01-12-2005, 12:08 AM | #1 |
Member#: 25731
MWSOC
Vehicle:02 wrx(sold)/2005 Sti/ 93 Leg Wag |
EJ22T Structure - should I be worried?
This has been sitting in my garage for awhile since I bought it (underfunded project) and I finally got around to posting this. Should I be concerned about the block's integrity? It looks like someone tried to open up (scarred) the passages quite a bit.......not very professional:
Belly up, driver side passenger side exterior view |
01-12-2005, 04:16 PM | #2 |
Member#: 25731
MWSOC
bizzump
01-12-2005, 04:31 PM | #3 |
Member#: 43128
Vehicle:92 RWD, 96 FWD 05 AWD |
are you talking about the scratches in the passages?
i just went and looked at a ej20g closed deck..and it looks very similar. if your just talking about the scratches you should not have a problem. Rick |
01-12-2005, 04:42 PM | #4 |
Member#: 37558
South East
Vehicle:2003 TS wagon JDM bukkake white |
That hole looks to me like a typical crankcase pressure channel to allow the crankcase to equalize pressures between the crankcase and the valve covers. Looks the same on most (if not all) suby F/I blocks.
01-12-2005, 06:41 PM | #5 |
Member#: 25731
MWSOC
Cool, I hope so. When you have a better look at it, it appears that it was done with a beer (maybe more than one) in one hand and a drill bit in the other...unless they just do it that way from the factory.
01-14-2005, 06:12 PM | #6 |
Member#: 18588
Vehicle:1999 busted car silverthorn |
Im pretty sure its done that way at the factory...fast conveyor and air die grinder assembly work getting casting burrs off the case...my EJ22t had the same markings...and i was the 1st person to take mine apart.
01-15-2005, 11:57 PM | #7 |
Member#: 25731
MWSOC
Thanks all, I feel a little less stressed!
01-19-2005, 08:53 PM | #8 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
you are just seeing factory flashing. Build it...
01-20-2005, 12:35 AM | #9 |
Member#: 25731
MWSOC
Amen
01-21-2005, 10:54 PM | #10 |
Member#: 40337
BAIC
Vehicle:95 L Coupe Swapped |
Get a real torque wrench....
01-22-2005, 12:09 AM | #11 | |
Member#: 25731
MWSOC
Similar Threads | ||||
just put in ngks...should I be worried?... | Blindeye_03 | Normally Aspirated Powertrain | 8 | 06-22-2012 03:05 PM |
OT: should I be worried | subarurabbit | New England Impreza Club Forum -- NESIC | 24 | 10-29-2005 07:45 PM |
Should i be worried about this? | 00SilverWRXSedan | Service & Maintenance | 5 | 09-25-2002 07:18 PM |
Metal pieces found in tranny...should i be worried? | GDA | Transmission (AT/MT) & Driveline | 79 | 09-19-2002 07:03 PM |
I have a Phase 1 block should I be worried? | georgiamiata | Legacy Forum | 21 | 09-13-2002 02:51 PM |
