02-11-2002, 04:36 PM | #1 |
Member#: 14921
Vehicle:'02 WRX Sedan Midnight Black Pearl |
Need Help?!?!?!?! MBC or EBC?!?!?!?!
hey guys, as you can see i'm a newbie and i'm askin for a lil help. whats the difference between a MBC and an EBC. also, which would you prefer and what are the benefits and drawbacks for both. thanx alot guys.
SubieNubie
02-11-2002, 04:58 PM | #2 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
I'll let somebody else answer the question however please refrain from all the ?!?!?!?!?!?! in the subject line as it is completely uneccessary... we try to keep this place tidy .
Brian http://www.northursalia.com http://www.imprezamods.com http://www.scoobymods.com |
02-11-2002, 05:06 PM | #3 |
Vendor
Member#: 9224
Vehicle:2004 STI 12.88@ 106.2 in my WRX |
1 is manual and 1 is electronic just kidding
manual is good and cheap electronic is better and will make more HP but cost more money some people say a MBC can make just as much power but that is not true. it can make the same peak boost level but it will not be able to hold the pressure like a EBC can with a MBC you may get 10lbs is 1st , 12lbs in 2nd and 14lbs in 3rd and so on. with a EBC you will get what ever you set it at in 1st, 2nd, 3rd and so on as long as it's set correctly. now if you set the boost for 15lbs with a MBC and get 15lbs in 4th or 5th you will not get that in 1st...you may only get like 12lbs or so. you will get that extra 3 lbs in 1st with a EBC so if those 3lbs extra in 1st translates into more power EBC is better but more money MBC is a nice cheap, easy mod to make somewhat close to EBC power. all depends on what you want to spend fastline |
02-12-2002, 12:22 AM | #4 |
Member#: 14921
bump....
02-12-2002, 10:31 AM | #5 |
Member#: 14921
ttt
02-12-2002, 10:42 AM | #6 |
Member#: 10788
RMIC
Vehicle:2019 Tesla Model 3 Midnight Silver Metallic |
MBC is btw $1 & $110
EBC is btw $300-$500 most EBCs will let you adjust your boost depending on throttle position and/or by gear. You won't need a boost gauge to keep an eye on your boost because it'll be included in the readout. MBC is cheaper, easier to take out too. You'll have to get a boost gauge. If you are thinking of getting an EBC, you might as well get a chip instead. ~$700 |
02-12-2002, 05:11 PM | #7 | |
Vendor
Member#: 9224
fastline |
02-12-2002, 06:40 PM | #8 | |
Member#: 8804
South East
Vehicle:2008 Impreza STi Dark Gray Metallic |
02-12-2002, 08:04 PM | #9 |
Member#: 14921
Thanx.
thanx alot for all the help guys. this will really helping my decision. any more suggestions?
SubieNubie |
02-12-2002, 11:00 PM | #10 | |
Member#: 9211
SWIC
Vehicle:2002 wrx wrb swankmonkey.com |
Re: Thanx.
YMMV, but it's your car and I have a feeling you are going to do what you want to do! |
02-12-2002, 11:04 PM | #11 | |
Member#: 5756
Vehicle:2004 Jeep Rubicon Black |
Re: Re: Thanx.
02-13-2002, 12:04 AM | #12 |
Member#: 8804
South East
No, it won't display EGTs. You need an EGT gauge and an EGT probe, which goes into your exhaust manifold.
The only thing an EBC may display is boost pressure and maybe vacuum. |
to buy an MBC or EBC or wait for UTEC? | M32WRXin3seconds | Newbies & FAQs | 8 | 05-24-2003 12:53 AM |
Anyone running upgraded turbo only w/ MBC or EBC? | WRXVII | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 01-07-2003 11:09 PM |
WRX: Superchips vs. just mbc or ebc | cmb | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 25 | 11-27-2001 07:31 AM |
MBC or EBC | scoobyboost | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-17-2001 11:27 PM |
