04-09-2007, 04:49 PM | #1 |
Member#: 132574
SWIC
Vehicle:04 Aspen White Sti GT35r, axis motor,280cams |
Quick injector Flow question
I bought some modded injectors a while back and just had them cleaned an flow tested. They installed new caps and o-rings also. Here is what I know. In a 30second test @ 40psi each injector ran within 2 ml of each other. They flowed @ 132ml. in 30 seconds. I need to know what cc they are flowing. Its should be around 800cc. Thanks
04-09-2007, 05:05 PM | #2 |
Member#: 33430
BAIC
Vehicle:2015 STI Galaxy Blue Pearl |
If you want a direct ml to cc conversion, they are equal. 1ml = 1cc. I believe injector flow rates are measured in cc's per minute, so with the info you gave, it looks like yours are flowing 264cc. Seems a little low, since stock injectors flow 440cc.
04-09-2007, 05:10 PM | #3 |
Member#: 94131
Vehicle:08' SRT Caliber Hard to keep clean black! |
Yeah thats right 1ml = 1cc, I think I would call the company who modded them and ask how they come up with that figure!
04-09-2007, 05:17 PM | #4 |
Member#: 33430
BAIC
Did the person you buy them from have them flow-tested? If so, what did their sheets rate them at? It is possible that they were modded incorrectly.
04-09-2007, 05:18 PM | #5 |
Member#: 132574
SWIC
They were modded by a guy on here. He sent them to me and told me that they just needed to be cleaned and flow tested. I had that done local. When I picked them up, the guy said that they were flowing so much that he had to turn the machine off. They should be somewhere around 800cc. Remember, that was just a thirty second test he gave me. So the number you gave me should be doubled, but its still way to low,.....hmmmmm
04-09-2007, 05:59 PM | #6 |
Member#: 33430
BAIC
Well, if 1cc = 1ml, and yours tested at 132ml/30 seconds, then the they are flowing at 264cc per minute.
04-09-2007, 06:01 PM | #7 |
Member#: 132574
SWIC
Yeah, you would think, but there is no way that that is what they are flowing. They were 565cc before the caps were cut. I Think it has something to do with the pressure or something.
04-09-2007, 06:10 PM | #8 | |
Member#: 101378
Vehicle:2022 Ioniq 5 SEL AWD Matte Baby |
The part that gets me is this: "...the guy said that they were flowing so much that he had to turn the machine off." Obviously 264cc per minute won't outflow the machine. My guess is he gave you some misinformation somewhere along the line. For example, maybe they flowed 132ml in 10 seconds, that would mean your flowing closer to the original goal. |
04-09-2007, 06:26 PM | #9 |
Member#: 132574
SWIC
Yeah, something isnt right, let me get the sheet he gave me real quick.
04-09-2007, 06:30 PM | #10 |
Member#: 132574
SWIC
IT says in his comments, "over my scale" He also said when I was there that he has several V8 cars that he had injectors tested for that wernt even close to mine. I told him they should be somewhere around 800cc. He told me that 800cc it way more than he had ever tested for. When he told me "like 30seconds" he sounded like he didnt know for sure how long he did it for. I am kinda pissed about it. I really need to know how much these things are flowing.
04-09-2007, 07:13 PM | #11 |
Member#: 33430
BAIC
If you're certain they were tested incorrectly, send them out to Witchhunter or somewhere more reputable to be tested again, properly.
FS: 4 sets of Modded WRX Injectors-Flow tested and cleaned with flow sheet | ScoobyNubieToo! | Engine/Power/Exhaust | 22 | 05-19-2008 10:11 PM |
Injector flow rating question | Andursun0013 | Normally Aspirated with bolt-on Forced Induction Powertrain | 2 | 11-25-2005 11:21 PM |
Modified injectors flow patterens question?? | greysave | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 19 | 10-23-2005 02:25 PM |
UTEC OLF Injector Flow Questions (Quick) | jetskizero | Engine Management & Tuning | 6 | 04-24-2005 02:26 PM |
quick injector question.. | DEX_WRX | General Community | 0 | 06-16-2004 09:45 PM |
