02-28-2013, 12:36 PM | #1 |
Member#: 319087
New black filters
So I go to my Subaru dealership to get an oil filter and the parts guys says they got the black one and it's the new style, now does anyone know of the bypass valve rating or anything about the filter other then it is not made my fram and that it is taller?
02-28-2013, 12:45 PM | #2 |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
Any pictures?
I still have a box of over 30 of the old black filters that I got when I bought a closed dealership parts department. I figure that amount should last the life of my wagon. |
02-28-2013, 04:05 PM | #3 |
Member#: 132588
Vehicle:2005 WRX PSM |
Part # might help as well
02-28-2013, 06:11 PM | #4 |
Member#: 171948
Vehicle:19 Sti Crystal white |
there are a few newer black filters. i know of at least 15208aa130 and 160. both are for the newer fb25 forester engines.
02-28-2013, 09:49 PM | #5 |
Member#: 247029
Vehicle:2010 WRX Hatch (02C) Proletariat |
Black filter, japan made, nuff said lol but it is the correct bypass, search it on legacygt.com. Im on my ipad and im too lazy to pull it up. Then go to fredbeans and purchase 12 of them. I ran two of them in a row and got a good blackstone report on the second
02-28-2013, 10:33 PM | #6 |
Vehicle:OK buy Nates beans westcoastroasting.com |
uuuuummmmm....w0w d0000000d....like the dealer is gonna have a SUBARU branded part that is the wrong specs
yeah....w0w...jeeze...maybe...like they jus spray painted them black and sellin counterfit parts or...yeah....thas it |
03-01-2013, 01:44 AM | #7 |
Member#: 180193
Vehicle:04 Forester XT Aspen White |
03-01-2013, 08:58 AM | #8 |
Member#: 186498
I believe the one that guys are using is the 15208AA160 and the corresponding Oil Pan crush ring. The vin will call for the 15208AA12A so it all depends which you want and who you get at the parts counter/forum PM.
-Adam |
03-02-2013, 01:46 AM | #9 |
Member#: 346512
E. Canada
was wondering i got a wrx a few weeks back and noticed thay used a honda fram 3593a i swaped to a mobil 1 filter it was way smaller also used mobil one full sytnthetic did some drifting thiss week now motor has a rod knock i think the drifting caused the knock but u think the filter or oil caused the problem as well also should i use subaru filters and if so what filters should i use on my bug eye after i swap out the motor thiss week ? and oil
03-02-2013, 02:24 AM | #10 |
Member#: 282701
Vehicle:2008 FXT WRB |
Look up Mobil1 5w30 in NASIOC and read what you find. If you have rod knock...save up for a new engine
03-02-2013, 01:27 PM | #11 | |
Member#: 236927
Vehicle:2015 BRZ 86 GL Hatch 1984 BRAT |
Stick with the Subaru filters from the dealer as they are one of the few filters with the correct bypass pressure, and many people on here use Rotella T6 5w40 with great results. Read the oil FAQ here: http://forums.nasioc.com/forums/showthread.php?t=499177 |
03-02-2013, 06:04 PM | #12 |
Member#: 283194
RMIC
Vehicle:2017 STi and '05 WRX WRB and PSM |
15208AA160 gone!
If you find said black filters (15208AA160) you better snag them up. Subaru has now superseded them to a 15208AA15A. (a blue honeywell filter) I've ran the black 15208AA160 on my wrx for the last 2 oil changes, they have the same pressure rating/anti-drain back.... I grabbed a box when I found out they went bye bye, set for the next 100,000+.
03-03-2013, 10:13 AM | #13 |
Member#: 23313
Vehicle:99' 2.5Rs black |
The only black filters that dealers stock are for H6's and the new top mounted FB oil filters. You still can't buy a wrx jdm black oil filter. If you use the filter above that is black you are using the wrong filter on your car.
03-03-2013, 08:01 PM | #14 | |
Member#: 283194
RMIC
15208AA160 - black FB filter (taller) 15208AA12A - blue (correct by vin) It may be wrong by vin. But by psi spec. and anti-drain back valve the 15208AA160 and 15208AA12A are the same. Only differance, half inch taller. Not only do I run the black 15208AA160, but did more then enough research between the two. Cut one apart, (exact internal design of the discontinued Tokyo Roki filters form japanland.) i also read all the Subaru info I could get my hands on. (Easy since I work for a Subaru dealership!) But please tell me why using the FB filter will blow up my car/house/puppy... |
03-03-2013, 08:07 PM | #15 | |
Member#: 23313
But please tell me where I said using the FB filter will blow up your car/house/puppy/reading skills? I stated if you aren't running the "blue" filter you're running the wrong filter on your car. It doesn't matter what research you did or what you cut open or where you work. Subaru specifies you use that filter. If you use on from the fb it is the wrong filter. You attempted to make yourself sound smart when really it was the other way around. |
03-03-2013, 11:54 PM | #16 |
Member#: 247029
It is technically the wrong filter, but so are other filters like purolators that have the wrong psi valve. Those are what i moved on from lol exact oem anything just doesnt cut it sometimes
03-04-2013, 12:24 AM | #17 | |
the wix 57712 fits the 2.5's and has the proper bpv psi |
03-04-2013, 08:08 AM | #18 |
Member#: 247029
My mistake, i shouldve said i used the 4612 a couple times before i knew better lol
03-06-2013, 06:01 PM | #19 |
Member#: 73564
Vehicle:2003 WRX black-no wing no badges |
I'm not comfortable with my ability to parse this discussion.
What's the correct filter for a 2003 2.0 liter WRX? Thank you. |
03-06-2013, 06:27 PM | #20 |
Member#: 23313
You have been on here since 2004 and you don't know what oil filter to use? Kinda weird....anyway the correct filter is part #15208AA12A. That is what will be pulled up by the vin.
03-06-2013, 06:31 PM | #21 |
Member#: 166324
According to the dealership I deal with only blue filters are available for my 02-03 WRX. They have black filters but those are for the BRZ and Foresters ect
03-06-2013, 06:46 PM | #22 |
Member#: 23313
What they are are saying is supposedly the specs are the same as the blue filters just taller and not made by fram. People drool over the jdm black filter because they are supposedly made better. That is what the confusion is here. The major majority of subaru's only call for the blue filters here in the good old USA.
03-06-2013, 07:33 PM | #23 |
Member#: 166324
I'm not in a fit over it at all, just passing on what I was told, when I asked.
03-06-2013, 07:45 PM | #24 |
Member#: 23313
I'm letting you know what you were told is true. This is not new information. I was trying to catch you up to what is being talked about in this thread. Yes there is only one filter made for the wrx currently.
03-06-2013, 08:41 PM | #25 |
Member#: 49998
RMIC
Vehicle:2017 WRX MT6 WRB |
I've used nothing but stock filters, and have had very low insolubles showing up in my UOAs. Clearly, they're working well.
