Brakes & Suspension Forum sponsored by The Tire Rack |
11-30-2006, 05:56 PM | #1 |
Member#: 120766
SCIC
Vehicle:04 Wrx Stg2 Harman Tuned |
Cusco Camber Plates?? Tein Coilovers
So I bought a set of Tein Basic Coilover about a year ago now, and I keep having neg camber issues. Now Im assuming that this is because it cannot be aligned properly (had it aligned twice now) because of the stock pillow ball mounts. So if I purchase Cusco Camber plates for the Front and rear will this correct my problem, and will they work with the Tein Basic Coilovers?? Any other suggestions, or input would be appreciated.
12-04-2006, 11:41 AM | #2 |
Member#: 120766
SCIC
bump....
12-04-2006, 05:27 PM | #3 |
Member#: 62182
Vehicle:2005 STI White |
You have too much negative camber, or not enough?
-Mike |
12-05-2006, 02:18 PM | #4 |
Member#: 120766
SCIC
12-06-2006, 02:17 AM | #5 |
Member#: 99421
Vehicle:'13 BRZ White Pearl |
What's your toe? If you have zero toe and lots of neg camber, your tires shouldn't be wearing really fast. Granted they will wear more on the inside edge than the rest of the tire but it shouldn't be as bad as what you are describing. Toe (in or out) combined with camber is a sure tire killer. Are your front mounts pillow ball/slotted camber plates or pillow ball/fixed mounts? If they are fixed (single position) then get some slotted camber plates and that should fix your problem. If they are already slotted then you should have enough adjustability to get even tire wear.
12-06-2006, 05:22 PM | #6 | |
Member#: 120766
SCIC
12-06-2006, 06:09 PM | #7 | |
Member#: 39070
TXIC
Vehicle:-- GTF off my lawn! |
Why can't it be aligned properly?... the tie-rods adjust toe, the top strut bolt adjusts camber (what you can adjust, it's range is not huge), it's very simple. Any reasonable alignment shop should be able to figure it out. Your toe needs adjusting is my guess. |
12-06-2006, 10:24 PM | #8 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Ahhh, if only it were that simple. For one, your toe was probably never zero to begin with (unless you had it aligned before putting on the coil-overs), as the factory alignments are notorious for having toe settings all over the place.
And, as jamesohoh7 already pointed out, when you lowered the car that affected toe. I'll put even more emphasis on it than he did. Your toe is completely out to lunch right now, I guarantee it. You have major toe out, which is what is killing your tires. To agree with james yet again, a competent shop should be able to align the car using the factory adjustments with no problems. Pat Olsen '97 Legacy 2.5GT sedan |
12-06-2006, 11:13 PM | #9 |
Member#: 25859
South East
Vehicle:1965 MGB yellow 2008 Black Miata |
You say in OP that you have Basics, then later that you have Flex. Which do you have? Flex come with camber plates.
12-07-2006, 12:06 PM | #10 |
Member#: 120766
SCIC
Your right my mistake... i fixed that post. There just the Basic ones, no camber plates. So I could get away without having to buy the Cusco Camber plates, and still get a good alignment?? Or is it worth the extra 450 bucks to get the camber plates??
12-07-2006, 05:09 PM | #11 |
Member#: 120
AKIC
$450 for camber plates?! Are you buying ones made of diamond?
Go get an alignment. Unless you have the car absolutely slammed, there's no reason they would not be able to get the car properly aligned. Pat |
12-07-2006, 05:10 PM | #12 |
Member#: 25859
South East
If you are going to autocross, yes it is worth it to be able to adjust camber at the track and run less on the street. For just DD it is overkill and no nessessary.
12-08-2006, 04:29 PM | #13 |
Member#: 120766
SCIC
Similar Threads | ||||
FS in FL: Brand new Tein EDFC for 2004+ WRX and brand new Cusco camber plates | sonic03rex | Suspension/Brakes/Handling | 8 | 06-21-2007 11:31 PM |
Cusco Camber Plates, Tein Pillowball, Razo shift knob, etc. | zroom tsuchiya | Suspension/Brakes/Handling | 7 | 06-06-2007 01:33 AM |
KW Variant 3 Coilovers w/Cusco camber plates + Noltec F/R Camber Plates | JayD707 | Suspension/Brakes/Handling | 6 | 03-24-2007 09:29 PM |
using cusco camber plates with Tein Wagon coilovers??? | JohnW | Brakes, Steering & Suspension | 0 | 01-12-2004 07:48 PM |
cusco camber plates, kyb agx, ground control coilovers? | slvrwrx02 | Brakes, Steering & Suspension | 0 | 11-30-2003 06:29 PM |
