01-30-2005, 09:18 AM | #1 |
Member#: 67669
MWSOC
Vehicle:2005 2.5 Hybrid WRX evoIII 16G |
Outside (Ambient) Air temp for '05 WRX
After doing many searches/reading it appears that the '05 WRX comes with an outside air temp sensor which is used for the climate control. My question is can I replace just the fuel/water temp gauge in my cluster with a gauge from either an STI or an OBS? Is the plug/harness for the temperature sensor present behind my instrument cluster to make this a plug and play operation?
02-15-2005, 07:35 PM | #2 |
Member#: 67669
MWSOC
blump
02-15-2005, 09:02 PM | #3 |
Member#: 78967
VIC
Vehicle:2011 335i Black |
for the outside temp...it only display 2 digits..while your water temp is reading morethan 100+
02-15-2005, 09:46 PM | #4 | |
Member#: 37617
Vehicle:2007 |
As for whether or not that will work, I have no idea. Probably easier to just switch to an STi cluster. |
04-24-2005, 03:20 PM | #5 |
Member#: 27620
Tri-State
Vehicle:2009 Subaru WRX DGM |
where is this temp guage located?
04-24-2005, 04:09 PM | #6 |
Trust no one
Moderator Member#: 11170
Tri-State
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
You would need to swap the entire cluster. It's not possible to swap the individual gauges, and the circuitry for the temp readout is part of the cluster circuit board.
08-01-2005, 05:24 PM | #7 |
Member#: 72031
NWIC
Vehicle:2017 SS 1LE |
So, if you swap your '05 WRX cluster for a '05 STi cluster, will the outside temp display work?
08-01-2005, 05:32 PM | #8 |
Member#: 27620
Tri-State
bump...where is this existing temp guage located?
08-08-2005, 01:32 PM | #9 |
Member#: 67669
MWSOC
the temp gauge I am refering to is located underneath the front bumper behind where your front license plate would be (if you have one). I don't have a camera handy to take a pic of the unit but I know it is a temperature sensor and may also be used for the automatic climate control system. Someone once said that the water temp gauge from an outback sedan has the digital outside temp gauge in it and this gauge could be swapped for the WRX water temp gauge. That's what prompted this question....
08-08-2005, 08:43 PM | #10 |
Member#: 63445
MWSOC
Vehicle:2002 WRX Wagon PSM |
That's a shame to have to go with an entirely new cluster in order to get a temp gauge, and then have to install the sensor and wiring as well.
What would that cost? |
Similar Threads | ||||
Intake air temp of 02 wrx | Skoloseven | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 10-06-2008 01:51 PM |
WTB: Stock Air Intake for '05 STi | theformula175789 | Mid West Subaru Owners Club Forum -- MWSOC | 0 | 07-20-2005 03:12 AM |
WTT: '05 Aspen White STi Trunk & Wing for '05 WRX Trunk & Wing... | STIcky WRX AWD | Private 'Wanted' Classifieds | 2 | 11-21-2004 09:57 AM |
WTT: '05 Aspen White STi Trunk & Wing for '05 WRX Trunk & Wing... | STIcky WRX AWD | Private 'Wanted' Classifieds | 11 | 10-21-2004 10:36 AM |
