08-21-2012, 11:31 PM | #1 |
Member#: 319773
Vehicle:2005 wrx sti black |
meth question
Thinking about getting a aem meth kit but I want to know if I need a special tune or if I can just hook it up and go? I have a cold air intake a full tbe exhaust and Cobb ap stage 2 tune. And should I get any other mods before I get a meth kit? Or am I fine with what I have? Any input is great as to what I should do
08-22-2012, 01:01 AM | #2 |
Member#: 217458
VIC
Vehicle:1989 Mazda Miata Classic Red |
You will want to get it tuned. I suppose you may be able to run the smallest nozzle without any danger of harming your engine. But you will not see any power gains until it's tuned.
10-03-2012, 06:08 PM | #3 |
Member#: 278263
A tune is always recommended with added mods on these cars.
Meth is a fuel, so if you install it and drive it w/o a tune you will be running rich on WOT. If your too rich, you'll get bore wash & murder your motor slowly. The tune is needed to adjust your fuel trims to make it a tad leaner (since you can w/ meth) & increase boost to make more power. It burns hotter thus, creating mad torque & spool. A tune tells the ecu how to compensate for the meth & make it work with your car, not against it. |
10-08-2012, 06:34 PM | #4 |
Member#: 290921
AKIC
Vehicle:2010 Impreza WRX prm WR Blue |
I'm thinking of doing the same do to Alaska not having above 90 oct. just curious on what every one thinks about the meth kits, any issues, problems, likes, dislikes. Right now I have a full setup on my 2010 WRX
336 WHP / 343 WTQ 2010 Subaru Impreza WRX tuned at COBB Tuning's facilities in Plano, TX. ProTuned using the COBB AccessPort on 91 Octane. http://www.cobbtuningplano.com Primary Power Modifications: COBB AccessPort Tomioka TD05-20G COBB SS DP SPT Carback Exhaust Perrin FMIC COBB SF Intake + Box AVO TIP ID1000cc Injectors Walbro 255lph FP Crawford AOS 3-Port EBCS 91 Octane Click below to see this dyno graph on our Dyno Database: http://accessecu.com/dyno/index.php?...rgb1=000000255 |
10-08-2012, 06:47 PM | #5 |
Member#: 329319
Meth is awesome for people who don't have access to higher octane fuels. You have to be careful when tuned for it to not run out during a pull, but as long as you are mindful of how much you have in the tank, it makes for a great way to safely increase power.
