Tire & Wheel Forum sponsored by The Tire Rack |
05-04-2014, 06:57 PM | #1 |
Member#: 181826
MAIC
Vehicle:2005 Legacy GT GRP |
Need to replace a tire... only 10k miles - replace all 4?
Hi all,
I'm aware that for AWD vehicles, you generally have to replace all 4 tires for size matching/drivetrain purposes. My question is this: Is there a low-mile consideration where it would be ok to just replace 1 or 2 tires? I only have around 10k miles on my tires, and hate to replace all 4 =/ I tried plugging one of the tires that got a flat, but it keeps leaking and I have to refill it every 3-4 weeks or so. There's also some sidewall damage, so I don't really want to keep it on there for long.
05-04-2014, 07:06 PM | #2 |
Member#: 97135
NWIC
Take a tread depth gauge and measure the 3 good tires, order a single tire from tire rack and have them shave it to match the others.
05-05-2014, 08:01 AM | #3 |
Vehicle:OK buy Nates beans westcoastroasting.com |
at 10k my tires are 1/2 gone 'course they only start with 8/32's as it is...but |
05-05-2014, 09:29 AM | #4 |
Member#: 318736
MWSOC
Vehicle:2013 WRX Hatch CBS (BLCK) |
buy a new set of 4. my suggestion on shaving is a bad idea, and more shops will not do it, not that i know of. then sell the 3 tires
05-05-2014, 10:11 AM | #5 |
Member#: 8365
Vehicle:2019 Mazda MX-5 RF Machine Grey |
Why is shaving bad?
Krzys |
05-05-2014, 10:23 AM | #6 | |
Member#: 97135
NWIC
And any competent tire shop can shave a tire, as I mentioned in my first post - tire rack can do it for you. |
05-05-2014, 12:47 PM | #7 |
Member#: 335612
Tri-State
Vehicle:05 STI Black |
Tire Shaving - Where else besides tire rack?
I'd agree that having a tire shaved is certainly the way to go. But, the only place I know that still does it is tire rack. Care to help us ouit and let us know of any other national chain or local places that offer this service?
05-05-2014, 01:46 PM | #8 | |
Member#: 97135
NWIC
Call your local motorsports shop (not ricer shop), they'll know. |
05-05-2014, 02:25 PM | #9 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
05-05-2014, 10:09 PM | #10 | |
Member#: 321546
BAIC
Vehicle:2006 Wrx Limited OBP |
Tires that get shaved should be measured by outside diameter not tread depth. I made this mistake and the tire was a whole 1/4 inch out of spec vs the others. Did it the right way after.....ordered same new tire.....and it didnt even need a shave even tho my tires were at 7/32. All within 1/5th of an inch from eachother. The shop or whoever shaves tires should measure od. Not how tire rack does tread depth......... Last edited by Scoobiesdoobies; 05-05-2014 at 11:12 PM. |
05-06-2014, 10:03 AM | #11 | |
Member#: 97135
NWIC
05-06-2014, 12:26 PM | #12 | |
Member#: 197384
NESIC
Vehicle:2006 WRX Ltd OBP |
05-06-2014, 01:06 PM | #13 | |
Member#: 321546
BAIC
And this isnt the case always just my experience. And you should NEVER shave a tire based on tread depth..... |
05-06-2014, 01:10 PM | #14 |
Member#: 321546
BAIC
Not me. A very well known performance alignment shop in the san francisco bay area....
I watched them....and they charge good money to shave the tire....I dont think they would turn down business like that after measuring od with a stagger gauge and rebalancing all my tires. Btw best balance ive ever had. All my measurements were within 1/5" of eachother. One brand new tire @ 11/32 and 3 tires at 7/32..... Nothings perfect guys....... |
05-06-2014, 01:13 PM | #15 |
Member#: 197384
NESIC
Just because a tire is out of round doesn't mean the circumference is going to change...
05-06-2014, 01:16 PM | #16 | |
Member#: 321546
BAIC
Cupping, out of round, sticker for race day........just saying not all tires are perfect. Ive had imperfections in almost every tire ive bought. Incuding my girlfriends tired which have the worst radial pull ever...... Does not change my point. Shave tires based on outside diameter........ You could have a 245/40 on one wheel and a 235/45 on the other with the same tread depth........doesnt mean they are the same OD. Not that you would mismatch tires but thats besides my point. |
05-06-2014, 08:13 PM | #17 | |
Member#: 97135
NWIC
I've never had an issue having tires shaved based on tread depth because you can more accurately match the wear patterns of the other tires. I.e if a good tire measure 5/32-4/32-3/32 (yeah my example has camber wear), it's best to match the tires as closely as possible. The only time when measuring by OD would be if you're buying different sized tires or a different brand/model - which again would jot be recommended. |
05-07-2014, 04:29 PM | #18 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
shaving a tire based on tread depth is perfectly acceptable and does yield a proper circumference when done correctly.
Shaving a tire for competition does not make it stickier. It reduces the tread squirm under load for better response. Your example of a 245/40-17 vs. 235/45-17 is not valid as their starting diameters are different. to the OP buy 1 tire and have it shaved to the proper tread depth |
05-07-2014, 10:55 PM | #19 | |
Member#: 321546
BAIC
And I was running 215 45 17. 7/32 and 11/32....out of spec based on tread depth.....in spec based on circumference. That is all. |
05-08-2014, 06:34 AM | #20 |
Member#: 8365
Who made your tires?
Were they really the same make and model? Krzys |
05-08-2014, 04:04 PM | #21 |
Tire Rack Moderator
Member#: 1215
If I wasn't offering an unbiased comment wouldn't I, as the moderator of The Tire Rack sponsored wheel and tire forum and a Tire Rack sales guy, want the OP to purchase 4 new tires?
I am here to provide CORRECT information when technical questions come up and in this case, as I have already stated, the OP should buy 1 tire and have it shaved to the proper, matching tread depth |
05-09-2014, 12:24 AM | #22 | |
Member#: 321546
BAIC
05-09-2014, 01:47 AM | #23 |
Member#: 97135
NWIC
05-09-2014, 07:38 AM | #24 |
Tire Rack Moderator
Member#: 1215
correct information is just that correct information
05-09-2014, 02:37 PM | #25 |
Member#: 321546
BAIC
