05-12-2003, 07:38 PM | #1 |
Member#: 2703
Vehicle:Y2K GC8 Silver forever |
Auto 2.5 RS owners, autocross question.
Hi to all automatic 2.5 RS owners,
I have some questions for you guys who do autocrossing. Do you guys use "D" all the time? Or do you guys need to shift a lot when cornering? (i.e. "D" then foot brake then shift to 2 or 1) I am new in autocross and I don't know should I shift when autocrossing. Thanks very much.
05-12-2003, 08:41 PM | #2 |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
I would think you'd want to leave it in 2 all the time, or if your TCU has auto upshift to leave it in first. I dont have a 2.5rs but I dont even use D when driving around in the city!!
Although not on topic I suggest learning to drive with two feet. With combination of brake and gas you can not only control shifting but weight balance and rpm level as well. Try it out. Your brake pads and transmission fluid will wear out fast but it sure does improve speed. In my "fun" Legacy the TCU will auto upshift right at redline, its great because I can keep the car in 1 and the RPMS will stay very high. Yet if I ever forget to shift into 2nd manually and reach a straight away of speed it will shift to second for me. It will shift back to first at the "first" oportunity (When rpms in 1 would be at or below 6k if I remember right). |
05-13-2003, 12:41 AM | #3 |
Member#: 12535
NWIC
Vehicle:Low 06 5MT OBXT 92 EG33 Legacy Rally Car |
I autoX my auto Legacy and I launch in first and shift back and forth during the run, dropping from 2nd to 1st helps me rotate the rear out in corners I would normaly plow through.
My very first run I use "D" so I can look for the proper line. Just experiment, you will find yourself getting very angry when the auto shifts before you want it to and in the middle of corners when you arent using full throttle. |
05-13-2003, 07:28 PM | #4 |
Member#: 6637
Vehicle:2005 Subaru Outback |
off the line I have it in 1st, then shift to second at redline...
then I leave it in second unless there is a box or other very low speed turn, in which you can pop it back into 1st... I do alot of left food braking to keep the turbo spooled as well |
05-14-2003, 01:07 PM | #5 | |
Member#: 7022
Vehicle:2001 Forester Arcadia green |
05-14-2003, 01:12 PM | #6 |
Member#: 6637
have'nt auto-X'ed her with the turbo yet... but my geuss is turns should be fun when exiting and then instantly spooling, car should get sideways VERY fast...
with the turbo, second gear is about half as long... I can redline VERY fast, so it should be interesting... |
05-14-2003, 01:36 PM | #7 |
Member#: 7022
you got a pm rhdude.
and to answer the question for the topic. I usually leave it in 3rd and do alot of left food brakeing. Also alot of peddle to the floor driving |
05-26-2003, 03:21 PM | #8 |
Member#: 2703
As I know when we left the stick in 1 or 2 the power will spilt to 50/50 but for 3 and D then it will be 90/10.
If that's true, then wouldn't it be nice to use 1 ro 2 when cornering? Anyone can tell me is that true? Thanks. Last edited by V6; 06-03-2003 at 01:40 AM. |
06-03-2003, 01:40 AM | #9 |
Member#: 2703
bump
06-03-2003, 01:32 PM | #10 | |
Member#: 4782
SCIC
Vehicle:2001 Forester SP Black Diamond Pearl |
I agree with the Doctor here!
~ferretboy |
New 2.5 RS owner | Famous Last Words | Bay Area Impreza Club Forum -- BAIC | 2 | 08-24-2004 01:03 PM |
Can 2.5 rs owners use the stock turbo kit from a 02 wrx? | OutkastWRX2 | Normally Aspirated with bolt-on Forced Induction Powertrain | 7 | 07-20-2004 11:17 PM |
2.5 RS owners who have bought WRXs: Whattya think? | motorob | General Forum Archive | 18 | 03-24-2001 05:15 PM |
Am I the First '02 2.5 RS owner?? | purduealum91 | Mid West Subaru Owners Club Forum -- MWSOC | 3 | 03-17-2001 08:02 PM |
2.5 RS owners vs I-Club members | STORER | General Forum Archive | 15 | 02-17-2001 12:45 AM |
