04-30-2009, 06:12 PM | #326 |
Member#: 152077
Vehicle:2015 Volkswagen GTI Reflex Silver |
I believe in the adage, "it's more fun to drive a slow car fast, than a fast car slow."
Problem with fast cars is that if you drive a fast car fast...you're doing something very dangerous and very illegal... I've actually been acquiring the parts for a VF23 turbo upgrade, but recently decided I don't need that level of power (my WRX is stage 2.)
04-30-2009, 08:00 PM | #327 |
Member#: 112178
Good thread too. I'd reccommend some of these that want 400+whp try a sportbike, do 120mph on that and hit a tiny bump and it can put the fear of God in yah.
I'd be happy with 300whp maybe less. I've read through various threads and it's pretty clear what a stage one setup is and what a stage two setup is (although it can vary, some put on a CAI or do a full TBE instead of just a DP). But what beyond that? Say you have a TBE, CAI and protune. Not sure what that nets you at the wheels but what is normally the next step (if there is one) if you don't plan on doing a FMIC or upgraded turbo? Or is that pretty much what you need to do for more power? This would be on 93oct pump gas. You do get used to the power, my stage one feels quick now instead of **** yeah FAST and its only been 4 months. |
04-30-2009, 08:10 PM | #328 |
Member#: 193353
Vehicle:2004 Subaru STI JBP |
i got 50 whp more to go
05-05-2009, 11:31 PM | #329 |
Member#: 160489
SWIC
Vehicle:15 STI miss my wrx black |
this is a great thread it needs to be stickied! i thought about trying to do hp but thats not what i am going for. i am trying to get it set up for autox so i will do suspension first then hp.
05-06-2009, 12:05 AM | #330 |
Member#: 207263
Vehicle:2019 WRX Limited World Rally Blue |
I have a feeling that the fact that I will eventually get married will mean that there will be a "restriction" on the $$ I can spend on my car without loads of "marital distress." I figure 300 whp is a reasonable goal before said "restrictions" fall into place .
05-06-2009, 12:53 AM | #331 | |
Member#: 191491
NESIC
Vehicle:2011 Forester |
Do it all at once on the DL |
05-06-2009, 01:43 AM | #332 |
Member#: 207263
Eh, it's more about cash flow restrictions than "wifey will be pissed off" restrictions.....though the former usually affects the latter :P.
I'm just trying to be realistic (and considering what I can safely handle). |
05-06-2009, 01:54 AM | #333 |
Member#: 191491
NESIC
god damn you responsible people
05-06-2009, 02:09 AM | #334 |
Member#: 193959
Vehicle:2001 Lexus IS300 05 Wrx AW 18x9.5 WFC#295 |
alright flame suit on.
quick question? how do i pull 300whp out of my 05 wrx my mods right now are hks up megan dp turbo xs catback ssac fmic 12inc cobb short ram stock td04 at 15psi on open source tune about to go 18psi what are my options. im thinking of sti injectors and 18g turbo. not looking to spend to much cash, the soon to be wifey is not to happy with the money issue considering that we're buying a new house. just looking to hit 300whp |
05-06-2009, 02:19 AM | #335 |
Member#: 207263
What's the dyno read-out on your power and torque with those mods?
05-06-2009, 02:25 AM | #336 |
Member#: 193959
dont know yet waiting for final tune hopefully next week if i get my car back from the shop. , but dont know whats wrong with my car yet its something in the tranny and wont go in gear. thinking its the shift forks or
2nd gear went kablamoo. but they should have it started friday so then ill find out what it is. but hopefully itll be done next week, but i think im only getting around 260whp or so not sure though |
05-06-2009, 03:27 AM | #337 | |
Member#: 53558
NWIC
Vehicle:2005 Baja Turbo White/Silver/Black 3tone |
If it was a shift fork problem (keep in mind, I've worked on shift forks in Toyotas and Nissans, not Subarus), it would most likely have a problem going into two gears, but not all 6 (counting reverse here). 1-2 have their own shift fork and share a syncro ring, same with 3-4, 5 has it's own fork and ring, and reverse has a fork that moves a small gear inbetween two other gears. If second went blamo, if it bent the main shaft or output shaft, I could see it throwing everything out so it wouldn't shift into any gear, except maybe reverse would still work, but the car probably wouldn't move. When you find out what happened, try to post pics. I like seeing pics of the insides of our gearboxes, even the glass 5 speeds. |
05-06-2009, 03:34 AM | #338 |
Member#: 193959
i actually got it to go into reverse to back it off the trailer today but it wouldnt go into
1st gear and there is a rattling noise coming from inside the tranny |
05-06-2009, 03:36 AM | #339 |
Member#: 193959
o and the 6mt will cost to much for me.... if im only looking at $700 or $800 im better of just fixing mine i figure rather than spending $3000 to buy a 6MT
05-06-2009, 03:48 AM | #340 |
Member#: 53558
NWIC
Yeah, but what happens when you pop another gearbox?
05-06-2009, 04:09 AM | #341 |
Member#: 193959
idk. .... thatll suck then
05-06-2009, 04:53 AM | #342 |
Member#: 204988
SCIC
Vehicle:2004 WRX |
^^^^ true, maybe fix yours and start saving. the new tranny will be inevitable in the future. (6MT)
05-06-2009, 07:14 AM | #343 |
Member#: 50267
SWIC
Vehicle:02 built hybrid sr55/meth/sick speed |
you guys wil get bored with 300whp if you keep the car long enough. trust me...
05-06-2009, 12:24 PM | #344 |
Member#: 53558
NWIC
I started out with 135 chp. Then I moved to 165 chp. Now I've got 227 chp. Eventually, I'll upgrade my WRX to 300 chp. Then, I'll either stick a 2JZ stroker motor with a GT 60 turbo in it, or I'll just keep gradually upgrading the power in small incriments. This way, I'll never be truely bored with power, and I'll never have more power than I can handle in my car, unless I put the 2JZ in it. Then I'll have a car that just explodes transmissions everywhere.
05-06-2009, 02:38 PM | #345 |
Member#: 163519
Vehicle:2023 GT4RS/GT3/S4 Blue/Grey/Blue |
pshhh 400...I want 450. Ha JK. Great thread. Should be a sticky. After riding in my friends 600 RWHP RX-7 I never want that much street power. I'll take 300 and be perfectly happy.
05-06-2009, 03:46 PM | #346 |
Member#: 184206
SWIC
Vehicle:2013 X1 sDrive 28i gray |
360whp is perfect
And it seems the more power my car has the slower i actually drive normally. I know for a fact that i can beat 99% of the cars around me. . . whats the point of endangering people. I knw my cars fast, HP numbers dont make u speed. they just help. Ill take a 500whp car anyday, i would need new rubber like every 6months but if youre responsible enough to keep the real stuff on the track then why not. I did the sportbike route. . . went 140, and had plenty of near death experiances here in AZ. Point is, for some people the temptation alone is reason enough to limit your car's power. but for others, mod the heck outa it. burn mustangs and challengers at the track, just dont do stupid stuff in school zones and parking lots lol |
05-06-2009, 06:33 PM | #347 |
Member#: 210671
lol y is it always 400hp y not 500-or 600
05-06-2009, 07:44 PM | #348 |
Member#: 191076
South East
Vehicle:2004 STI Java Blk Pearl Stg2 + |
great post!
05-06-2009, 09:10 PM | #349 |
Member#: 197229
SWIC
Vehicle:2006 impreza wrx |
Stickyyyy that thang
05-31-2009, 09:57 PM | #350 |
Member#: 207586
Vehicle:09 WRX white |
Excellent post, good information. Realistically 310-320 in my 2009 wrx doesn't seem to far out of reach and I can't wait....
Public service Announcement for all you white guys. | obyone | Off-Topic | 12 | 06-24-2009 10:20 AM |
the following Public Service Announcement is brought to you by P.A.C.T | Amazake | New England Impreza Club Forum -- NESIC | 16 | 11-27-2003 09:43 PM |
A public service announcement | Midwayman | Mid West Subaru Owners Club Forum -- MWSOC | 15 | 02-25-2001 06:34 AM |
SVX Public Service Announcement | CRZ_MSL | SVX Forum Archive | 2 | 11-22-2000 11:24 AM |
Public service announcement (AKA: Tony eats crow) | Tony | General Forum Archive | 3 | 10-18-2000 06:12 AM |
