08-18-2014, 10:35 PM | #151 |
Member#: 399215
Vehicle:2015 WRX Premium Dark Grey Metallic |
Also, did you ever figure out the radio antenna problem? I was wondering from SVXdc's website if we needed to just put the blue/white system remote control wire to the blue/white wire on the SVXdc harness. That is the power to start up the amp (both subwoofer, speaker, and the car antenna booster amp) if my understanding is correct. Anybody know if this is right?
08-19-2014, 07:43 AM | #152 |
Member#: 393302
Vehicle:2014 Impreza Sport |
I forget the actual color of the wires, but yes, you do need to hook the car antenna booster lead to the remote turn on from the radio. If your installing the NEX, I do believe there was only one lead for the remote turn for amp and antenna. Just double check your install instructions.
Also, I do believe you are variation B for SWC. Variation B is the one that lists Imprezas and WRX. If your still not sure, e-mail SVXdc and ask him. |
09-02-2014, 12:02 AM | #153 | |
Member#: 388235
Vehicle:2015 WRX GBP |
I was actually thinking about putting a front view camera for the same reason.
Although I'd like to retain the Fujitsu Ten factory Nav HU and hook the front camera into it's camera video input... if it even has one? That way the factory backup camera stays wired to the MFD, and the front camera can be switched on manually via button/whatever to display onto the OEM HU screen on-demand. A wide angle cam like this would be nice: https://www.youtube.com/watch?v=zCaf3C5l8Ck Of course I have no idea what I'm doing so it's also just 'big dreams' Quote:
09-02-2014, 07:18 AM | #154 |
Member#: 393302
Check on AE64.com. If it can be done, he should have the harness for it.
There are actually kits out there to do the bird's eye view. I believe I saw one from alpine. I think the hardest thing would be finding the right mounting point for the side view cameras. |
09-02-2014, 07:04 PM | #155 |
Member#: 378138
Vehicle:2022 WRX Silver |
Gentlemen....how do we get this done? Lol
09-03-2014, 06:56 PM | #156 |
Member#: 393302
This might help http://forums.nasioc.com/forums/show....php?t=2460699
09-06-2014, 10:48 PM | #157 |
Member#: 388047
Vehicle:2015 Wrx White |
Anyone tell me if there are wiring harnesses released so I don't loose all my steering wheel controls if I do an aftermarket navi
09-07-2014, 12:16 AM | #158 | |
Member#: 76503
Vehicle:2016 Mustang GT |
http://forums.nasioc.com/forums/show...55&postcount=3 |
09-21-2014, 12:50 AM | #159 |
Member#: 392396
SCIC
Vehicle:2015 WRX DGM |
so , I have a lot of HD stations in my area, but when I changed out the stock HU, I noticed a considerable decrease in clarity as compared to the crappy Subaru HU. it works fine and stays connected so I assumed that the pwr booster is working fine -but I do notice it sounds real crappy now. before, it would sound as clear as my ipod. anyone else have this issue ?
09-29-2014, 12:19 AM | #160 |
Member#: 202074
I just installed my 4000nex and working great except the VSS. Anyone know which wire from the 4000nex is for VSS?
10-07-2014, 04:01 PM | #161 | |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
Your issue sounds more like a defect in your new head unit (or just poor quality in the design). I suppose it's possible that your HU is staying locked on the HD signal, but is getting so many errors that you start getting poor reproduction that sounds like noise. Subaru's antenna booster amp requires a minimum of 12V to work. Some aftermarket HUs supply less than that, especially if you use the same wire from the HU for the trigger signal to an external speaker amp, subwoofer, and/or parking brake bypass. See the power antenna section of my 'Subaru 20-pin installation guide' for tips. |
10-07-2014, 04:03 PM | #162 |
Member#: 25837
South East
The Pioneer AVH-4000NEX doesn't need VSS (it doesn't have a wire for 'speed signal'). The AVIC-5000NEX and higher NEX models do. See my installation guide (link in previous post) for location of factory VSS wire.
10-09-2014, 03:10 PM | #163 | |
Member#: 382533
Vehicle:2015 WRX 6MT ltd+nav WR Blue |
I think VSS might improve GPS accuracy but I don't have any accuracy issues. Phones seem to do OK as GPS units without a VSS input. |
10-10-2014, 02:42 PM | #164 |
Member#: 238303
W. Canada
Vehicle:2011 WRX WRB |
I'll be replacing the front door speakers, I bought the wiring adapters, anything I would need beside the 6.5 speakers? Thanks
10-12-2014, 03:40 PM | #165 | |
Member#: 391762
Vehicle:2021 SQ5 2015 LE STI (gone) |
10-23-2014, 11:48 PM | #166 |
Member#: 389143
TXIC
Vehicle:2015 WRX Limited DGM |
been trying to reach SVXdc to order the bits i need for my 2015 w/ nav since August. tried sending from a different email in case mine was getting blocked; not sure what else to do. i see he's posted here but can't send a PM. if anyone has any ideas, i'm listening.
10-26-2014, 08:17 PM | #167 |
Member#: 403814
Vehicle:2015 WRX Premium WR Blue Pearl |
10-31-2014, 09:43 AM | #168 |
Member#: 388047
Is there a page or any posts about running the ebrake bypass line?? Thanks
12-25-2014, 04:51 AM | #169 |
Member#: 409320
Vehicle:2015 WRX 6MT limited Galaxy blue pearl |
App radio 4
I have the 2015 wrx with standard system and upgraded using the parts suggested from David. Everything works great but I just have 2 questions. The app radio 4 comes with a gps antenna can I use the factory Sat radio antenna to avoid wiring anything by modifying the connector? Second question when you guys are saying that you mounted the gps antenna that came with your pioneer radios you are just sticking it directly on top of the head unit itself?.
01-02-2015, 10:17 PM | #170 |
Member#: 387885
Hey guys, so I'm waiting on my 2015 WRX Base in DGM, and I figured that while I wait I may as well purchase a head unit and the adapters and whatnot and wire everything up, helps pass the time. I've seen a few of you have navigation units and mounted the gps antenna right above the HU behind the dash face, I have a Kenwood dnx571HD with the Garmin navi, and I wanted to do the same. Is it working well for those of you who did it? Any losses in signal or interruptions?
01-02-2015, 10:20 PM | #171 | |
Member#: 387885
02-19-2015, 12:43 PM | #172 |
Member#: 388585
Vehicle:2015 wrx base ISM |
I'm sure he's busy, curious if anyone's had any contact with SVXdc? I'd really like to order a harness from him but have yet to get any response so maybe going to Metra route to install my 5000nex.
02-23-2015, 10:07 PM | #173 |
Member#: 244245
Vehicle:2015 WRX lightning red |
http://autoharnesshouse.com/11443.html
Does anyone know if this is what we need for the camera to Aftermarket unit? (for base wrx) |
02-24-2015, 12:16 AM | #174 | |
Member#: 413709
02-24-2015, 08:56 AM | #175 |
Member#: 244245
