08-21-2012, 11:54 AM | #13601 | |
Member#: 329271
South East
Vehicle:2012 Impreza Limited Ice Silver Metallic |
08-22-2012, 04:17 PM | #13602 |
Member#: 318978
The ones who installed aftermarket HID kits, do you have any issues with "flickering" when you first turn on and while its on?
If so, did you buy a harness relay to fix the issue? |
08-23-2012, 12:26 AM | #13603 | |
Member#: 315759
Vehicle:2014 WRX Hatch Satin White Pearl |
08-23-2012, 12:30 AM | #13604 |
Member#: 313093
VIC
Vehicle:2012 Impreza 2.0i 5-door Sport. Dark Grey |
Do you mean retrofitting HID projectors or just HIDs into the halogen reflectors? I have retrofit projectors and I get no "flickering" at all.
08-23-2012, 12:34 AM | #13605 |
Member#: 73068
Vehicle:2008 STI Boost Wagon 2014 Honda Accord Hybrid |
I had flickering issues with the two Xentec kits. They are really bad. I went with an AC Ballast with external igniters and they are rock solid. No flickering at all...
08-23-2012, 12:43 AM | #13606 |
Member#: 313093
VIC
That was the joke.
You should check out the retrofit source. |
08-23-2012, 06:59 AM | #13607 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
08-23-2012, 07:45 AM | #13608 |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
I'm pretty sure that all Jettas, including the Jetta Sportwagen, are built in Mexico regardless of which engine they contain (including the TDI).
08-23-2012, 09:17 AM | #13609 |
Member#: 302559
08-23-2012, 09:31 AM | #13610 |
Member#: 322264
Nope. The engine/transmission (at least for the TDI) is made in Germany. But the car is assembled in Mexico.
http://forums.tdiclub.com/showthread.php?t=313890 |
08-23-2012, 12:42 PM | #13611 |
Member#: 318978
08-23-2012, 12:45 PM | #13612 | |
Member#: 318978
You have a website link you can provide? What are External Igniters? |
08-23-2012, 01:00 PM | #13613 |
Member#: 310350
Vehicle:2012 Sport Limited Ice Silver Metallic |
Weathertech floormats just came in!! SOOOOO much better than the Subaru optional rubber mats...
http://www.weathertech.com/subaru/20...excluding-wrx/ |
08-23-2012, 01:03 PM | #13614 | |
Member#: 326540
BAIC
Vehicle:2012 Impreza MT SP DGM |
I've gone officially Toyota/Subaru from here on out... |
08-23-2012, 01:04 PM | #13615 | |
Member#: 326540
BAIC
08-23-2012, 01:11 PM | #13616 | |
Member#: 322264
Interestingly, the HPFP is one problem that my Golf TDI didn't have in the 30k miles I owned it (it did have several other issues, most minor, one moderate, and one critical). Had I kept that POS car, the HPFP issue would still be hanging over my head. |
08-23-2012, 01:15 PM | #13617 | |
Member#: 326540
BAIC
I bet that thing is having major issues by now! Maybe I should carfax the vin and find out. The only thing keeping this on topic is that it's how we both ended up driving subies. |
08-23-2012, 02:46 PM | #13618 |
Member#: 73068
I got them off of ebay. External igniters are in-line with the wire going from the ballast to the bulb. Not sure of the pros or cons however the Xentec kits I had had them built in to the ballast.
http://www.ebay.com/itm/280625347554...84.m1439.l2649 |
08-23-2012, 07:15 PM | #13619 | |
Member#: 318978
Are these the ones you bought that didn't have any flickering issues? Are these Xentec? |
08-23-2012, 08:42 PM | #13620 |
Member#: 73068
08-24-2012, 02:04 AM | #13621 |
Member#: 313093
VIC
I think 6000k HIDs are the best compromise between looks and light output, any higher your car will look rice and if lower the output is slightly yellow.
08-24-2012, 04:15 AM | #13622 | |
Member#: 319162
BAIC
Vehicle:2013 Impreza SL SWP |
From what I've seen: 4300k=OEM white 5000k=pure white 6000k=pure white/ hint of blue blue Best option would be 4300k, which has the maximum light visibility output available for HIDs. But if your looking for the bestlight output and looks, go with 5000k. Anything higher than that, then its more for the color and you start to sacrifice some visibility. Higher color temperatures=less visible lumens But the light output when going from stock halogens to HIDs is really noticeable, whether you choose any of the 3 above. I agree though, anything above 6k looks cheap and tacky. |
08-24-2012, 08:21 AM | #13623 |
Member#: 323103
Vehicle:2018 WRX Pure der |
Are they hard to install? Is there a DIY?
...probably... ...probably gonna catch crap for not searching first... ...probably should stop typing out my thoughts... ...i want bacon... |
08-24-2012, 10:30 AM | #13624 | |
Member#: 73068
I want bacon too. |
08-24-2012, 10:36 AM | #13625 | |
Member#: 323103
You can use the stock housing? Projector? Any chance of it blinding oncoming traffic? Are they h9 or h11? Thanks Last edited by myrt1987; 08-24-2012 at 10:59 AM. |
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 05:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
