11-28-2012, 10:59 AM | #4101 |
Member#: 74064
So far, no mention of DUNE color. Currently, Dune is not an option for the 10th anniv rubicon.
http://www.autoblog.com/2012/11/28/2...-gets-full-fr/
11-28-2012, 11:21 AM | #4102 |
Member#: 210438
Vehicle:2012 Jeepfiniti G37X Rubicon |
Metal bumpers too, and apparently the front one is a winch mount.
11-28-2012, 11:25 AM | #4103 |
Member#: 74064
11-28-2012, 11:28 AM | #4104 |
Member#: 57283
Vehicle:2014 4.7L of TT Fury w/ 4Matic |
three colors. anvil, billet silver and black (from the autoblog pics) apparently
edit: correct on those three plus white, from Jeep.com |
11-28-2012, 11:33 AM | #4105 |
Member#: 74064
So far, I think I made the right decision going with a 12mw3 jeep.
11-28-2012, 12:08 PM | #4106 |
Member#: 95823
Vehicle:2003 Imprezza Wrx WRC BLUE |
11-28-2012, 12:26 PM | #4107 |
Member#: 22035
SCIC
Vehicle:2014 Brocoma DCab 71 FJ40, 13 DRZ400SM |
11-28-2012, 03:08 PM | #4108 |
Member#: 2902
TXIC
went up to hidden falls adventure park outside marble falls texas this last weekened with a bunch of jeep people (we were missing one toyota guy). had a good time. at the end of the day i had not broken anything, so i tried to climb out of a dried up waterfall. spare tire touched the ground so i called it quits. it made for some good photos though (pics are blurry because the guy using my camera didnt know how to work it in manual)!!
this dude got high centered. they had to put a line on the front and drag him passenger so he could get some traction. it beat up his rear pass fender and tore off the pass tail light. a few choice shots... nothing too major. Last edited by Damon; 11-28-2012 at 03:24 PM. |
11-28-2012, 03:09 PM | #4109 |
Member#: 2902
TXIC
that is all. Last edited by Damon; 11-28-2012 at 03:24 PM. |
11-28-2012, 03:18 PM | #4110 |
Member#: 74064
Damon your jeep is badass.
11-28-2012, 03:42 PM | #4111 | |
Member#: 114550
NESIC
11-28-2012, 04:34 PM | #4112 | |
Member#: 95823
11-28-2012, 05:03 PM | #4113 |
Member#: 2902
TXIC
^im hopefully going to be caging my wrangler this coming year. im at least going to look into getting something like that rigged into the cage since the spare bit me in the butt, but still hopefully be able to keep some storage area and keep it working with a slant back soft top.
11-28-2012, 05:05 PM | #4114 |
Member#: 2902
TXIC
11-28-2012, 05:38 PM | #4115 | |
Member#: 95823
11-28-2012, 05:57 PM | #4116 |
Member#: 2902
TXIC
if i had a two door i would probably have it permanently mounted where the rear seat is. since i have a four door i get the pleasure of trying to figure out how to mount all that in the itty bitty cargo area i have. i actually want to keep my back seat.
11-28-2012, 07:42 PM | #4117 |
Member#: 57283
11-28-2012, 07:47 PM | #4118 |
Member#: 2902
TXIC
11-28-2012, 07:48 PM | #4119 |
Member#: 12391
NESIC
Vehicle:I did her 5 times then 7 times, then 5 more |
11-28-2012, 07:50 PM | #4120 | |
Member#: 70698
Vehicle:wait until I go up a hill... |
Rub it in Damon, rub it in. |
11-28-2012, 07:51 PM | #4121 |
Member#: 4562
NWIC
Vehicle:2014 Electric Datsun 2005 Adventure van |
I'm really starting to dig those 4dr hard top Wranglers. Kind of reminds me of a D110
11-28-2012, 07:54 PM | #4122 |
Member#: 57283
I went by the Jeep dealer today to pick up the 2.5XT kit. Got to talking with their resident modder that handles the custom rigs they build and he sort of convinced me to go 3.5" on the 4dr. Probably a good idea. So, he'll have these in for me on Monday instead:
I also ordered the trick clamps. Figured it would be easier to put them on now.... |
11-28-2012, 07:55 PM | #4123 |
Member#: 57283
11-28-2012, 08:12 PM | #4124 |
Member#: 125113
RMIC
Vehicle:. im in joor bAs3 drinkin joor beerz |
Finally back into a Jeep of my own:
Picked this little beauty up for a whopping $500, and she runs! It's a '96 Limited with the 5.2 and full time 4WD (249 t-case IIRC). I lucked out since it has a regular u-jointed front drive shaft. Oh, and it's sitting right around 225k miles lol. So far I've done: Driver's side door hinge pins, also repaired where the door lock module ripped away from the inner door. This prevented the door from closing and latching shut. Coolant flush and fill, including flushing the heater core and t-stat. This fixed the issue of no heat out of the vents. Cleaned IAC, idles much better now, albeit a little low. Looking to test the TPS next. Both 02 sensors, helped with the surging while driving and cured the CEL. Still on the list to do is a new/used steering gear box, all new TRE up front, transmission pressure governor and shift solenoid (doesn't shift in 1st when at the stop light, however manually shifting in first works just fine. Fairly common issue with these), t-case and diff fluid changes, and toss on the old set of Maxxis Bighorns we used to run on my wife's WJ. Lift wise, I think I'll start with the IRO Foundation 3.5" lift kit and pick up a set of new stock front springs for the rear which I can get them locally for $60 a pair. This should give me plenty of clearance for the 31's I have sitting in my basement. Nothing too crazy since it will be my primary mode of transportation in crappy weather, along with relieving my wife's WJ of it's hunting season duties. |
11-28-2012, 08:17 PM | #4125 | |
Member#: 4562
NWIC
I keep thinking about picking up a Disco for the wife, but then I realize what a terrible idea that is |
with all the gay and straight threads | [27] | Off-Topic | 27 | 05-08-2013 06:31 PM |
the Official Rally/Off-Road thread? | Longitude | Member's Car Gallery | 178 | 09-05-2006 05:39 PM |
Why all the bestiality and dehydration threads today??? | Grap | Off-Topic | 15 | 01-11-2006 03:55 PM |
this site is dwindling (aka: The piss and moan thread v.2) | stevedood | Bay Area Impreza Club Forum -- BAIC | 59 | 04-01-2004 12:38 AM |
A lazy monday thread...A continuation of the saturday and sunday thread | DoctorNick | Mid West Subaru Owners Club Forum -- MWSOC | 9 | 09-10-2002 08:17 AM |
