05-14-2013, 07:23 PM | #551 |
Member#: 354019
Boosted tuning in Chico ca said I should do a road tune. Not REMOTE. You really don't know what that means!!?
05-15-2013, 12:09 AM | #552 |
Member#: 164437
RMIC
Vehicle:EVO IX - Track Car BRZ - Daily |
lol who is this guy?
05-15-2013, 01:20 AM | #553 | |
Member#: 199836
RMIC
Vehicle:2011 STi DGM |
I ran E85 when the draper pump had it in my 08. Availability has been why I haven't till now. Running pump gas has proven to be problematic as it turns out we have ****ty pump gas in utah, who knew? 110 in the pump didn't make any more power then 91 given how much timing it took to just meet what I made on 91. Not to mention it is spendy. There are other options obviously, but E85 will probably work for me given that I don't drive my sti alot. Although a new job may change that How does one go about talking a local station into installing an e85 pump? |
05-15-2013, 01:57 AM | #554 |
Member#: 354019
05-15-2013, 02:20 AM | #555 |
Member#: 183634
RMIC
Vehicle:02 wrx/ 92 ss Booze fueled :) |
05-15-2013, 02:26 AM | #556 | ||
Member#: 183634
RMIC
05-15-2013, 02:29 AM | #557 |
Member#: 354019
He also does remote tunes
05-15-2013, 02:41 PM | #558 | ||
Member#: 99442
International
Vehicle:2006 SGM STI I'm on CORN YO! |
05-15-2013, 04:13 PM | #559 |
Member#: 164437
RMIC
I wasn't asking who the tuner was, I was asking who you are lol.
05-15-2013, 08:44 PM | #560 |
Member#: 35276
RMIC
who knows a service station owner in slc that we could tak into buying e85 for their pump
05-15-2013, 09:38 PM | #561 | |
Member#: 199836
RMIC
Also it was specifically the 110 out of the draper pump, the sunco 110 makes power but isn't available right by my house. |
05-15-2013, 10:24 PM | #562 |
Member#: 35276
RMIC
I made a ton of power out of the 110 off the draper pump.
05-16-2013, 12:18 AM | #563 | |
Member#: 242377
RMIC
Vehicle:2006 Legacy GT Wagon For Sale |
05-16-2013, 12:36 AM | #564 |
Member#: 199836
RMIC
05-16-2013, 01:27 AM | #565 | |
Member#: 183634
RMIC
Of the several dom1.5 set ups i've tuned the difference between 91 and 110+ octane is around 4-5 degrees of timing to achieve MBT (depending on how much the 91 map was pushed). E85 is different in terms of MBT, but it's very similar to leaded gases in terms of being able to significantly advance timing past MBT. Most race gases get the octane from Tetraethyllead(same with aviation). And as far as boost is concerned try 23-24lbs on pump and 28+ on some higher octane and see how she goes (i'm assuming a built motor here ). This same misconception is present with E85, that it burns slower. When in fact it burns amazingly faster: http://www.epa.gov/OMS/presentations/gni-mjb-051303.pdf Scroll down to slide 9. This with it's lambda of 9.0 before adding in gasoline makes E85 an amazing gas! Pack that cylinder with lots of cooling and make it escape quickly! Then there are the oxygenated fuels, the Ethanol and race gas blends etc. |
05-16-2013, 01:32 PM | #566 |
Member#: 101464
05-16-2013, 02:36 PM | #567 |
Member#: 199836
RMIC
If it doesn't burn slower then why does it require more advance to make the same MBT?
Exactly that was the plan, but the turbo just wouldn't make that much boost. Duno what the issue is, maybe its the equal length setup and the bigger hotside combo. Thats why I couldn't make alot more power. I couldn't run alot more boost then what I was running on pump. |
05-16-2013, 02:53 PM | #568 | |
Member#: 183634
RMIC
I'm not sure why your turbo won't run that much boost, even with a 14.7lb wg you should still be able to hit 24-25ish psi. With the 110(or other increased sources of octane) there are other methods to increase power output safely. There is no reason for your car to have less output on race gas, unless the tune was set up that way. |
05-16-2013, 11:14 PM | #569 |
Member#: 143264
RMIC
Vehicle:2006 WRX TR Obsidian Black Pearl |
I was talking to the Manager at Jensens Oil on redwood and about 4800 south. They said if we got a petition together of all the E85 enthusiasts and it substantial enough, they would consider doing a tank up here. They said that their concern with doing this is that nobody would buy it and the product would "spoil" before it sold.
I would be game for E85 at Jensen's oil on Redwood. |
05-17-2013, 02:46 AM | #570 |
Member#: 35276
RMIC
05-17-2013, 09:54 AM | #571 |
Member#: 199836
RMIC
How many signatures does he want?
05-17-2013, 03:45 PM | #572 |
Member#: 143264
RMIC
I have no clue how to go about doing it. Maybe if we just had them hang a sign and we went in with signatures at the location?
05-17-2013, 04:17 PM | #573 |
Member#: 290178
RMIC
Vehicle:2008 DGM STi-Ituned 2008 R6 |
Maybe create a new thread for signatures, post a link to where it is located on google maps. Go around to different forums whoring out the link etc. I'm sure you'll get enough e-signatures. There is most definitely a potential market for E-85 in SLC valley.
05-18-2013, 12:44 AM | #574 | |
Member#: 242377
RMIC
everything sti related | DCsubieSTI | Newbies & FAQs | 6 | 04-25-2010 09:26 PM |
E85 near seattle? and other related questions... | CheapShot | Newbies & FAQs | 4 | 10-22-2009 05:05 PM |
FS: 1998 OBS and everything Subaru related I own cheap | rabbitnutz | NESIC Private Classifieds | 43 | 06-11-2009 10:42 PM |
03 WRX parts... EVERYTHING ENGINE RELATED!!!!!! | drifmtaster04 | Engine/Power/Exhaust | 47 | 04-29-2009 07:20 PM |
List everything non-work related that's on your work area. | Stroke | Off-Topic | 20 | 06-23-2004 07:10 PM |
