Brakes & Suspension Forum sponsored by The Tire Rack |
01-07-2005, 10:07 PM | #1 |
Member#: 74900
Vehicle:2008 STI black |
Occasional noise after switching to WRX front brakes on 95 L impreza
Occasionally, when doing a full throttle U turn in first gear, or driving around, my brakes will make a sound, as if they've reached the warning indicator on the pads. It goes away pretty quickly. What I'm guessing is, when putting on the WRX rotors and calipers, I didn't switch to WRX dust shields. This is allowing rocks or whatever to occasionally get stuck between my rotor and dust shield, causing a horrible screeching noise. I'm not that worried about it now that I know what's causing it. Just wanted to give a heads up to anyone else who may have been wondering what the noise was.
Oh one more thing, it seems to take 2 pushes of the brake pedal to get full pressure on those 2 piston fronts. Anyone else experience this? They work fine on one push but the pedal feels better if I press it twice. The car has 114k on it. Could it be due for a master cylinder? Also, is there an upgrade I should get, like a WRX MC or other subaru MC?
01-08-2005, 06:41 PM | #2 | |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
01-08-2005, 07:25 PM | #3 |
Member#: 74900
Exactly. At first I thought it needed to be bled again, but I'm thinking the stock MC just doesn't have enough pressure for those 2 pots. I wonder how much bigger the WRX MC is, compared to the L one.
01-08-2005, 09:58 PM | #4 |
Member#: 67767
NWIC
Vehicle:2010 WRX Red |
I put wrx brakes (and dust shields ) on my 97 OBS, and I don't have this issue. I will be putting a larger MC in there later when I get the rear wrx brakes on. Currently I have a 1" MC, and will go up to 1 1/16". Not sure, maybe your 95L has a 15/16" MC?
My brakes are stronger as they are now than stock, with a hardly detectable increase in pedal travel, which will probably get worse when I get the rear brakes on (which is why I plan the change to a larger MC.) Your 2 push issue is interesting. The wrx MC is 1 1/16", but may be non-compatible with your current MC setup. I have to go with a Legacy MC, personally, so it's something to check out. |
01-08-2005, 10:49 PM | #5 | |
Member#: 63076
Vehicle:2004 Outback Sport Red! |
Trying to upgrade to WRX front brakes... | ihartred | Brakes, Steering & Suspension | 7 | 11-29-2009 03:46 PM |
quick question on rs to wrx front brake conversion | doubledribble | Brakes, Steering & Suspension | 2 | 12-21-2006 04:13 PM |
What's needed to put WRX front brakes on Legacy? | legacysayingbye | Brakes, Steering & Suspension | 4 | 03-10-2005 02:42 PM |
OBS to WRX front brake conversion....moving the front discs to rear | chri3 | Brakes, Steering & Suspension | 6 | 12-19-2003 02:32 PM |
Is there a bracket that will work to fit WRX front calipers on a 96 Impreza rotor? | rallynutdon | Subaru Conversions | 10 | 09-14-2003 11:37 PM |
