06-08-2005, 08:38 AM | #1 |
Member#: 88713
Vehicle:04 STi Blue |
a'pexi turbo timer-air/fuel read out hook up?
okay was reading the last post and it said it was in the wrong place so not to sure if this is right any how, i bought the a'pexi slim turbo time and it has a air fuel read out can anyone help with this what wire do i tap into?
i have a 04 sti
06-10-2005, 04:08 PM | #2 |
Member#: 82881
I think ravensblade has the diagram for the wireharness for the ECU.
06-11-2005, 09:59 PM | #3 |
Member#: 88713
i have the diagram but where is the ECU someone said behind the pass kick panel but no luck
06-11-2005, 10:06 PM | #4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
The ECU is under the passenger footwell. Peel back the carpet, you'll see the metal cover that's over it. Remove that and the ECU is underneath. Disconnect the battery before unplugging the connector and messing with the wiring.
Also note that the TT will only be able to tap into the rear 02, same as the cheap A/F gauges, so it won't be getting accurate readings. |
06-11-2005, 10:09 PM | #5 |
Member#: 88713
cool i get my pod soon putting a boost gauge i can read and pyro meter in
06-12-2005, 06:30 PM | #6 |
Member#: 88713
i have the wire diagram for an 02 wrx but not matching my ecu plugs. i have a 04 sti
06-12-2005, 06:50 PM | #7 |
Member#: 88713
okay found the o4 diagram but is says that their is a rear oxygen sensor and a rear oxygen sensor heater signal which one do i use? the dif is on says ign sw on (eng off) the siganl says 0, and the hearter signal is 0-1.0, the other box says eng on (idling) the signal says 0-0.9 and the heater signal has no read out?
sorry because i dont have more then 10 post i cant post the url Last edited by avengermike; 06-12-2005 at 06:56 PM. |
06-12-2005, 07:25 PM | #8 |
Member#: 88713
this thing is not going well im lookin at the diagram i have and my plugs dont look like any on this diagram, how can u tell what plug is what and what pin is what?
Similar Threads | ||||
A'PEXi turbo timer NIB | blazeEJ20 | Interior/Dressup/Audio & Security | 0 | 09-19-2007 09:55 AM |
a'pexi turbo timer and up-pipe | VFwrXrated34 | Engine/Power/Exhaust | 1 | 02-11-2007 11:05 AM |
A'PEXi Turbo Timer for sale - San Diego | YinUCSD | Private 'For Sale' Classifieds | 10 | 02-02-2004 02:46 PM |
A'PEXi Turbo Timer and A/F meter | jfalcon001 | New England Impreza Club Forum -- NESIC | 0 | 09-17-2002 04:30 PM |
A'pexi Turbo Timer installed (pics) | wrx2fast | Member's Car Gallery | 18 | 07-20-2002 07:12 PM |
