06-22-2016, 03:51 PM | #2426 |
Member#: 328635
Vehicle:2004 STi GTX3076R Rally Blue |
^^^ why not clock the turbo so you don't have the charge pipe making such a long loop to the front?
As for the "can I grind this off my intake manifold" thing i would grind it in a second and not look back. Not like your risking a hard to replace/find part. But I also tend to lean towards cutting/grinding on your car. Lol
06-22-2016, 06:53 PM | #2427 |
Member#: 425386
The picture doesnt do it justice. The way I went only added 12in of pipe. I couldnt clock the turbo without buying braided oil line and power steering line. Also I recirc the bov, so a pipe was needed close turbo inlet
06-25-2016, 11:49 PM | #2428 |
Member#: 425386
07-22-2016, 03:40 PM | #2429 | |
Member#: 220816
Vehicle:2018 Exotruck |
swapped out the vf43 for a 50trim and fixed up the intercooler piping |
07-22-2016, 05:32 PM | #2430 |
Member#: 425386
Hows it driving with no p.s.
07-22-2016, 06:24 PM | #2431 |
Member#: 220816
07-22-2016, 06:30 PM | #2432 |
Member#: 358782
Vehicle:2013 STi DGM |
07-22-2016, 07:06 PM | #2433 |
Member#: 220816
07-22-2016, 08:39 PM | #2434 |
Member#: 176134
SCIC
Vehicle:1995 Coupe, Sedan & Wagon! |
Like.
07-25-2016, 09:31 AM | #2435 |
Member#: 141043
Vehicle:2011 STI black af |
Great write up.
-leo at MAP! |
08-04-2016, 02:20 PM | #2436 |
Member#: 35944
South East
Vehicle:'03 EJ257/EFR/G4+ MBP |
Great thread! working on my mani flip currently, making some progress.
v7 swap Ported TGV's and had them and mani coated. TB coolant bypass Extended the tps wires...couldn't get enough length from de-looming to be comfortable with. Bent the oem fuel lines some and cut off the mounting points on the underside. Jdm mani had a plug in back so I took that out and using for brake booster. Tapped hole for stock fpr vacuum line so it fits like stock. Relocated purge valve. Ordered 07 sti alternator, only $50 shipped on ebay. Haven't figured out what to do with PCV yet. |
08-04-2016, 07:10 PM | #2437 |
Member#: 176134
SCIC
Sad to say my set up will be posted for sale later today
08-04-2016, 07:31 PM | #2438 |
Member#: 220816
08-04-2016, 07:48 PM | #2439 |
Member#: 176134
SCIC
No job since Jan. Back to stock, car for sale too.
08-07-2016, 10:54 PM | #2440 |
Member#: 303442
Vehicle:2008 STI Silver |
I've been following this thread for a while and I finally worked on my version of "reversed intake". I am an AutoX driver and wanted to reduce the amount of piping to help me spool up quicker. I am running a GTX3076 and put down about 420 AWHP in the previous config. There were a couple changes during this project so whatever difference I see will be a result of all the changes.
New engine wiring harness. New "forward facing" intake Cleaned injectors (ID1000) Smaller hot side for turbo (from a 0.82 to a 0.63) Anyway.. Here is before and after pictures. Going to get the intake piping fabbed up this week. Then we will know if this intake can flow enough to keep me happy or if I wasted 8 hours putting this together! Last edited by 3Dglasses; 08-07-2016 at 11:01 PM. |
08-08-2016, 06:11 AM | #2441 | |
Member#: 220816
and i see your running your boost controller off an intake port, thought that was a nono edit for funk Last edited by no694terry; 08-08-2016 at 08:35 AM. |
08-08-2016, 06:46 AM | #2442 |
Member#: 245787
W. Canada
Vehicle:GD Race Car |
^^^ thanks for quoting the post directly above you with all the pics....
3dglasses, that piping off the turbo is a mile long, i would have stayed with the sti manifold so you could shorten the piping by going under the manifold and then reverse it to shorten the cold side also by going down where your overflow tank is. Or make a dual Pass IC and both pipes go down the passenger side. |
08-08-2016, 08:30 AM | #2443 |
Member#: 220816
lil something i been woking on so i can make the switch to 1000cc topfeeds
i brought it into work today to get the butterfly holes welded shut and then sandblast the hole thing |
08-08-2016, 08:50 AM | #2444 | ||
Member#: 303442
The car has always had the EBC running off the intake. Quote:
08-12-2016, 02:40 PM | #2445 |
Member#: 220816
topfeed mani about finished
08-21-2016, 12:30 PM | #2446 |
Member#: 220816
Forgot to update
08-21-2016, 02:38 PM | #2447 |
Member#: 176134
SCIC
So fresh and so clean!
08-24-2016, 08:51 AM | #2448 |
Member#: 174698
08-24-2016, 08:59 AM | #2449 |
Member#: 174698
08-29-2016, 09:44 PM | #2450 |
Member#: 279176
Vehicle:2006 Sti SGM |
Similar Threads | ||||
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange | White 2.5rs | Engine/Power/Exhaust | 6 | 04-02-2007 01:24 PM |
F/S: Borla header, Intake manifold, TB, TGV | 01G_WRX_02 | Private 'For Sale' Classifieds | 14 | 03-03-2006 05:44 PM |
'02-04 WRX intake manifold/tb/sensors | annointed | Private 'Wanted' Classifieds | 6 | 03-05-2005 02:30 PM |
ej22 intake manifold, tb, coil | mr. m | Private 'For Sale' Classifieds | 7 | 07-01-2004 08:40 AM |
WRX intake manifold/TB question | black knight | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 04-20-2003 10:58 AM |
