Brakes & Suspension Forum sponsored by The Tire Rack |
04-26-2012, 10:40 AM | #1 |
Member#: 95337
Vehicle:2018 WRX Limited |
Planning suspension upgrade for Spec.B
Ok, so I've been researching proper suspension setups for my car and figured I'd post some info up here in case any of you are in the same boat or just want something to read. I'm going off of the Legacy platform but some information may be useful for you guys.
DISCLAIMER: First and foremost, I didn't want to go with coilovers due to the added cost as well as added maintenance. I also don't need all of that adjustability. They're overengineered for my needs, which is a daily driver that handles well, has a more appealing ride height, and retains some of it's comfortable characteristics. Remember, it's a Legacy, not a WRX or STi. The Legacy is the Subaru's flagship luxury model and that's why I bought it. Not to turn it into what my WRX was. I decided on the Swift springs. They're JDM, just like the JDM Pink springs, and very good quality. They also give quite a bit of a drop compared to other springs, yet have a very good ride quality, especially when paired with the Bilsteins. Below is a chart on spring rates, the drop data may be off a bit. Also, I'm on Bilstein struts which has different tophats so a JDM spring is more appropriate for my vehicle. http://subiwiki.com/wiki/index.php/B..._Modifications Stock.......=..3.5 kgf/mm F.... 5.5 kgf/mm R Pinks..........=..4 kgf/mm F....... 6 kgf/mm R Tein S-tech.=..4.2 kgf/mm F.... 6.0 kgf/mm R Swifts.........=.4.25 kfg/mm F... 6.6 kgf/mm R If lowering any more than 1", the suspension geometry will be thrown off and car may have what's called "bump steer". An FRC (front roll center) or bump steer correction kit is recommended. I'll likely go with the Whiteline kit below since it includes both and should tighten things up quite a bit. KCA313 http://www.whiteline.com.au/product_...sans_vehicle=1 Also, the Legacy stock suspension doesn't allow for rear camber adjustment so I'll likely get the Whiteline rear camber bolts. When lowering the car, it'll actually add too much negative camber, something around -2.5* so I can get bushings which will give me back 1* and set me to -1.5*. I'm still not sure if I should get the camber bolts, or camber bushing. KCA399 http://www.whiteline.com.au/product_...sans_vehicle=1 A few guys get adjustable lateral links but this is my daily driver and won't be a track car, so I don't feel it's necessary to replace half of the suspension components. Not to mention, the Spec.B comes with lots of upgraded suspension over the standard GT models. This isn't really an option for me right now mainly due to the cost, and the car only has 27k miles on it so I don't want to start replacing things just yet. And like I said, it's a comfortable daily driver. I have no desire to turn it into a stiff, bouncy, track car. KTA124 http://www.whiteline.com.au/product_...sans_vehicle=1 So, to sum it up, this is pretty much my checklist: 1. Tires (Good set of tires) 2. Swift Springs (on the Rev C Bilsteins) 3. Front WL KCA313 4. Rear WL KCA399 5. (If I wanted to do what some of the other, suspension gurus get, which they think I'd be better served over the long-haul with) rear WL KTA124 and the KCA307 Rear Toe Lock bolts. 3. Performance alignment -1.0 front/-1.5 rear camber, 0* toe, 0* cross-camber. 4. And eventually, front WL KCA334 or AVO S1X03E1GV002T rear LCA bushings - when the stock ones fail. I came up with this list with the help from the guys over at LGT.com who are very knowledgeable. I posted what I gathered here to share the information as well as get some feedback from you guys. Thanks.
06-02-2012, 02:58 AM | #2 |
Member#: 185048
TXIC
Vehicle:07 Legacy Spec B 06 SGM Sti |
Nice write up. I am doing the same thing you are but replacing more. Still waiting on some of the bushings to show up but will be doing them all at the same time maybe in a few weeks. Here is a list of what Im replacing:
KCA313-WL Front Roll Bump Steer Kit AVO LCA Front Bushings AVO Caster Bushing Offset .5 AVO Steering Shaft Bushing KDT901-WL Positive Shifter Kit KCA399-WL Rear Camber Kit KDT905-WL Rear Differential Mount Bushings KDT906-WL Rear Differential Mount Bushings KTA124-WL Adjustable Rear Control Arm Kit KCA307-WL Rear Toe Lock Bolt Kit |
06-02-2012, 02:58 AM | #3 |
Member#: 185048
TXIC
06-02-2012, 05:28 AM | #4 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
i wouldn't do those springs.....we(me and another board member) installed those swifts on jdm spec b bilsteins on his lgt and he hated it....it was just too low and the springs were just a poor match to the dampers
we swapped the springs back and it was perfect if i had a leggy....id do the jdm springs and i would 100% no possible doubt....CALL MYLES at Race Comp Engineering he had/has a spec b |
06-08-2012, 09:22 AM | #5 |
Member#: 95337
Thanks, Scotty. Yes, Myles is a big contributor to the Legacy community. Awesome guy.
I ended up not getting Swifts and got a brand new set of JDM Pink springs. Haven't had time to install them yet. I also sold the LCA kit since the Pinks only lower the car 0.6". I'll update the thread once I get the springs on. SubyStud, definitely let me know how everything works out. Are you going to be tracking the car at all? I want to keep it as simple as possible since it's my daily driver. |
06-08-2012, 12:45 PM | #6 | |
Member#: 185048
TXIC
06-11-2013, 05:48 PM | #7 |
Member#: 359207
Bump!
I realize this thread is a year old, but I was hoping for some feedback on the suspension upgrades? Did you guys go through with it? Do you like it? did you change anything since then? Looking to upgrade my spec.B and would love some feedback.
06-12-2013, 04:16 PM | #8 |
Member#: 95337
UPDATE:
One of my stock Bilstein struts was blown (with only 20k miles), so I decided it would be best to just scrap the whole spring/strut idea and get coilovers since I would have to send out the strut to be rebuilt/replaced. I had the JDM Pink springs but sold them before installing and ended up picking up a set of RCE Tarmac coilovers. I still haven't decided what I want to do with my blown strut. Send it out, replace it, or sell all 4 of them. I also sold the Whiteline kit I had. I'm currently on the fence if I should just install the KCA399 or go all out and buy the WL KTA124 lateral links. I hate to throw money into a daily driver but the alignment shop couldn't get my rear alignment anywhere passed the stock specs and I'd like slightly more camber. I'm not terribly low, but I'm running 18x9 +45 with 235/40 tires and if I can't dial in more camber, I can't go any lower. Ideally I'd like to go about 1/2" lower. Last edited by Donzo; 06-12-2013 at 04:22 PM. |
06-12-2013, 11:55 PM | #9 |
Member#: 245483
Vehicle:2008 Legacy Spec B |
what wheels do you have?
07-02-2013, 03:14 AM | #10 | |
Member#: 185048
TXIC
suspension upgrades for the Baja? | Kai | Baja Forum | 3 | 01-18-2003 08:58 PM |
need suspension upgrade for wrx wagon | conbamay | Brakes, Steering & Suspension | 1 | 09-20-2002 09:02 PM |
suspension upgrade for bumpy roads... | potouli | Brakes, Steering & Suspension | 7 | 04-10-2002 11:22 AM |
DOT-R vs suspension upgrades for STX | WRXhauls | Brakes, Steering & Suspension | 12 | 01-03-2002 12:44 PM |
