01-20-2012, 11:52 AM | #1 |
Member#: 158123
5-10% Off Our Most Popular Services - IAG Performance Service Special Sale is ON!
For a limited time, we are offering discounts on all of our regular MAIC Service Special Thread prices! The best service deals in the area just got better! Call, PM, or email to schedule your service today!
FREE Alignment Check Special Call now to set up your free alignment check using our floor mounted Hunter RX Scissor Lift Rack and HawkEye High Definition Digital Imaging Wheel Alignment System. A quality alignment is essential for safety/drivability, good handling, and consistent tire wear. Have your alignment checked 100% free-of-charge, and we will supply a printout of alignment results for your records. Once you're on the rack, if you decide to have us perform a 4-wheel alignment, we are offering 10% off our regular alignment price of $99! Join 1000+ Subaru owners in the area who have experienced the IAG Performance Alignment***8230; Satisfaction guaranteed! IAG Performance Subaru Scheduled Maintenance Services 30,000 & 90,000 Mile Service - Was $399 - NOW $379! -Oil change using your choice of Motul, Eneos or Valvoline Synthetics -K&N or Purolator Pure One Oil Filter & new drain plug washer -Replace Transmission Fluid w/ Motul 75w90 (Motul Gear300, Extra-S, and other fluids available upon request) -Replace Differential Fluid w/ Motul 75w90 (WRX) or Motul PA 90 (STi) -Coolant flush and inspect cooling system, hoses and connections. Global coolant w/ 1 bottle of Motul MoCool -Air Filter Service (replace factory filter w/ K&N Drop-In, or clean & lubricate existing filter) -Flush & replace brake fluid w/ your choice of Ate SuperBlue or Motul DOT 5.1 -Inspect brake pads and rotors -Inspect brake lines and check operation of parking brake -Inspect Front & Rear axle boots and axle shaft joint portions -Inspect clutch operation -Inspect Steering & Suspension -Inspect tires & rotate -PCV Valve -Top-off all fluids -Replace fuel filter (vehicles vary) and inspect fuel system 60,000 Mile Service - Was $499 - NOW $474! -All services performed in 30K Service -Change spark plugs 105,000 Mile Service - Was $899 - NOW $854! -Replace Timing belt -Replace water pump & water pump gasket -Replace thermostat & thermostat gasket -Flush coolant & inspect cooling system. Global coolant w/ 1 bottle of Red Line Water Wetter or Motul MoCool -Crank Seal -A/C & P/S Belts -Cam Seals -Timing belt tensioner Timing Belt/Water Pump Service Only - Was $499 - NOW $474! Brake Packages Stage 1 Hawk HPS Front/Rear Pads Techna-Fit SS brake lines Motul DOT 5.1 or Ate SuperBlue WRX - Was $499 - NOW $474 Installed STi - Was $549 - NOW $522 Installed Prices vary - Also available for other Subaru models - Call/PM for details and pricing! Stage 2 Hawk HPS Front/Rear Pads Techna-Fit SS Brake Lines Motul DOT 5.1 or Ate SuperBlue DBA 4000 Series Slotted Rotors WRX - Was $1049 - NOW $997 Installed STi - Was $1199 - NOW $1139 Installed Prices Vary - Also available for other Subaru models - Call/PM for details and pricing! Suspension Services Alignment/Corner Balancing Performance Alignment - Was $99 - NOW $94! Performance Alignment & Corner Balancing - Was $199 - NOW $189! Install Springs/Coilovers (purchased @ IAG) w/ Performance Alignment - Was $299 - NOW $284! Install Customer supplied springs & alignment - Was $349 - NOW $332! Install Customer supplied coilovers & alignment - Was $399 - NOW $379! *Coilover installation includes initial ride-height set-up. Additional changes to ride height are extra. Alignments are subject to additional charges for extra time (seized bolts/hardware, extreme fitment/aggressive set-ups, etc.) Fender Rolling Services - 10% Off! 10% Off Regular Fender Rolling Prices! CALL FOR DETAILS! Guideline for our basic pricing can be found here: http://www.iagperformance.com/fender...g_service.html Fender rolling service pricing may vary depending on vehicle/extent of service - Call/PM for details and scheduling info! Transmission Services Exedy Clutch Specials Exedy Stage 1 clutch package - w/ resurfaced flywheel & Motul or Eneos 75w90 fluid WRX - Was $899 - NOW $854 Installed STi - Was $999 - NOW $949 Installed Prices Vary - Also available for other Subaru models - Call/PM for details and pricing! Exedy Twin-Plate clutch package w/ performance flywheel & Motul or Eneos 75w90 fluid WRX - Was $1999 - NOW $1899 Installed STi - Was $2099 - NOW $1994 Installed Prices Vary - Also available for other Subaru models - Call/PM for details and pricing! ACT Heavy Duty Street Specials 06+ WRX Special - ACT Heavy-Duty Modified Street Clutch, resurface factory flywheel - Was $1149 Installed with your choice of fluids - NOW $1092! 05-09 Legacy GT Special - ACT Heavy-Duty Modified Street Clutch with your choice of ACT Streetlite or Subaru OE 06-07 WRX Flywheel - Was $1399 Installed with your choice of fluids - NOW $1329! 04+ STI Special - ACT Heavy-Duty Modified Street Clutch with resurfaced flywheel for 04-09 STI 6-Speed - Was $1249 Installed with your choice of fluids - NOW $1187! OEM clutches & other Exedy and ACT Packages Available Upon Request!!! Accessport/Protune Special As always, buy your Cobb AP from IAG & Receive $100 off protuning - AP/Protune Combo = $995 Window Tint Window Tinting @ IAG Performance - $10% off*! Our window tinter has been in the business for over 15 years, and does an absolutely incredible job. We offer Johnson high quality window films, available in shades from MD legal all the way to limo dark. Our tinting services come with a lifetime warranty against bubbling, peeling, fading, purpling, hazing, & more. If you're looking for high-quality tint for your Subaru, shoot us a PM or call at the shop any time! *Vehicle doesn't have to be a Subaru, but you MUST mention this ad to receive 10% off window tint - This is a NASIOC-only special!!! IAG Performance 1203 Baltimore Blvd. Westminster, MD 21157 410-840-3555 www.iagperformance.com [email protected] Like us on Facebook for shop news/updates & Special Deals! www.facebook.com/iagperformance
06-27-2012, 01:26 PM | #2 |
Member#: 248596
Vehicle:2013 WRX black |
Is this still going on? Do you charge more to mount and balance tires, if not purchased through your shop?
07-09-2012, 03:36 PM | #3 |
Member#: 214346
If you guys carry Cusco 2E's, can you please pm a quote of them shipped to 14586 for a '09 WRX?
07-13-2012, 08:42 AM | #4 | |
Member#: 158123
PM'd you. |
Similar Threads | ||||
IAG Performance Service Special Thread - Now Including Mobile Electronics Specials!!! | IAG Performance | MAIC Vendor Classifieds | 450 | 01-06-2012 01:18 PM |
IAG Performance Holiday Specials - KillerB, ID, Walbro, TONS More!!! | IAG Performance | Engine/Power/Exhaust | 17 | 03-02-2011 05:45 PM |
IAG Performance Holiday Special Service Thread: Free Services & Discounts? Mmmhmmm! | IAG Performance | MAIC Vendor Classifieds | 27 | 01-02-2010 06:16 PM |
The IAG Performance Service Special Thread! | IAG Performance | Services | 29 | 11-23-2009 07:52 PM |
