01-06-2008, 04:19 PM | #1 |
Member#: 127556
Vehicle:2006 WRX RomRaided. |
'06 Stage 2 WRX, logged AFR not matching map targets
I installed an LC-1 with XD-16 WB02 gauge a couple weeks ago. The first thing I noticed was that my car was running quite rich under load. The map values were calling for around 11:1 AFR's, and the car was down at around 9:1 at peak torque and 8.5:1 at redline. Idle and cruise AFR's were steady fluctuating right around 14.7:1.
This was somewhat surprising, as the car seemed to run well and did not stutter or hesitate at all. In addition, the car seemed to behave normally in boost, which hit targets, and did not waver at all. After spending a lot of time checking for boost/exhaust leaks (of which I've found none), and re-calibrating the WB02 sensor (gauge and logs showed the same values after re-calibration), I decided to simply try leaning out the target AFR tables. After leaning out the high load target AFR tables by around 2 points, the car now hits right around 10.8:1 during peak torque, and 11.3:1 at redline. The map values now call for 12.3 and 13 AFR respectively. My first instinct would be to chalk this up to some type of leak, but I can't seem to find any other behavior that is out of the norm (boost seems to behave perfectly normal), other then the fact that actual AFR doesn't match the map targets. Has anyone seen similar behavior? If this may be caused by a leak, where specifically should I be looking? Is my car just a freak? Relevant information: 06 WRX TXS Stealthback exhaust Maddad Whisper axleback GMBCS Thanks.
01-06-2008, 05:34 PM | #2 |
Member#: 115819
Vehicle:2006 vf39 R0mRa1DeR Darknessess Wagon |
It could be caused by a boost leak, but then you would notice either lower boost or really high wgdc to hit target boost.
Sounds like you need to tune the MAF calibration. Where logged AFR is lower than target, you need to lower the MAF calibration. The ecu thinks it's getting more air than it really is. Try airboy's spreadsheet, it will graph everything and show the AFR error against maf voltage. Last edited by ExpO; 01-06-2008 at 05:41 PM. |
01-06-2008, 06:20 PM | #3 | |
Member#: 127556
01-06-2008, 08:04 PM | #4 | |
Member#: 72829
W. Canada
Vehicle:2006 WRX 2015 WRX |
Remember to flash back to the 11AFR map after cleaning the MAF or you may get a nasty surprise. Do you have the means to collect data logs? The stock '06WRX intake ran lean on my car. |
01-06-2008, 11:19 PM | #5 | |
Member#: 127556
I've got some MAF cleaner that I've been using regularly to keep the MAF clean. I'll toss in the paper filter and clean the MAF and see what happens. Yeah, the numbers cited previously are from datalogs. Other's that I've talked to have said the same thing, that the '06 runs just a tad leaner then map targets. |
01-08-2008, 02:00 PM | #6 |
Member#: 127556
Well, I cleaned the MAF and tossed on the stock paper filter. No change in logged AFR. The car is still running ~2.0 points richer then the map calls for. Idle and cruise AFR's are still in range.
It seems like I can rule out a boost leak (as boost seems to behave normally), where else (would have to be post-MAF) should I be checking for a leak, and what would be the best way to check? One additional thing of note: I get the impression that WOT/high load AFR seems to be bouncing around more then normal. This would be in indication of a leak, correct? I'll grab some logs to toss 'em up tonight. |
01-08-2008, 02:13 PM | #7 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
Vehicle:98 2.5 RS 04 WRX |
I have never seen a DBW Subaru match real world AFR with the fuel map targets from the factory. So no, your car is not a freak.
01-08-2008, 02:29 PM | #8 |
Member#: 127556
01-08-2008, 09:20 PM | #9 |
Member#: 32459
Vehicle:02 WRX VF34 (SOLD) Junior Tuned 301whp |
where did you tap the sensor to?
01-08-2008, 09:40 PM | #10 |
Member#: 127556
The sensor is in the downpipe, around 15" from the turbo.
01-09-2008, 08:14 AM | #11 |
Member#: 44422
SWIC
Vehicle:2009 G8 GT Cammed, sprayed, stalled |
Just a thought, but check in LM Programmer for the WBO2 that you have the correct fuel specified. The AFR is merely a representation of the ratio based on the fuel that you have selected. The WBO2 actually measures lambda.
01-09-2008, 12:27 PM | #12 |
Member#: 127556
Yeah, the LC-1 has the 14.7:1 (Gasoline) fuel type selected. Many of the guys local to me seem to be convinced the cause is simply a the car running off from the fuel mapping. It's been suggested that raise the injector scalar to bring the open loop map and logged AFR values closer. I may try playing with that this weekend.
01-09-2008, 12:40 PM | #13 | |
01-09-2008, 03:21 PM | #14 |
Member#: 110994
Vehicle:2006 SGM STi 1997 SVX LSi |
where can i get a copy of airboys spreadsheet for the maf
01-09-2008, 04:40 PM | #15 | |
Member#: 127556
The current resolution is adequate, but I was simply concerned, as a 2 point differential seemed like a high tolerance for a car with the stock airsystem. Thanks much for the info! |
01-13-2008, 03:17 PM | #16 |
Member#: 122980
South East
Vehicle:2010 F150, 2013 CX-5 92 Miata 15 TTF/PTF/E3 |
Mine is 1.1 different from whats in the map. i.e. when Im targeting 12.1 during boost onset, Im actually getting 11.0.
I think 06rexwagon had the same thing if I remember correctly. Ive seen two other 06's where the fuel maps didnt match the actual AFR's as well. |
01-13-2008, 04:08 PM | #17 | |
Member#: 127556
For anyone else researching this issue: In open loop, my car is right at 1.5 points richer then target. |
01-15-2008, 07:54 PM | #18 |
Member#: 35076
TXIC
Vehicle:2004 507whp Wagon Silver |
If you have the stock MAF housing you can update your MAF scaling pretty quickly to adjust your AFR to match targets. Probably take about 3-5 WOT runs and a few flashes.
Easiest way to do it is log RPM, MRP, MAF v, EL, and WBo2. I generally log MRP to show changes in onset fueling which is tough to dial in. But once that is stable you can modify the voltages on the MAF table to fall in line. Add voltage to lean it out, subtract to richen. I would recommend setting your Target fuel to 11:1 from 2800-redline during this time to keep the maf tuning easy, then adjust your fuel curve after the MAF is dialed. |
01-15-2008, 11:14 PM | #19 | |
Member#: 115819
Last time I did my afr's I ran a 10.5-10 map, scaled the maf, then bumped it to 11.5-11 with no issues. Doing it this way also eliminates the possibility of a rich/lean run if your load/rpm cell goes into a part of the fueling table in which you haven't logged the afr error. Anyone know for sure if there are any other compensations that apply or use either table? Last edited by ExpO; 01-15-2008 at 11:20 PM. |
01-16-2008, 01:19 PM | #20 | |
Member#: 127556
01-16-2008, 02:01 PM | #21 | |
Member#: 47145
Vehicle:2012 Gas Saver |
I use an unorthodox way of correcting this that most don't do BUT I've used it on just about every car I've tuned & its worked flawlessly. I see jacking w/ the MAF table as a last resort. Instead of jacking w/ the MAF table, raise the injector scalar. My reasoning, if you jack w/ the MAF tables you'll end jacking with more tables, most of them that include the Load reference values. By raising the injector scalar you are linearly raising the fuel table. I'd start by dropping the AFR back down to a ~11.0:1(assuming you are on 93octane) at peak load, then raising the scalar 20-30cc/min since your tailpipe is ~2 points off of matching the AFR table. This is generally the first thing I do when tuning a car. |
01-16-2008, 02:24 PM | #22 |
Member#: 103320
Vehicle:1998 swapped Forester L |
testes,
does this apply to DBC or only DBW cars? Interesting approach. |
01-16-2008, 02:28 PM | #23 |
Member#: 47145
01-16-2008, 03:09 PM | #24 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
Testes, if the injector scaling is the actual problem, then fixing it rather than MAF scaling is the correct thing to do.
However, if the AFR targets weren't being met because the MAF scaling was off, then in stock form you're getting bad load data anyway. Fixing the MAF scaling would fix both the AFR targets AND give you correct load data. The real question is what's wrong in the stock tune. |
01-16-2008, 03:24 PM | #25 |
Member#: 47145
Similar Threads | ||||
Logged target boost does not match map | STIlin' | Open Source Reflashes | 1 | 04-15-2009 12:10 AM |
Stage 2 WRX map enginuity | HKSpowerWRX | Commercial ECU Reflashes | 3 | 12-04-2007 12:12 AM |
Stage 2 WRX looking to go back to the stock map-Questions.. | SubbieAndCoop | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 07-14-2007 09:22 PM |
06 Stage 2 WRX PDXtuning map | drmichael | North West Impreza Club Forum -- NWIC | 11 | 10-20-2006 05:56 PM |
PDX Maps for 06 Cobb Stage 2 WRX | sleestak6326 | TXIC Private Classifieds | 15 | 07-23-2006 10:34 AM |
