07-03-2012, 05:21 PM | #1 |
Member#: 174710
Vehicle:1997 Outback The $400 Special |
P0100, P0101 - Replaced MAF, Still Won't Start
Trying to fix my dads beater 95 Legacy. It's been having lots of idle and ignition problems lately because of the MAF sensor. For example, some days it would sputter like crazy and you would need to hold your foot on the gas for a few minutes and let it idle at about 3k before it would idle on its own. Otherwise it would just sputter out and die. HUGE loss in MPG overall even when it would idle on its own.
Well, we ignored it for long enough and it died totally. He was driving down the street when it cut out, and it had to be pushed back to the house (luckily it was close). Pulled out two codes, a p0100 and a p0101; both of which are MAF related codes. I replaced the MAF sensor with the one out of my impreza and it still won't start. However I should note that when I took the faulty MAF from the legacy and put it into the impreza it would at least start, just not idle correctly. We have fuel and spark. Can you think of anything else we should check? Keep in mind I have another car with the same motor that I am willing to temporarily cannibalize to figure this out. Thanks! Below is a video. http://youtu.be/E-i1Q3CnTDM
07-03-2012, 06:06 PM | #2 |
Member#: 165749
What about the wiring harness?
07-06-2012, 12:33 PM | #3 |
Member#: 174710
Harness is fine, checked connections for the MAF. Just to be sure I checked the MAP, Cam, Crank, Knock sensors too. I would imagine if one of the sensors was bad it would throw a code saying so. Still trying to figure this out
07-09-2012, 08:15 PM | #4 |
Member#: 174710
bump!
11-05-2012, 09:50 AM | #5 |
Member#: 337061
Vehicle:1996 Impreza Blue (obviously) |
Did you figure this out? I have a MAF code in my 96. Barely stays running. Inconsistent at any rpm. Terrible fuel mileage.
Tim. |
11-05-2012, 01:23 PM | #6 |
Member#: 174710
We took it to a shop and they got it running some how. It was a combination of a few things: it was losing compression in one of the cylinders and needed a headgasket replacement and the MAF was shot. I pulled the motor and replaced the headgasket and I replaced the MAF and coolant temperature sensor and we haven't had any issues so far. My suggestion would be to replace the MAF
11-05-2012, 01:33 PM | #7 |
Member#: 337061
Thanks for the follow up. I'll try throwing a MAF at it. At least that's an easy job.
Tim. |
11-06-2012, 06:50 AM | #8 |
Member#: 132457
Just goin to give u a heads up.. unplug maf & see if it idles yes it'll have check engine lite but it'll tell u if its bad or not..
11-06-2012, 09:24 AM | #9 |
Member#: 337061
Yeah, I read that somewhere else. Haven't had a chance to try it. Does that work after the computer has been reset? I've read that the computer supposedly learns to run without the MAF which is why unplugging it allows the car to continue to run.
Tim. |
11-06-2012, 03:24 PM | #10 | |
Member#: 165749
In my experience if you unplug the sensor while it is running it will quit. But it should start if you turn the key off and back on and crank it. |
11-06-2012, 08:11 PM | #11 |
Member#: 337061
Unplugged MAF, ran similarly to how it was running, but with a faster oscillation of the rpms.
Installed new MAF, problem gone. Tim. |
11-06-2012, 08:16 PM | #12 |
Member#: 6119
BAIC
Vehicle:1999 GM6 RBP |
