've made sure before the tune. It's tuned w/ Ecutek currently, so I don't know if I can log it w/ open source? |
10-23-2014, 08:31 PM | #9268 | ||
Member#: 336869
To check if AVCS is working do the below: Quote:
10-23-2014, 09:48 PM | #9269 |
Member#: 309465
E. Canada
10-23-2014, 09:52 PM | #9270 |
Member#: 6886
Vehicle:MY01 EJ207 HTA35r AVCS ON! |
if your Ecutek tune prevents you to log with open source, you'll need to log the avcs with Delta Dash/ProEcu.
10-25-2014, 02:17 AM | #9271 |
Member#: 10854
SCIC
Vehicle:'02 WRX; '08 OBXT; '08 G37 (S/C'd); '09 XF |
What's the popular injector to run these days? I heard something about Bosch 850's? If Bosch is making injectors for top feed Subaru fuel rails, I'd guess those are the hot ticket?
To those of you with ID 1000's - how's idle and part throttle cruise? |
10-25-2014, 09:53 AM | #9272 |
Member#: 6886
ID1000's are actually spec'd Bosch. Had them for several years now, idle perfectly and no issues part throttle cruise.
10-25-2014, 03:32 PM | #9273 |
Member#: 82745
SCIC
10-26-2014, 12:03 PM | #9274 |
Member#: 10854
SCIC
Cool, thanks guys! I'm probably going to go with Bosch/ID's. I've had DW's for a little while, and it seems like they commonly start having issues at around 50K miles, which is inline with what's happening with my car.
10-26-2014, 12:37 PM | #9275 |
Member#: 46135
Vehicle:19 GLA45 AMG C63 AMG |
My Kamak TD05 16GTX STS Twinscroll looks like it's settling on 3750 RPM for full spool for 23 PSI.
This is with 62F intake temperature. Looks like the slightly taller 4th in my 6 speed has very little influence over the spool. My records with the 5 speed in 3rd are also in the 3700 range, with this turbo, with intake temps in the 60's. |
ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-26-2011 07:29 PM |
Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 06-03-2010 04:53 PM |
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 10-17-2005 01:56 AM |
