11-20-2015, 08:27 PM | #17401 |
Member#: 233192
Vehicle:2013 Legacy Black |
That last one is rather obnoxiously loud. The Tsudo sounded the best.
12-06-2015, 06:49 PM | #17402 |
Member#: 330830
Vehicle:2010 Impreza2.5i 5dr Obsidian Black Pearl |
12-06-2015, 06:50 PM | #17403 |
Member#: 346009
NESIC
Vehicle:2009 Impreza 2.5i Newport Blue Pearl |
Street sweeper crew, looks like a great Sunday drive
12-07-2015, 04:46 AM | #17404 |
Member#: 435637
Vehicle:2008 Impreza Black |
My plain (or vanilla) 2008 Subaru Impreza 2.5i (Premium) that's lasted me quite a few years. Only recently have I started to have issues with it due to a bad timing belt job done in Nov '15 that's caused my off-highway MPG to drop drastically and lead to some crappy low-end power issues.
Beyond that, I've been looking at the 2016 Subaru WRX for a little while now as a soon-to-be replacement. But issues aside and the possibility of looking at a newer, faster model, it's been the most reliable, trouble-free car I've ever owned... and I've owned 5 other cars. |
12-07-2015, 05:40 AM | #17405 | |||
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
12-07-2015, 09:53 AM | #17406 |
Member#: 211395
South East
Vehicle:0000 4wfp Flintstone Mobile made of stone+wood |
12-12-2015, 11:07 AM | #17407 |
Member#: 346009
NESIC
Finally found a RS badge that wasn't $70, cleaned it up and have it some fresh paint to match my theme. Kind of nice to pay respect to the older generations of our 2.5i's
12-12-2015, 05:06 PM | #17408 |
Member#: 416465
NESIC
Vehicle:2009 Impreza 12 WRX |
That looks good. Not ricey
12-12-2015, 06:06 PM | #17409 |
Member#: 346009
NESIC
Thanks man, I've been wanting either the jdm or Australian badges for a while and thought they always looked good. I spent like 20 minutes at home depot deciding between yellow white and red, thought the red would look the best with the brake lights.
12-12-2015, 08:47 PM | #17410 |
Member#: 411867
E. Canada
Vehicle:2011 Impreza 2.5i WRB |
Anyone here can help me build a hybrid for my 2011 2.5i?
Im looking at cosmo sri. I just haveno clue how to extend the pipe to reach the airbox. Also im not sure if its maf or map. Pls heeeeelp. |
12-12-2015, 09:10 PM | #17411 | |
Member#: 262503
Vehicle:2008 Impreza 2.5i |
Pointless to do unless you're getting a tune. It's going to literally do nothing anyways. |
12-12-2015, 09:12 PM | #17412 |
Member#: 411867
E. Canada
I plan to tune to 91. Also.i read williaty's thread and it is plausible.
12-12-2015, 09:16 PM | #17413 |
Member#: 262503
12-12-2015, 09:18 PM | #17414 |
Member#: 411867
E. Canada
Well what the hell are you doing in this threas fancyfootwork15 ?
12-12-2015, 09:33 PM | #17415 |
Member#: 416465
NESIC
12-12-2015, 09:42 PM | #17416 |
Member#: 411867
E. Canada
12-13-2015, 02:22 AM | #17417 |
Member#: 262503
12-13-2015, 03:00 AM | #17418 | |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
For the record, Fancy is right. I got better results from changing the filter than changing the pipe. |
12-13-2015, 10:30 AM | #17419 | |
Member#: 346009
NESIC
If you change your pipes and sit on it for 6 months or a year you'll be shortening the life of your engine quite a bit. You'll instantly be running too lean, the ecu will indeed compensate for it somewhat but it won't be enough. Find your tuner first and talk to them about it! They'll have good insight on this project |
12-13-2015, 11:03 AM | #17420 |
Member#: 349386
Vehicle:2019 WRX Limited Lapis Blue Pearl |
I just wanted to reinforce the correct info in this thread because this is one of the biggest misstatements that I hear when people say the rear end sags.
Almost all cars have a larger wheel well cut-out in the front than in the back. This is because the front wheels HAVE TO TURN. They need more room than the rear wheels. End of story. The fender gap is bigger in front but the car is level. If you tune your ride height based on fender gap then the car will be pitched forward more than stock which may or may not be desired. |
12-13-2015, 01:21 PM | #17421 |
Member#: 346009
NESIC
What do you guys think? I haven't clear coated it yet so I can take the vinyl off...
12-14-2015, 12:31 AM | #17422 |
Member#: 330830
12-14-2015, 12:40 AM | #17423 |
Member#: 346009
NESIC
Those look great, really good color choice. Hope the ice and salt,this winter doesn't chew it up too badly
12-14-2015, 08:48 AM | #17424 |
Member#: 408055
Vehicle:2008 Impreza 2.5i Dark grey |
12-14-2015, 09:25 AM | #17425 |
Member#: 346009
NESIC
Indeed, I roughly cut the shape of the whole bar and after getting it on I cut the emblem and sealed the corners.
Note: do NOT spray a clear coat on the 3m vinyl, it'll melt the surface and make it flat black. Learned that the hard way after trying for 3 rounds and finally getting a wrap I liked, sprayed it and in 2 minutes it was fried ugh. I'm going to coat it with a uv preventing wax hopefully that'll make it last a little while. Not too concerned if not though considering its fake carbon fiber wrap WOOOO |
What's the widest tire that can be put on the 2.5i? | SubieSubie | Impreza Forum | 21 | 07-25-2017 08:51 AM |
Will the STi Front and Rear Bumper will fit on the 2.5i? | GD6Noob | Interior & Exterior Modification | 7 | 04-30-2012 08:33 PM |
Wheels that fit the 2.5i and the best offset. | VIsubi | Tire & Wheel | 2 | 06-23-2010 09:19 PM |
Test Drove the 2.5i Legacy at SoD | maclif | Texas Impreza Club Forum -- TXIC | 8 | 06-02-2004 08:42 PM |
