View Poll Results: ? | |||
A lot of people will make the mistake just like with diesel. | 17 | 54.84% | |
Not many, Americans aren't THAT stupid. | 3 | 9.68% | |
wth is E85? | 6 | 19.35% | |
I made that mistake. | 5 | 16.13% | |
Voters: 31. You may not vote on this poll |
07-08-2007, 07:03 PM | #1 |
Member#: 94524
How many people are going to put E85 in their non flex fuel cars?
I was watching ALMS on CBS before and they were playing a lot of ads about E85 and how good it is to use it. I noticed they never mentioned that E85 is only for E85 compatible/flex fuel cars, the American companies are pushing.
I also saw in a post on NASIOC saying this guy put some E85 into his 9-2x and it stopped his car from shaking. I'm not sure if there are any bad effects of putting E85 into a non compatible car, does anyone know? so how many people do you think will make the mistake?
07-08-2007, 07:04 PM | #2 |
Member#: 75638
NWIC
Vehicle:new metalocalypse is effin funneh |
you probably will.
07-08-2007, 07:05 PM | #3 |
Member#: 94524
I put Toulene[sp?] mixed with some ATF in my car.
07-08-2007, 07:06 PM | #4 |
Member#: 34931
Vehicle:. Super bowl LII Champions! |
i prefer an E30 to a E85
07-08-2007, 07:07 PM | #5 |
Member#: 75638
NWIC
07-08-2007, 07:08 PM | #6 |
Member#: 122980
South East
Vehicle:2010 F150, 2013 CX-5 92 Miata 15 TTF/PTF/E3 |
If youre smart and patient, you can tune a car to run e85. Ive seriously considered it with my WRX if they ever put the pumps in around me. Helloooooooooo extra HP and Torque!
The downside is, its less efficient at burning than gasoline, so you have to add more fuel. This means you get worse gas mileage, but everywhere Ive seen it in SC lately, it was a full dollar cheaper than premium. |
07-08-2007, 07:12 PM | #7 |
Member#: 22218
South East
There are some vehicles listed as E85 compatible that aren't really advertised as it (unlike the GM SUVs). For example, the ancient 4.0L used by Ford is listed as E85 compatible and the Nissan 5.6L V8 is as well.
chris619 dr_wheel Full_Clip will stick to gas. |
07-08-2007, 07:41 PM | #8 |
Member#: 50216
Vehicle:2005 Honda Insight 1993 Miata, 1953 CJ-3B |
You have to do two things: 1.) Make sure your fuel system is made of plastic that won't get damaged by the E85 fuel, and 2.) Adjust the mixture. Flex-fuel cars meet both requirements. Regular cars may meet the first, but not the second.
07-08-2007, 07:46 PM | #9 |
Member#: 89951
Vehicle:2016 Porsche 911 White |
Gas companies make more profit selling e85, and look environmentally friendly while doing it.
07-08-2007, 07:49 PM | #10 |
Member#: 60357
South East
people who think E85 will save us have no concept of an energy balance.
the future is in algae that produces stuff to make biodiesel. algae = simple, efficient and easy to grow. the only problem is finding out how to condense its growth and supply it with enough CO2. In the lab trials they actually have to use dry ice to supply these bastards with enough CO2. If someone can figure out how to get the system up and running, it will be doubly good for the environment. |
07-08-2007, 07:50 PM | #11 |
Member#: 99289
I'd run e85 in a heart beat if I could get it. New injectors, new fuel pump, and I'd be running way more boost and timing than I could safely on pump gas.
07-08-2007, 07:53 PM | #12 | |
Member#: 94524
there's a good article in Car and Driver that explains it. |
07-08-2007, 07:53 PM | #13 |
Member#: 63164
Vehicle:1971 Chevelle SS & RB26DETT S13 |
Dougie. Elaborate more please.
1) You must make sure there are ABSOLUTELY NOTHING RUBBER in your fuel system, the entire thing. Plastic, steel, what have ya.... NO RUBBER. Alcohol hates rubber. 2) You must "adjust" the fuel mixture in old Carbeurated cars becaues there is no "compensation" for fuel trim's and such. (I.E. No computer). "Flex Fuel" cars have O2 sensors and PCM's (Powertrain Control Modules) that can have parameters wide enough to accept E85. Most cars not already programmed to be able to accommodate the higher octane fuel will not be able to adjust themselves to that extent, they'll only see "Too Rich! Too Rich!" and will misfire profusely. In said carbeurated cars you must enrichen the mixture 15***37; .... and remove all non-alcohol friendly lines/hoses/tanks. |
07-08-2007, 08:01 PM | #14 |
Member#: 40989
Vehicle:OT vag inspector |
lets all run e85
lets see.....beer and corn prices have already gone up because of this |
07-08-2007, 08:05 PM | #15 |
Member#: 50216
Blaze: You are correct, sir.
07-08-2007, 08:18 PM | #16 | |
Member#: 26088
Vehicle:out of your system |
bad news for tequila drinkers too http://blogs.usatoday.com/ondeadline...g_global_.html |
07-08-2007, 08:53 PM | #17 |
Member#: 123574
Vehicle:2005 STi CGM |
<--- Has been running E85 in his STi for over a year now. Running E30 before that.
07-08-2007, 08:56 PM | #18 |
Member#: 16255
Vehicle:2004 Mazda 3 5dr 2013 Mini Cooper S |
^ one more reason for me to dislike e85
07-08-2007, 09:00 PM | #19 |
Member#: 39142
Vehicle:Memb er#: 39142 Join Date: Jun 2003 |
It's bad news for boaters too.
07-08-2007, 09:00 PM | #20 |
Member#: 123574
07-08-2007, 09:00 PM | #21 |
Member#: 94524
07-08-2007, 09:01 PM | #22 |
Member#: 123574
Read the E85 Fuel FAQ in the Engine Management & Tuning forum. Tons of good info.
07-08-2007, 09:03 PM | #23 |
Member#: 16255
07-08-2007, 09:04 PM | #24 | |
Member#: 123574
All that needs to be changed is the fuel pump, injectors, and tune. |
07-08-2007, 09:09 PM | #25 | |
Member#: 45400
RMIC
Vehicle:06 WRX TR OBP |
If anyone is actually interested in it, I would go do some research and NOT rely on this thread for info. |
How many people are willing to rallycross in the tri state area W.V.,P.A.,O.H? | 1butter | Mid Atlantic Impreza Club -- MAIC | 17 | 08-21-2006 11:51 AM |
So how many people are going to start... | forced4 | Texas Impreza Club Forum -- TXIC | 37 | 03-08-2006 07:48 PM |
How many people are unable to detach from reality... | Mikkito | Off-Topic | 9 | 11-28-2005 07:56 PM |
How many people are planning to go to Hot import nights in Chicago? | underground-mpyre | Mid West Subaru Owners Club Forum -- MWSOC | 22 | 07-25-2003 12:19 PM |
how many people are going to willow on 2/21 for that duratec event? | Poe | Southern California Impreza Club Forum -- SCIC | 6 | 01-26-2003 08:25 PM |
