05-14-2010, 08:55 AM | #1 |
Member Sales Rating: (4)
Member#: 148317
TXIC
Vehicle:1998 Subaru Impreza Brilliant Red |
FS: (NJ) 06 STi 6speed swap
Comes with
06 STI 6speed with shifter assembly ~30kmiles WRX rear diff with proper plate to accept STI driveshaft STI driveshaft If you have any questions feel free to ask -vince Last edited by tramix; 06-03-2010 at 08:46 AM. |
05-15-2010, 01:16 PM | #5 |
Member#: 148317
TXIC
the setup is still in the car. The plate is from an R180...removed and installed onto the r160 for a factory bolt-on solution. I will include the slave and shift fork
car isnt running anymore. Had the setup for about 2 months Last edited by tramix; 05-15-2010 at 08:34 PM. |
05-16-2010, 03:35 PM | #7 |
Member Sales Rating: (23)
Member#: 167739
Vehicle:15 Forester NA dat gas mileage |
Rear diff.
If you have an 02-05 WRX, they will be the same. With this setup, IIRC you won't be needing anything else, although I would advise upgrading to the STi Clutch setup. You can reuse your clutch slave cylinder and front axles if they are male. |
05-17-2010, 08:53 AM | #11 |
Member#: 148317
TXIC
The setup works.
Also you can have either style axles as I have gone through the trouble of installing axle stubs for female axles. If you have males, just remove the axle stub. The setup comes with a rear diff so anyone without a 02-05 wrx can use this setup. |
05-17-2010, 09:40 AM | #12 |
Member Sales Rating: (15)
Member#: 133418
Vehicle:2006 DOM3 XTR WRX TR SRR 407whp 365wtq ppg'd |
damn if this is available by my next paycheck i'll take it. which rear diff would i need to buy to throw this on my 06
Similar Threads | ||||
FS: (NJ) 06 STI 6speed swap | tramix | Drivetrain | 24 | 06-02-2010 11:54 AM |
You got the "200" STI 6speed swap lists now, how do you install? | wrx03.4wz | Transmission (AT/MT) & Driveline | 9 | 07-16-2009 11:32 AM |
08 sti 6speed swap | DausWRX | Transmission (AT/MT) & Driveline | 14 | 05-10-2009 11:55 AM |
Dowel Pins? STI 6speed swap. | AWNOPEEL | Transmission (AT/MT) & Driveline | 3 | 05-18-2008 03:18 PM |
