01-28-2013, 08:14 PM | #1 |
Member#: 281019
South East
Vehicle:2011 Impreza WRX WRB |
2011 wrx overboost with ap ots stage 2
So I was on the way home tonight cruising in 5th gear, downshifted into 4th then 3rd and gave it a boot full. Normally the car hits target boost around 17psi +- a little. However this time it spiked at 20psi around 5500 rpm, then hit what sounded like a rev limiter, then it lost power. I looked down and the whole dash was lit up. CEL, Traction control and flashing cruise light. I checked the code and it was a turbo/waste gate (A) solenoid (parameter/performance) code. I was thinking maybe the solenoid is going bad and the waste gate is staying closed? I'm not sure. Also after the event I noticed the car building boost ALOT quicker than it used to. Any ideas/ thoughts/ help would be awesome. Thanks guys!
Car is running Cobb OTS stage 2 AEM 93, Full Invidia TBE and AEM CAI.
01-28-2013, 08:18 PM | #2 |
Member#: 308550
Vehicle:2006 Wrx STi Aspen White |
I think what you are experiencing boost creep. But what you need to do is a 3rd gear pull from around 2000rpm if you can do so safely.
01-28-2013, 08:36 PM | #3 |
Member#: 297565
Vehicle:2011 WRX hatch Silver |
I would def pull a log. Could just be a freak boost spike. Won't realize without more info.
01-28-2013, 08:43 PM | #4 |
Member#: 308550
As I understand it "boost spike" can occur when a car will hit peak boost. For example if his peak boost was 17psi and he hit 20 psi at 3800 rpm this would be a boost spike. Boost creep is when boost isn't tapering down to 14.5 psi for example. Boost creep occurres when the waste gate cannot pass enough exhaust through it. This causes boost to increase as rpm's increase.
01-29-2013, 10:10 AM | #5 | |
Member#: 4803
Once you've completed that, try to get a data log as outlined in the video below (if you can do so safely). You can post the log up on google docs (make sure to set the permissions to public) and post the link here. Bill |
01-29-2013, 03:30 PM | #6 |
Member#: 281019
South East
You're the man Bill! I'll get it done as soon as I can. Only thing I was really confused on is I had been running the same tune for almost a year with no probs. But I did move recently and the air is a lot colder here. Not sure. I'll post the data up tonight or tomorrow morning.
01-29-2013, 08:30 PM | #7 | |
Member#: 281019
South East
https://docs.google.com/spreadsheet/...oRWJ1aXc#gid=0 https://docs.google.com/spreadsheet/...EdGpBRWc#gid=0 |
01-30-2013, 09:45 AM | #8 | |
Member#: 4803
Bill |
01-30-2013, 10:04 AM | #9 |
Member#: 281019
South East
Will do, I won't be able to check until Friday though. Left the car in the garage and I'm on duty for two days. I'll be back then. Thanks.
02-01-2013, 10:01 AM | #10 | |
Member#: 281019
South East
Ok this should be the right one. I didnt do a full reflash the first time, it was just the realtime. |
02-01-2013, 10:29 AM | #11 | |
Member#: 4803
Bill |
02-01-2013, 10:48 AM | #12 |
Member#: 281019
South East
02-01-2013, 10:53 AM | #13 | |
Member#: 4803
Bill |
02-01-2013, 10:59 AM | #14 |
Member#: 281019
South East
crap sorry forgot to add that part, it was in the next line where is starts all the verbage details about the map. It does say SLWG so it reads (Stage2+AEM93 MT v310 SLWG).
Sorry for the confusion. |
02-01-2013, 12:22 PM | #15 | |
Member#: 281019
South East
Sorry for the confusion |
02-01-2013, 12:41 PM | #16 | |
Member#: 4803
If you can do so safely, try to get some additional logs (of SLWG map) but add the "Inj. Duty Cycle" and "Intake Temp." monitors to the log (nothing else). You can do this by going to "Monitor" -> "Set Data Log List" and checking those two parameters. If you can get logs when it is colder out as well, that would be a good comparison. Bill |
02-01-2013, 01:37 PM | #17 | |
Member#: 281019
South East
01-27-2016, 03:24 PM | #18 |
Member#: 372769
Vehicle:2011 WRX WRB |
Updates?
Good Afternoon, All!
I'm recently experiencing the same issue running a similar (COBB SF Intake + Invidia TBE) setup. Has anyone noticed any updates? Thanks! |
02-10-2016, 04:41 PM | #19 |
Member#: 353788
South East
Vehicle:1997 Cherokee Tuned by AlanSnackbar |
welcome to Boost Creep fellas. Cold out + intake/dowpipe can = creep
Cobb is helping you try and control it but the problem is mechanical not tune based. IMO take the intake off during cold season. |
02-10-2016, 05:50 PM | #20 |
Member#: 164942
Vehicle:2015 Porsche Cayman |
If a car is prone to creep, even if its never done it before, a cold air intake will make it do it. Go back to the stock intake for the winter.
02-23-2016, 02:34 AM | #21 |
Member#: 440906
Vehicle:15 Stage 2 STI Ice Silver |
The problem is the aem cai. I talked with matt from innovative tuning in NY and the OTS Maps from cobb are prone to creep without proper boost control. My suggestion since I am in the same boat. I have a full invidia tbe and catless(even more boost creep). Take off the i take until you can get a ewg setup and a ebcs then put the intake back on and get a protune directly after. Or get rid of the intake if you dont want too spend the money on the proper setup
02-26-2016, 06:33 PM | #22 |
Member#: 353788
South East
It's not the maps fault. It's a mechanical issues that can be semi mitigated by swapping out some parts and tuning. Ultimately there is a point where you can't control it without drastic measures
