05-06-2009, 03:22 PM | #1 |
Member#: 134429
TXIC
Vehicle:02 wrx blu |
08 sti 6speed swap
im about to do a 6speed swap into my 02 wrx but i cant find anything on swaping an 08 6speed...would it swap like the previous 04/05 sti trannys or would i need additional parts besides the hubs, axels, rear diff, cv's, and drive shaft since its a newer transmission?
05-06-2009, 08:24 PM | #2 |
Big Ron
Super Moderator Member#: 18062
A 6mt is a 6mt
05-06-2009, 08:45 PM | #3 |
Member#: 15359
05-06-2009, 08:46 PM | #4 |
Member#: 85813
South East
Vehicle:2002 E46 M3 2006 RC51 |
05-06-2009, 08:52 PM | #5 |
Member#: 75234
Vehicle:2004 WRX Wagon with 07 STI 6-Speed Goodness! |
I believe the vehicle speed sensor is in a different location on the 08 STI trans.....I seem to recall someone who tried to do a similar swap and found that to be a problem.
05-06-2009, 08:53 PM | #6 |
Member#: 85813
South East
It is. The front housing is different and like the Legacy Spec B.
05-06-2009, 10:43 PM | #7 |
Member#: 115276
Vehicle:98 v9 RSTI 207 + rotated 30r |
damn, lucky.. i want an 08 6 speed..
05-07-2009, 09:04 AM | #8 |
Member#: 173100
South East
Vehicle:2002 WRX Blue |
I am also interested in doing this I am inbetween a 07 or 08
as far as fitment probably similar issues to others I know the bellhousing has to be changed with a previous year model one and the speed sensor as well but I dont know about drive shafts also is the DCCD the same? with the spidder unit work seing how the 08 has all the fancy drive modes I am assuming it is the same but IDK |
05-07-2009, 09:11 AM | #9 |
Member#: 85813
South East
You can't simply and easily swap 08 sti trans into earlier model WRX's and it will cost in the neighborhood of 5-6K to do it. You can get brand new 07's for $3500-4000. The 08's have no benefits to the 07's. The SI drive stuff is in the ECU's.
05-07-2009, 10:15 AM | #10 |
Big Ron
OMG I was owned!
05-07-2009, 04:58 PM | #11 |
Member#: 186893
South East
Vehicle:2004 WRX SILVER |
Well I was going to say
05-07-2009, 05:51 PM | #12 |
Member#: 170415
NESIC
Vehicle:2002 Hardware store bumper clips, that is all |
05-07-2009, 09:09 PM | #13 |
Member#: 159682
NESIC
Vehicle:1995 WRX 2015 F150 |
Yes that is the issue you'd have. You can put an 07 bellhousing on it, but then you might as well just buy an 07 trans.
05-09-2009, 08:16 PM | #14 |
Member#: 181046
SWIC
Vehicle:2002 wrx wagon psm aps s/r55, meth 6 spd |
i just had an 08 usdm sti 6 speed swapped in to my 02 wrx wagon by FAT in phx,az . . . cost me 6k out the door but runs great and am very happy for it
05-10-2009, 11:55 AM | #15 |
Vendor
Member#: 111780
All you have to do is swap a 07' or earlier bell housing to enable you to run the vehicle speed sensor (wich 08'+ don't have). You will also need the plastic gear that goes on to the front diff.
-Dylan @ Ds1 |
FS: (NJ) 06 STi 6speed swap | tramix | Tri-State Area Private Classifieds | 17 | 06-03-2010 08:46 AM |
FS: (NJ) 06 STI 6speed swap | tramix | Drivetrain | 24 | 06-02-2010 11:54 AM |
NEED HELP!!! - 08 sti clutch fork doesnt work with 08 sti trans swap into 02 wrx | STiGuy23 | Transmission (AT/MT) & Driveline | 4 | 04-09-2010 01:03 AM |
You got the "200" STI 6speed swap lists now, how do you install? | wrx03.4wz | Transmission (AT/MT) & Driveline | 9 | 07-16-2009 11:32 AM |
Dowel Pins? STI 6speed swap. | AWNOPEEL | Transmission (AT/MT) & Driveline | 3 | 05-18-2008 03:18 PM |
