Brakes & Suspension Forum sponsored by The Tire Rack |
01-24-2003, 01:02 AM | #1 |
Member#: 14117
Vehicle:2005 Nissan Murano Pewter |
Wheel Alignment question
Hey there everyone! Got a quick question. First off, is there anyone out there running Ground Control Coilovers on their cars? And if so, what kind of alignment settings did you get, or tell them to use, when you took your car for an alignment? Any help is appreciated. Thanks in advance!
Bill
01-24-2003, 04:40 AM | #2 |
Member#: 13634
NESIC
Vehicle:2002 WRX WRB |
don't have ground controls, but alignment settings are probably better classified as mostly highway, street, or track/auto-x, as opposed to which spring/strut you have. i'm about half highway/city, running -1.3 camber in front, -1.1 camber in rear with camber bolts, 0 toe all around. i'm getting excellent tire wear and the car handles great.
01-24-2003, 08:40 AM | #3 | |
Member#: 14117
01-24-2003, 11:07 AM | #4 |
Member#: 13634
NESIC
you'll probably want as much negative camber as you can get with the eccentric bolts, should be able ot get -1.5. if you want more than that, you need camber adjustable strut tops. rear camber you should get camber bolts to lower it from the factory setting, i got mine down to -1.1. toe there are a lot of opinions about it, but basically toe out in the rear helps the car rotate, toe in at the rear helps stabilize the car. i would go with either 0 toe, or something like 1/16th toe out. you can do a search to find some more toe answers.
01-24-2003, 12:30 PM | #5 |
Member#: 14117
Awesome! Thanks for the response....now I have something to go off of when I go to the alignment shop....
wheel alignment question | 06impreza2.5i | Tire & Wheel | 10 | 09-07-2008 06:46 PM |
Wheel Alignment Question | Flexx999 | Canada Region Forum | 1 | 03-28-2005 11:10 PM |
wheel alignment questions | turner | Tire & Wheel | 0 | 01-13-2004 08:03 PM |
Wheel Alignment Questions | mturmel | Brakes, Steering & Suspension | 5 | 04-30-2003 01:38 PM |
Wheel change & Alignment question? | Robmat | South East Region Forum | 2 | 01-01-2001 08:02 PM |
