09-27-2005, 04:14 AM | #1 |
Member#: 36075
Vehicle:2004 STi 2.65L GT35R Hydra |
Is there a reason the Front O2 sensor is before the turbo?
I know that most O2 sensors don't depend on where they are located.
But is there soemthing unique about the factory front "Wide-range" O2 sensor that requires it before the turbo? My reason for asking is becuase my new setup was made just for a Hydra and the front O2 sensor bung has been welded shut. I'm now having issues with the Hydra and want to put the stock ECU in, but the only conveniet place I have for yjr O2 sensor now is in the Downpipe behind the turbo. Should there be a problem putting it here? thanks
09-27-2005, 08:53 AM | #2 |
Member#: 21267
Vehicle:STI, EWG 8cm Green UTEC/ECUtek/WI & SD tune |
Jay,
FWIW I have a spare bung if you want me to weld it on in the stock location. FOC I could also redrill the hole and tap a new thread. PM me if you want to go the above. |
09-27-2005, 11:56 AM | #3 |
Member#: 36075
Thanks, actqually the bung is still there and I could probablu get the plug out as it was just lightly welded, my My whole headers in wrapped in about an inch thick of exhaust wrap. I don't really wan to pull the header and revove the 8hours labout it took to do the wrap just to test the Stock ECU for a few minutes.
I'll just put it behind the turbo and see how it works. Jay |
09-27-2005, 02:32 PM | #4 |
Member#: 33410
Vehicle:08 wrx dgm |
i don't have an answer to your question but i do know the JDM twin scroll setup has the o2 sensor a few inches from the turbo in the downpipe.
09-27-2005, 05:12 PM | #5 |
Member#: 36075
Thanks. Thats useful to know.
09-27-2005, 08:29 PM | #6 |
Member#: 36852
Vehicle:2004 STI |
Just a guess, but O2 sensors work best only when they are at a properly temp range. Closer to the exhaust manifold == hotter so the ECU doesn't have to turn on the heater element in the sensor to get an accurate reading?
09-27-2005, 09:17 PM | #7 |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
You want the O2 as close to the cylinders as possible to ensure quick response time.
09-28-2005, 05:51 PM | #8 |
Member#: 36075
OK,
To answer my own question, it appears that it works in the downpipe. It does seem like the AFR takes a bit longer to respond than usual, but it's not a huge problem. This now seems to confirm that all the drivaility issues I was having were with the hydra. Defective unit is the likely cause, but I won't know for sure until I send it back to Element and Phil checks it in a car. With regards to the sensor being as close to the combustion chambers as possible, it makes sense but many 02 sensors are not. Most aftermarket ECUs that run in closed loop (Hydra, AEM) for WOT tuning don't have the O2 Sensor after the turbo. Whether that matters, I don't know. I've also been advised by many (PDX) that if it is too close the the turbo the reading are innacurate. I think becuase of heat, but not sure. thanks Jay |
Is there any way to test O2 sensor readiness? | woodyak | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 04-25-2006 06:07 PM |
is the FRONT O2 sensor a wideband sensor ? | Extraze | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 12 | 07-01-2004 04:21 PM |
Can I use the front O2 sensor for my A/F on my turbo timer? | Got Groceries? | Electrical & Lighting | 4 | 05-29-2004 10:06 PM |
how important is it to get the front o2 sensor replaced? | inpreza kid | Canada Region Forum | 1 | 08-02-2001 02:35 PM |
how do you hook up a voltmeter up to the front o2 sensor? | inpreza kid | Normally Aspirated Powertrain | 2 | 06-06-2001 04:38 AM |
