07-15-2007, 09:41 AM | #1 |
Member#: 82487
Vehicle:2007 WRX STI Spec C |
CEL flashing = knock or misfire??
I read that on a stock ECU, CEL flashing is misfire. But what about on a Ecutek flashed ECU?
some background info: PE650 injectors, 255 pump Deadbolt TD05-18G Greddy RSPL FMIC TBE AVCR Car was protuned by local tuner with Ecutek with AVCR set to around 22psi. He has done a pretty crap job at it. car sputters alittle when moving off after extended idling and i can't hit target boost in 1st and 2nd. anyhow, i was doing some spirited driving the other night and after which, the car felt sluggish the next day. On my way to work, the CEL flashed a coupla times when i stopped at the lights.
07-15-2007, 01:56 PM | #2 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
ECUTEk reflashes will display knock by flashing the MIL. If it's a steady flashing it's a misfire, but if it illiminates a little at a time that's knock.
07-15-2007, 02:03 PM | #3 |
Member#: 82487
what is MIL??
The car felt sluggish after 4000 rpm, but no flashing of CEL at all. It only started to flash (5-6 consistent flashes) after i stopped at the lights idling. I was thinking if it is knock, shouldn't it flash during load (when boosting)?? |
07-15-2007, 02:57 PM | #4 |
Citizen Mick
Member#: 27646
Vehicle:2003 Sleeved 2.5 Oil Dry Sump Goodness |
EcuTek does not flash the CEL for knock, only misfire
Sounds like a mechanical problem to me, bad plugs, boost leak, vac leak |
07-15-2007, 06:19 PM | #5 | |
Member#: 144399
SWIC
Vehicle:2005 WRX STi stage 2 white Romraider tuned |
07-15-2007, 06:21 PM | #6 | |
Member#: 47145
Vehicle:2012 Gas Saver |
More than likely the tuner did not get the injectors dialed in properly....pretty common with the PE injectors... |
07-15-2007, 09:24 PM | #7 |
Member#: 82487
I'm not sure if the CEL flashing has anything to do with it though but i'm pretty sure the injectors are NOT dialed in because i'm sputtering when moving off with the aircon on and in traffic. its annoying!!
07-15-2007, 09:28 PM | #8 | |
Member#: 6551
and yes, go back to the person that tuned that vehicle. |
07-15-2007, 09:32 PM | #9 | |
Member#: 82487
AFAIK, the 02 ECUs are extremely sensitive and go into limp mode easily. It doesn't help that the ambient temp here is HOT around 90 deg. I installed a EBC and it didn't happen again till this shi**y tune. |
07-15-2007, 11:05 PM | #10 | |
Member#: 6551
07-16-2007, 05:07 AM | #11 | |
Member#: 82487
so in a nutshell, CEL flashing on Ecutek and stock ECU = misfire and on UTECs = knock? Thanks guys one more thing, how does misfire cause the ECU to go into limp mode? i thought it only goes limp mode when it senses knock? Last edited by Suberman; 07-16-2007 at 05:13 AM. |
07-16-2007, 05:23 AM | #12 |
Member#: 6551
IAM= Ignition Advance Multiplier, that's bascially what the ECU uses to determine the health of the engine/conditions in which it's under. Normally the ECU won't switch to limp mode(wastegate pressure) until 6(normally the ECU would be at 16). You really need to do some type of datalogging as there's no reason you should end up in Limp mode with those kind of temperatures. Hell it's easier to tune a car if your weather never changes, try tuning it when it's 95 then have the car start when it's -10
Similar Threads | ||||
Excessive knocking causing misfire CEL? | mxpunk | Open Source Reflashes | 2 | 03-10-2009 05:02 PM |
04 sti misfire help cel flashing | rsbiggart | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 10 | 02-10-2008 07:40 PM |
Experiences with SOA ECU re-flash for P0301 misfire CEL/MIL? | buddha_1976 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 02-07-2005 02:08 PM |
Knocking Or Misfiring!?! | WjRgX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-30-2003 04:57 AM |
A UTEC question - flashing CEL, no knock seen on data log..what gives? | LargeOrangeFont | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 10-03-2003 03:33 PM |
