10-15-2006, 11:24 PM | #301 |
Member#: 126091
Vehicle:02 WRX Wagon WRB |
I'm trying to install a compustar 2wss(something like that) and I keep blowing a 50 amp fuse under the hood. It doesn't instantly blow it but after a minute or so. What would cause this? Perhaps a bad ground? Also I'm trying to do the 5 on/off thing to program my remote and it isn't working. Any help would be great!!
=Jason-
11-03-2006, 11:16 PM | #302 |
Member#: 115482
Vehicle:2006 WRX Limited Aspen White |
i'm going to install a dei rs 3.5 into my 06 wrx limited soon... wish me luck...
11-03-2006, 11:31 PM | #303 |
Member#: 130672
TXIC
Vehicle:99 Tacoma 4X4 Green |
11-04-2006, 12:38 AM | #304 |
Member#: 115482
tabbed out all the alarm wiring harness leads... now to make myself a writeup before i start on the wire locations.
11-21-2006, 12:53 AM | #305 |
Member#: 78967
VIC
Vehicle:2011 335i Black |
all this info. do they also apply/the same on a 06 sti?
11-21-2006, 01:35 AM | #306 |
Member#: 84382
BAIC
Vehicle:2006 STI Crystal Gray Metallic |
for the most part yes, can think of anything at the moment that is different.
11-21-2006, 02:23 AM | #307 |
Member#: 78967
VIC
^^ did you installed a alarm on your car? i've done it before on my 02 wagon with the help of vipernj and the other guy here i forgot his name.the only thing im worried about for my sti is if they have the same color code for wires like the 02
11-21-2006, 02:46 AM | #308 |
Member#: 84382
BAIC
I dont know 02 but 05 and 06 are very very similar. I cant think of anything different at the moment really (for 05 and 06 sti.
11-21-2006, 09:06 PM | #309 |
Member#: 33933
NESIC
Vehicle:2011 WRX Limited WRB |
veightkiller, the polarity of the neutral wire is the opposite in 2006 than it was in 2002. In 2002, it showed ground in gear. In 2006 it shows (+) in gear. I believe they changed it in 2005. Everything else is in the same location, although colors may have changed slightly. Connect the neutral wire according to how I described in post #291.
Also, I was one of the guys that helped you before. |
11-21-2006, 09:50 PM | #310 |
Member#: 115482
i'm about to do this install soon to my 06.
11-22-2006, 01:15 AM | #311 | |
Member#: 78967
VIC
thanks for helping out a fellow member |
12-14-2006, 09:15 AM | #312 |
Member#: 99549
Vehicle:2004 WRX PSM |
Hey guys,
wanted to say this thread is incredibly helpful! second last night during the install of the 791xv, we had a glorious idea. we wired the neutral switch as directed but also put it on the hood sensor. the reason for this is the installer had a lot of the hoodpins go bad, and when would i ever accidentaly start the car with the remote and the hoods open? so what this does for us is give me a visual confirmation that my car is NOT in gear, if it is the hood sensor will be tripped, and should the switch break (in a favorable position) the car wont start just wanted to pass this idea along! |
12-22-2006, 03:09 PM | #313 |
Member#: 118249
RMIC
Vehicle:2006 WRX Sedan WRB |
I'm having issues locating the security module in my 06. There doesn't seem to be any module behind the glovebox, nor do I see anything close to the parking brake. Also, I read on scoobymods that the keyless module and security module are one in the same. Thoughts? Thank you for your help
12-23-2006, 12:59 AM | #314 | |
Member#: 33933
NESIC
12-24-2006, 04:46 PM | #315 |
Member#: 118249
RMIC
Actually, after posting this, I disabled the alarm. My question, though, is if the ECU is reset, will I have to disable the alarm again, or will it remember that it is disabled? Thanks!
01-08-2007, 12:41 AM | #316 |
Member#: 136402
Guys, I am new to this. I downloaded the manual somewhere and was just reading it. Is it true that another immobilizer by-pass circuitry needs to be purchased to work with a 2006 2.5i? Thanks.
01-08-2007, 02:18 AM | #317 |
Member#: 42242
TXIC
Vehicle:2006 STI White |
I just read 7 pages and still don't know if i can buy just a remote starter and have it work on my 06 sti. ugh...
01-08-2007, 11:20 AM | #318 |
Member#: 70940
Vehicle:2004 Impreza WRX STI Java Black |
01-08-2007, 04:18 PM | #319 | |
Member#: 122980
South East
Vehicle:2010 F150, 2013 CX-5 92 Miata 15 TTF/PTF/E3 |
Just a heads up for anyone installing in a 2006: 1. The trunk trigger wire is BLU/white at the integrated module 2. You can tie the domelight supervision wire in with the door trigger in order to get supervision without a relay 3. The solid red wire in the gray plug at the integrated module is the trip wire for the defroster. I attached this to an aux output so I can turn the defroster on and off at will. 4. A turbo timer harness is a GREAT tool for not cutting the factory wiring 5. I used a solid yellow wire at the ECU on the plug closest to the firewall for tach learning. This wire will read ~1v at idle, and increas about 1 volt when you rev it. Also, if you want to rid yourself of the keyless module, it opens up some great real estate, and also you can tap certain wires at the keyless plug instead of the integrated module. |
01-11-2007, 11:44 AM | #320 |
Member#: 136402
Well, mine is a 2.5 i which I believe does not have a chip in the ignition. Plus when I arm my car using factory alarm I can still start the car with the key which tells me that there isn't a starter killer in the factory alarm (maybe just 2.5i). can someone confirm this?
So is the DEI just for bridging the 791 and factory security incase factory has an immobilizer? so what if I don't have factory starter killer? can the 791xv prevent the car from being started by a key when armed? thanx. |
01-11-2007, 12:14 PM | #321 | |
Member#: 122980
South East
The 791 can prevent it from being started, if you wire in the starter kill relay. |
01-11-2007, 03:58 PM | #322 |
Member#: 136402
Mine is the 2006 2.5i. I went to a local dealer to get keys for it and they told me it doesn't have immobilizer.
What's the different between Viper 5900 and a Python 990? |
01-15-2007, 01:44 PM | #323 |
Member#: 134734
SCIC
Vehicle:2013 WRX SE Tangerine Orange Peel |
Does anyone have any comments on a Crimeguard 745i listed on Crutchfield.
Link: http://www.crutchfield.com/S-dC6EuRw...p&I=514CG745I4 |
01-25-2007, 01:43 AM | #324 |
Member#: 51300
what alarms would you recommend...only thing id really wants is 2way 400-500 installed and just basic alarm options. thanks
01-25-2007, 01:51 AM | #325 |
Member#: 138716
I wish I could afford a remote starter! Can I have some money?
2005 WRX/STI Alarm/Remote Start Wiring Info | netZ | Car Audio, Video & Security | 4 | 05-05-2004 01:52 PM |
Viper 790XV 2-way alarm/remote start, Plus Extras - Ultimate WRX Wagon Setup | flames | Private 'For Sale' Classifieds | 0 | 01-06-2004 10:11 AM |
Alarm, Remote Start, & Defroster... | quynce | Car Audio, Video & Security | 16 | 01-15-2003 10:22 PM |
Alarm/Remote start sale (i club only) | action audio | Mid West Subaru Owners Club Forum -- MWSOC | 22 | 01-24-2002 02:16 PM |
midwest alarm/remote start & install group buy | Donnie | Mid West Subaru Owners Club Forum -- MWSOC | 9 | 10-19-2000 09:04 PM |
