10-27-2009, 07:28 PM | #1 |
Member#: 213524
2009 Impreza 2.51 Seat Uncomfortable on Long Drives
My husband and I are basically happy with our basic Impreza. However, on a recent 3-hour trip, we both felt the seats were too stiff and hit us in the back at just the wrong spots. My husband was driving and had a backache at the end of the trip. We have a much longer trip coming up.
Can anyone out there with the same problem recommend some kind of cushion, backrest, etc. for more comfort? We're on the small side, pretty thin with no natural "padding." We've tried all different configurations for adjusting the seats, but the ride seems much stiffer than our old 2006 Forester. Thanks. |
10-28-2009, 10:19 PM | #2 |
Member#: 213664
Vehicle:2001 Legacy L Wagon 2006 Tundra DC |
Our major problem is the headrest that is a good 2-3" too far forward. THat in turn might make your back sore. To my knowledge that is no work around.
10-30-2009, 06:13 PM | #3 |
Member#: 223843
Vehicle:2009 Impreza 2.5i Silver |
Couldn't agree more with the head rest being too far forward. Seems like you have to deal with it. However, as for seats, I've been contemplating getting some memory foam and cutting it to fit the seat top, and slightly going up the seat back. Then I'd put on a seat cover, perhaps som Wet Okole covers or something similar.
10-30-2009, 06:33 PM | #4 |
Member#: 124924
SCIC
I got the 09 impreza (sedan) as a loaner car from the dealer. I thought it would be an okay car to drive and what not. And I wanted to see how N/A impreza would feel. First time I get on that car I find myself adjusting the seats... like NON-stop... I just couldn't find the right setting for me. Second, would be how stiff the driver seat is... third would be how static-y the seats are. When I sat on it I noticed something wrong. As soon as I put the key on the starter I get a quick jolt... As I drive the car I try not to move a lot to avoid being shocked.
10-20min of driving I noticed my back starting to ache... I would it was just me... but later I found out it's the seat. I tried to adjust it again while driving but no luck on that. Getting out of the car I tried my best not to rub around the seat a lot. But failed on doing so... zaap! Another shock touching the door. I sat on wrx TR seats before... I'm use to wrx seats and thinking the TR seats sucks. But I was wrong. The new impreza seats sucks even more. |
10-30-2009, 10:06 PM | #5 |
Member#: 202982
I love the seats in my '08 wagon. Coming out of a mid-90's Chevy, the buckets in the OBS are fantastic and support my back. I've moved the seat only a handful of times since getting the car much earlier this year, and am glad that the headrest is where it is as I can actually put my head on it, unlike my last car.
No complaints here. |
11-02-2009, 10:40 PM | #6 | |
Member#: 216116
South East
Vehicle:2014 Impreza Limited Crimson Red Pearl |
10-30-2009, 11:29 PM | #7 |
Member#: 113666
Vehicle:60' all over you |
the 08 wagon 2.5i seats are amazing
my wife and myself love em on long trips compared to my 06 wrx |
10-31-2009, 12:04 AM | #8 |
Member#: 224887
Vehicle:2010 WRX Hatch |
I have a 09 2.5i and I love the seats. Most comfortable seats I have had in a car. I have had no complaints either. When I drive my sister around she says it hard to stay awake cause it's so comfortable. I'm wondering if they are the same seats you have in your 09.
11-25-2009, 01:13 PM | #9 | |
Member#: 217782
just last week i took a 1650 mile road trip in it and had NO back problems |
10-31-2009, 12:35 AM | #10 |
Member#: 181568
Vehicle:2011 3.6R Legacy LTD Steel Silver Metallic |
My 08 OBS seats are ok, but I found my 04 Civic EX seats were much more supportive.
10-31-2009, 01:42 PM | #11 |
Member#: 220259
Vehicle:09 2.5i SSM |
I agree with the headrest bit, but the seats are actually pretty comfortable.
11-03-2009, 12:20 PM | #12 |
Member#: 202642
RMIC
Vehicle:08 Impreza,80Vette 68 Impala, 15 SantaFe |
The 08 2.5i seats are pretty comfortable. The passenger seat is little too low.
11-05-2009, 12:57 AM | #13 |
Member#: 186303
SCIC
Vehicle:2011 Legacy 2.5i 6MT SPW |
The 2.5i suspension is too soft. The seat probably isn't the best, but serviceable.
11-18-2009, 01:49 PM | #14 |
Member#: 223843
I've determined a quick and relatively inexpensive solution to those who are complaining about the headrest of these cars being too far forward: swap out the headrest for one that does not protrude as far forward as the OEM headrest. I had success swapping in a '05 Forester headrest that suits me.
Alternate idea from a Forester thread: Straighten the stock headreast. (1) Remove the headrest from the seat by first angling the seat back to clear the roof (2) Locate the zipper - unzip and remove the covering (3) Place the headrest on a solid workbench and use a piece of decking wood and C-clamps to hold the foam upper piece secure to the table. The posts should clear the edge of the workbench table. (4) Using a 2 ft or so gas pipe 1/2" or 1/4" dia, slip it over one post close just before it angles into the foam. You may have to push back about 1/2" on the foam. (5) Lift the pipe to move the headrest post the desired new angle. I went almost parallel to the table. (6) Do the same for the other one (7) Put the cover back on and re-install - done! Last edited by mshirzad; 11-18-2009 at 03:58 PM. |
11-20-2009, 05:06 PM | #15 |
Member#: 210880
International
Vehicle:2009 Impreza RX 2.0 Newport Blue |
I too find the headrest is too far forward. I've tried having it at all possible heights and also adjusting the rake of the backrest to make it a bit better.
I won't muck around with trying to modify it as it is one of those active headrests like in Volvos. That's one thing that annoyed me most about the car when I got it, if you bounce your head back onto the headrest with some force you can feel the 'active' mechanism in the seat hit you in the middle of your back. I've done 2x 16 hour return interstate trips in my 09 Impreza hatch and think I must have got the seat in the right position for me, as I find it quite comfortable for long trips now. |
11-20-2009, 06:04 PM | #16 |
Member#: 219940
Vehicle:2012 Forester Silver |
I just get back from a trip to Rochester, NY and the seats in my 2010 OBS were fine. My back didnt hurt at all and even my friends said they were nice
11-21-2009, 06:53 AM | #17 |
Member#: 61504
E. Canada
Vehicle:2004 outback sport green |
my 05 RS seats hurt(I try to keep trips under 30 min or I have a sore back)
my 04 OBS seats are awesome (did Montreal to Calgary and back and was comfy) my 99 Legacy Brighton was comfy BIG disapointment about the RS I really should find some heated seats used at a scrapper off an OBS or WRX |
11-21-2009, 10:11 PM | #18 |
Member#: 224887
I have a 09 2.5i Sedan and my buddy has a 09 2.5i Hatch. We both have the premium package. The hatch version has the headrest more forward and the seats feel different. We both bought our cars from the same dealership. I wonder if the seats are different from Sedan/Hatch?
11-23-2009, 09:56 AM | #19 |
Member#: 229726
Vehicle:'09 2.Slow OBP |
I actually think the seats are pretty comfortable but we all have our own preferences.
11-29-2009, 02:04 AM | #20 |
Member#: 171557
HIIC
swap in some wrx seats, idk about 09 but my 05 wrx wagon had pretty comfy seats, much better than the ones in my FC
Similar Threads | ||||
FRESH 2009 Impreza 2.5i (watchout) | CrotchMonster | Member's Car Gallery | 27 | 03-30-2009 01:56 PM |
2009 Impreza 2.5i radio install and bezel same as 2008? | Fustern | Car Audio, Video & Security | 3 | 02-23-2009 08:03 PM |
2009 Impreza 2.5GT and 2008 WRX difference? | danny31004 | Newbies & FAQs | 4 | 01-19-2009 01:43 PM |
2007 impreza 2.5i seats carpet and doorcards in a 97 impreza wagon? | 97sportwaggie | Interior & Exterior Modification | 4 | 07-09-2008 03:38 AM |
Found WRX donor, how are the seats on long drives? | 02_Forester | Mid Atlantic Impreza Club -- MAIC | 8 | 03-06-2002 08:18 AM |
